Preliminary Datasheet SFM3020 series
Analog Mass Flow Meter
Product Summary
SFM3020 is Sensirion’s solution on providing high volumes of flow meters for medical ventilators in order to support the global
pandemic situation due to the Corona virus outbreak. It relies on a modular approach of assembling approved parts with good
availability to Sensirion and a high-volume through-put manufacturing.
The housing geometry is based on the SFM3000 flow meter, hence it remains mechanically compatible to the SFM3000.
A flow range from -10slm to +160slm and one directional flow supports high flow applications while still allowing to detect back
flows. To minimize pressure-drop the SFM3020 is equipped with one mesh at the inlet.
Disclaimer: The product is not fully qualified but the risk is deemed low as the processes and materials are already
used in other products currently in production.
Benefits of Sensirion’s CMOSens® Technology
Scalability
High reliability and long-term stability
Best signal-to-noise ratio
Industry-proven technology with a track record of more than 15 years
Designed for mass production
High process capability
Contents
1.
Ordering Information .............................................. 2
2.
Specifications ........................................................ 2
3.
Pin Assignment ...................................................... 4
4.
Package Outline .................................................... 6
5.
Revision History ..................................................... 6
6.
Important Notices................................................... 7
www.sensirion.com D1
Version 0.4 - April 2020
1/7
1. Ordering Information
Use the part names and order number shown in the following table when ordering the SFM3020. For the latest product
information and local distributors, visit www.sensirion.com.
Part name
Description
Order number
SFM3020-160-C
-10 to 160slm range, with cap
3.000.401
2. Specifications
2.1. Flow Specification1
Parameter
Condition
Measurement range 2
Accuracy4,5
Repeatability5
Noise Level5
span(0..160slm)
span(-10…0slm)
zero point
span
zero point
span
zero point
Span shift due to temperature variation
SFM3020
Air/O2: -10 to 160
Max.
Typ.
±3%
±2%
±5%
±3%
0.15 (max.)
0.05 (typ.)
1%
0.05
+1%
0.5%
0.06
Units
slm3
m.v.6
m.v.
slm
m.v.
slm
m.v.
slm
< 0.5% of reading per 10°C
Flow step response time (τ63)
< 5ms
Calibrated for
Air
Compensation formula
O2
Air, N2, O2, non-condensing
Media compatibility
Pressure Drop
@60slm
@200slm
One mesh version
很抱歉,暂时无法提供与“SFM3020”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+22824.89184
- 5+22140.15082
