231GRAY BULK
231GRAY BULK
    SERPAC
    塑料 - ABS 盒 灰色 手持,分叉式双侧 4.380" 长 x 3.250" 宽(111.25mm x 82.55mm) X 1.500"(38.10mm)
231GRAY BULK 数据手册
231(3D exploded) -Click on image to show toolbar. Use to Play/Pause Animation. -Left click and drag on image to move 3D model. L 4.38 W 3.25 H 1.50 PART NO. 3-1 23 1025 6005 DESCRIPTION (Included) ACCSESSORIES (Optional) TOP PART NO. 339 439 50 BOTTOM Battery Cover #4X3/8” Self tapping (4) DESCRIPTION Prototype grid board Prototype clad board Non-skid feet 3D model options: a) Zoom in & out with center wheel. b) Pause at any moment to view and or print views. c) Change the views to ortho and section views if needed from the Views pull down menu. d) Explore options included in the tool bar like: Views, Transparency of model, Lighting type, etc. Notes: (Enclosure weight 0.21 lb / 95 gm) 1) Enclosure meets or exceeds IP40 and NEMA 1 2) Circuit Board drawings can be download at: http://www.serpac.com/Accessories/CircuitBoard/drawings/339-439-cbg.pdf 3) All components are RoHS Compliant. ALL DIMENSIONS ARE ± .010" 4/12/10 (1 of 2) 619 Commercial Ave. Covina, CA 91723 Ph. (626) 331-0517 Fx. (626) 331-8584 serpac.com 231(user print) 1.50 3.25 A .02 2.50 .70 2.20 .25 4 plc's 4.38 .52 3.60 .45 1.00 A 2.00 Insert Area .04 X .02 deep 2.48 Insert Area 5° TOP .31 8 plc's .10 typ. .09 typ. for #4 screw .26 4 plc's 1.28 BOTTOM 3.09 PART NO. 3-1 DESCRIPTION (Included) ACCSESSORIES (Optional) TOP 23 1025 6005 BOTTOM Battery Cover #4X3/8” self tapping (4) PART NO. 339 439 50 DESCRIPTION Prototype grid board Prototype clad board Non-skid feet Notes: (Enclosure weight 0.21 lb / 95 gm) 1) Enclosure meets or exceeds IP40 and NEMA 1 2) Circuit Board drawings can be download at: http://www.serpac.com/Accessories/CircuitBoard/drawings/339-439-cbg.pdf 3) All components are RoHS Compliant. .26 8 plc's .32 4 plc's SECTION A-A SCALE 1 : 1.5 ALL DIMENSIONS ARE ± .010" 4/12/10 (2 of 2) 619 Commercial Ave. Covina, CA 91723 Ph. (626) 331-0517 Fx. (626) 331-8584 www.serpac.com
231GRAY BULK 价格&库存
很抱歉,暂时无法提供与“231GRAY BULK”相匹配的价格&库存,您可以联系我们找货
