CMW-FCC-CO1A
UV Module Solution
Pre-specification
CMW-FCC-CO1A
RoHS
Product Brief
Description
Features and Benefits
CMW-FCC-CO1A is a waterproof module with
peak emission wavelengths from 270 to
280nm.
The LED is sealed behind a UV-transparent
window to protect it from liquid and dust. The
module also features a threaded body and
mounting nut for hassle-free attachment into a
36mm diameter hole.
CMW-FCC-CO1A is suitably designed for
water and surface sterilization.
Waterproof
Deep ultraviolet LED
Compact footprint
RoHS compliant
Key Applications
Disinfection
Fluorescent spectroscopy
Chemical and biological analysis
Table 1. Product
Wp [nm]
Model
CMW-FCC-CO1A
Rev 1.0, March 28, 2019
Color
Black
IP Grade
IF [mA]
IPX8
100
1
Remark
Min
Max
270
280
Constant Current
Drive
www.seoulviosys.com & www.s-et.com
CMW-FCC-CO1A
Table of Contents
Index
Product Brief
Table of Contents
Performance Characteristics
Characteristic Diagrams
Mechanical Dimension
Precaution for Use
Rev 0.0, March 28, 2019
2
CMW-FCC-CO1A
Table 2. Electro - Optical characteristic at 100mA
(Ta=25℃, RH=30%)
Parameter
Symbol
Value
Unit
Peak Wavelength [1]
λp
275
nm
Forward Voltage
VF
6.5
V
Radiant Flux[2]
Φe[3]
7
mW
Power Consumption
P
0.65
W
Spectrum Half Width
Δλ
10
nm
View Angle
2Θ1/2
125
deg.
Weight
m
16
g
Table 3. Absolute Maximum Rating
Value
Parameter
Symbol
Unit
Min.
Input Current
Operating Temperature
Typ.
IF
[7]
Storage Temperature [7]
Max.
100
mA
Topr
- 20
60
ºC
Tstg
- 40
85
ºC
Notes :
1. Peak wavelength measurement tolerance: ± 3 nm
2. Radiant Flux measurement tolerance: ± 10%
3. Φe is the Optical Output Power as measured with an integrated sphere
4. Forward voltage measurement tolerance: ± 3%
3
CMW-FCC-CO1A
Characteristics Graph
Fig 1. Spectrum, Ta=25℃
110
100
Relative Spectral Power (%)
90
80
70
60
50
40
30
240
250
260
270
280
290
300
310
320
Wavelength (nm)
Fig 2. Forward Current vs. Forward Voltage, Ta=25℃
100
Current (mA)
75
50
25
5.5
6.0
6.5
7.0
Voltage (V)
4
CMW-FCC-CO1A
Relative Optical Output Power (%)
Fig 3. Relative Optical Output Power vs. Forward Current, Ta=25℃
100
75
50
25
50
75
100
75
100
Current (mA)
Fig 4. Peak Wavelength vs. Forward Current, Ta=25℃
290
289
288
Wavelength (nm)
287
286
285
284
283
282
281
280
50
Current (mA)
5
CMW-FCC-CO1A
Fig 5. Relative Radiant Flux vs. Ambient Temperature, IF=100mA
110
100
Relative Radiant Flux (%)
90
80
70
60
50
40
30
40
50
60
Ambient Temperature (C)
Fig 6. Peak Wavelength vs. Solder Point Temperature, IF=100mA
290
289
288
Wavelength(nm)
287
286
285
284
283
282
281
280
40
50
60
Tsp(C)
6
CMW-FCC-CO1A
Fig 7. Forward Voltage vs Solder Point Temperature, IF=100mA
7.5
Forward Voltage
7.0
6.5
6.0
5.5
5.0
30
40
50
60
Tsp(C)
Fig 8. Typical Spatial Distribution, IF=100mA
1.2
Normalized Intensity
1.0
0.8
0.6
0.4
0.2
0.0
-90
-60
-30
Viewing Angle [˚]
7
60
90
CMW-FCC-CO1A
Mechanical Dimensions
Unit : mm
“UV Module” Assembly Guide
Water Tank
Outer Guard
Notes :
- During assembly, the optimal torque on the “Outer Holder” component varies depending
on the material properties and wall thickness of the system utilizing the module. Test and
optimize it to suit your system.
SVC does not warranty assembly failure for the “Outer Holder” component.
- Dimensions indicate a nominal value with a tolerance of ±0.5 mm.
8
CMW-FCC-CO1A
Precaution for Use
A. UV Light
These devices are ultraviolet LEDs. During operation, the LED emits high intensity
ultraviolet (UV) light, which is harmful to skin and eyes. Do not look directly into the UV
light and wear protective equipment during operation.
UV light is hazardous to skin and may cause cancer. Avoid exposure to UV light when
LED is operational.
Precautions must be taken to avoid looking directly at the UV light without the use of UV
light protective glasses. Do not look directly at the front of the LED or at the LED’s lens
when LED is operational.
Attach the following warning labels on products/systems that use UV LEDs.
B. Static Electricity
Electrostatic discharge (ESD) is the defined as the release of static electricity when two
objects come into contact. While most ESD events are considered harmless, it can be an
expensive problem in many industrial environments during production and storage. The
damage from ESD to an LEDs may cause the product to demonstrate unusual
characteristics such as:
- Increase in reverse leakage current lowered turn-on voltage
- Abnormal emissions from the LED at low current
The following recommendations are suggested to help minimize the potential for an ESD
event.
One or more recommended work area suggestions:
- Ionizing fan setup
- ESD table/shelf mat made of conductive materials
- ESD safe storage containers
One or more personnel suggestion options:
- Antistatic wrist-strap
- Antistatic material shoes
- Antistatic clothes
Environmental controls:
- Humidity control (ESD gets worse in a dry environment)
9
CMW-FCC-CO1A
Precaution for Use
C. Handling Precautions
Do not use flammable material near the modules.
Do not touch the modules with wet hands
Do not attempt to repair or disassemble the module.
Do not drop or subject the module to strong impacts.
Avoid touching quartz glass parts especially with sharp tools such as Tweezers
Avoid leaving fingerprints on the quartz lens.
Use covered containers for storage to prevent dust buildup.
D) Other
Do not connect the module to a powered-on system/circuit.
- When connecting the module to an already powered circuit, the LED can
be damaged by the inrush voltage / current.
Epoxy Molding
- Bubbles may form during curing after epoxy molding.
- Bubbles are not problematic in function of product and may burst during
handling.
- SVC manages bubbles to within 2mm.
10
很抱歉,暂时无法提供与“CMW-FCC-CO1A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+143.565091+18.64838
