CHP5R5L104R-TW
CHP5R5L104R-TW
    CDA(智烽微)
    插件
    100 mF (EDLC) 超级电容器 5.5 V 径向,Can 900 毫欧 @ 1kHz 85°C 时为 1000 小时
CHP5R5L104R-TW 数据手册
CHP(5.5V)Series www.cda-cap.com FEATURES ● High power,high energy density ● Long cycle life,maintenance-free ● Lead terminals can be customized ● Explosion Safety ● RoHS Directive Compliant APPLICATIONS ● Consumer electronics, Ride thru power support, Back up power, Stand alone or augment existing, energy/power source. OPERATING TEMPERATURE RANGE ● -40℃ to +65℃ @5.5V Balanced, 5.1V Unbalanced ● -40℃ to +85℃ @4.6V Balanced, 4.3V Unbalanced GENERAL SPECIFICATIONS Item Performance Operating temperature -40°C to +70°C Capacitance range 0.10F to 60F Capacitance tolerance -20%to+50%; +0%to+100%; -10%to+30% Rated voltage 5.0V / 5.5 V Surge voltage 5.7 V Temperature characteristics Capacitance change: Within ±30% of initial measured value at +25°C Internal resistance: Within ±200% of initial measured value at +25°C High temperature load time After 70°C 2000 hours Capacitance change: ±30% of initial rated value Internal resistance: Within 2 times of initial specified value Projected cycle life (From rated voltage to 1/2 rated voltage at 25°C) After 500,000 cycles: Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Humidity characteristic Vibration resistance Shelf life Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Amplitude:1.5mm /Frequency:10~55Hz /Duration of testing:6 hrs Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CHP(5.5V)Series www.cda-cap.com DIMENSIONS DB Type: DA Type: L±1.5mm d±0.05mm D±1.0mm D±1.0mm L±1.5mm d±0.05mm W±1.0mm W±1.0mm P±0.5mm P±0.5mm 15mm min 15mm min (-)Negative 4mm min Cell Dia Ф4.0 Ф5.0 Ф6.3 Ф8.0 Ф10.0 Ф12.5 Ф16.0 Ф18.0 4mm min D 4 5 6.3 8 10 12.5 16 18 W 12 12 14 16 20 25 32 60 DC Type: P(mm) DA Type 5.8 7.5 10.0 11.5 15.5 17.5 23.7 26.0 DB Type 2.5 3.5 5.0 5.0 5.5 7.5 8.5 10.5 (-)Negative Фd 0.5 0.5 0.6 0.6 0.6 0.6 0.8 0.8 DZ Type:RADIAL BENT LEAD D±1.0mm L±1.5mm D±1.0mm L±1.5mm 3.0±0.5mm d±0.05mm d±0.05mm W±1.0mm P±0.5mm P±0.5mm W±1.0mm 15mm min 4mm min B mm±0.5mm (-)Negative (-)Negative Polarity Polarity Cell Dia Ф4.0 Ф5.0 Ф6.3 Ф8.0 Ф10.0 Ф12.5 Ф16.0 Ф18.0 D 4 5 6.3 8 10 12.5 16 18 W 12 12 14 16 20 25 32 60 P(mm) DC Type / / / 8.0 10.0 13.0 16.0 20.0 DZ Type 5.8 7.5 10.0 11.5 15.5 17.5 23.7 26.0 B(mm) 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 Фd 0.5 0.5 0.6 0.6 0.6 0.6 0.8 0.8 *for version with bent leads No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CHP(5.5V)Series www.cda-cap.com STANDARD PRODUCTS Rated Rated Part Number Voltage Cap. (V) (F) Size ФWxDxL (mm) Max.ESR ESRAC ESRDC (1kHz/mΩ) (mΩ) Maximum Maximum Endurance Peak Current(A) Current(A) Maximum Leakage Current (72hrs/mA) Power Maximum Energy Density Energy Density (W/Kg) (W.h) (Wh/kg) 5.0V Series-Connected SuperCapacitors Modules CHP5R0L104R-TW 5.0 0.1 CHP5R0L474R-TWX 5.0 CHP5R0L474R-TW 10*5*12 2000 3500 0.09 0.17 0.001 660 0.00035 0.38 0.47 13*6.3*14 400 1000 0.31 0.80 0.006 2143 0.0016 1.17 5.0 0.47 16*8*14 300 1000 0.38 0.86 0.006 2499 0.0016 0.78 CHP5R0L105R-TW 5.0 1.0 16*8*18 200 720 0.45 1.45 0.008 1667 0.0035 1.39 CHP5R0L155R-TW 5.0 1.5 16*8*22 190 580 0.64 2.01 0.010 1669 0.0052 1.68 CHP5R0L255R-TW 5.0 2.5 20*10*22 140 360 0.75 3.29 0.020 1852 0.0087 1.93 CHP5R0L505R-TWX 5.0 5.0 25*12.5*22 100 150 1.10 7.14 0.025 2740 0.0174 2.38 CHP5R0L755R-TW 5.0 7.5 25*12.5*32 70 160 1.52 8.52 0.065 1953 0.0260 2.71 5.5V Series-Connected SuperCapacitors Modules(Miniaturized) CHP5R5L104R-TW 5.5 0.1 10*5*12 900 1800 0.09 0.17 0.001 660 0.00042 0.38 CHP5R5L124R-TW 5.5 0.12 9*4*12 2000 3600 0.09 0.17 0.001 693 0.00045 0.38 CHP5R5L224R-TWX 5.5 0.22 10*5*14 800 1500 0.12 0.42 0.002 1117 0.00092 0.92 CHP5R5L224R-TW 5.5 0.22 13*7*14 400 800 0.14 0.60 0.006 3025 0.00092 1.00 CHP5R5L474R-TWQ 5.5 0.47 9*4*27 1100 1800 0.18 0.54 0.003 2046 0.0019 1.78 CHP5R5L504R-TWX 5.5 0.5 13*7*14 400 1000 0.16 0.66 0.006 2499 0.0020 1.36 CHP5R5L155R-TWQ 5.5 1.5 13*7*24 190 380 0.53 2.71 0.010 2880 0.0070 3.00 CHP5R5L205R-TWQ 5.5 2.0 13*7*27 190 380 0.56 3.00 0.010 2400 0.0090 3.33 No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CHP(5.5V)Series www.cda-cap.com STANDARD PRODUCTS Part Number CHP5R5L334R- TW CHP5R5L474R-TW CHP5R5L504R-TW CHP5R5L105R-TW CHP5R5L105R-TWX CHP5R5L105R-TWQ CHP5R5L155R-TW CHP5R5L155R-TWX CHP5R5L205R-TW CHP5R5L255R-TW CHP5R5L255R-TWX CHP5R5L255R-TWQ CHP5R5L305R-TW CHP5R5L355R-TW CHP5R5L355R-TWQ CHP5R5L405R-TW CHP5R5L405R-TWX CHP5R5L505R-TW CHP5R5L505R-TWX CHP5R5L505R-TWQ CHP5R5L755R-TW CHP5R5L755R-TWQ CHP5R5L106R-TW CHP5R5L106R-TWQ CHP5R5L106R-TWX CHP5R5L126R-TW CHP5R5L156R-TW CHP5R5L206R-TW CHP5R5L206R-TWX CHP5R5L256R-TW CHP5R5L306R-TW CHP5R5L416R-TW CHP5R5L506R-TW CHP5R5L606R-TW Maximum Size Max.ESR Rated Rated Maximum Maximum Leakage Voltage Cap. Endurance Peak Current ESRAC ESRDC Current(A) Current(A) (V) (F) ФWxDxL (72hrs/mA) (mm) (1kHz/mΩ) (mΩ) 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 5.5 0.33 0.47 0.50 1.0 1.0 1.0 1.5 1.5 2.0 2.5 2.5 2.5 3.0 3.5 3.5 4.0 4.0 5.0 5.0 5.0 7.5 7.5 10 10 10 12 15 20 20 25 30 41 50 60 5.5V Series-Connected SuperCapacitors Modules 16*8*14 300 600 0.34 0.90 16*8*14 300 600 0.47 1.05 16*8*14 300 600 0.50 1.05 16*8*14 360 540 0.44 1.79 16*8*18 240 360 0.61 2.02 16*8*22 200 400 0.74 2.12 16*8*22 200 300 0.74 2.84 16*8*18 260 320 0.59 2.60 16*8*22 200 300 0.74 3.38 20*10*22 150 225 0.97 4.40 20*10*18 180 270 0.80 4.10 16*8*27 160 330 0.75 4.05 20*10*22 150 225 0.97 4.93 20*10*22 150 225 0.97 5.38 16*8*27 120 180 1.20 5.90 20*10*27 150 315 1.17 5.35 25*12.5*22 90 135 1.42 8.21 20*10*27 150 315 1.17 5.35 25*12.5*22 90 135 1.42 8.21 20*10*32 90 135 1.51 8.21 25*12.5*28 100 160 1.80 10.66 25*13*32 70 105 1.93 11.54 25*12.5*28 96 140 1.95 11.25 25*13*32 70 105 1.93 13.42 25*13*37 60 90 2.23 14.47 32*16*27 50 75 2.41 17.74 32*16*32 70 120 2.09 15.00 36*18*42 36 54 3.52 26.44 36*18*37 43 72 3.1 20.54 36*18*42 40 60 4.34 27.50 36*18*42 35 50 4.64 33.00 36*18*42 45 60 3.55 31.53 36*18*62 30 45 6.04 42.31 36*18*62 25 40 7.20 50.47 0.006 0.006 0.006 0.006 0.010 0.012 0.012 0.012 0.015 0.015 0.015 0.017 0.020 0.020 0.020 0.028 0.030 0.028 0.030 0.030 0.070 0.052 0.055 0.055 0.056 0.068 0.095 0.088 0.080 0.110 0.120 0.250 0.300 0.25 Power Density (W/Kg) Maximum Energy (W.h) Energy Density (Wh/kg) 3084 3601 3184 2923 4201 4172 4172 3723 3307 3361 3056 3045 3361 3361 3667 2063 3634 2063 3634 4074 3359 3841 3362 3841 3507 3103 1952 2988 2345 2161 2503 1897 1939 2047 0.0019 0.0019 0.0020 0.0042 0.0042 0.0042 0.0063 0.0063 0.0100 0.0105 0.0105 0.0103 0.0126 0.0147 0.0147 0.0147 0.0210 0.0147 0.0210 0.0210 0.0152 0.0315 0.0315 0.0420 0.0420 0.0525 0.0525 0.0840 0.0735 0.1050 0.1260 0.1300 0.2101 0.1910 1.00 0.91 1.00 1.83 1.75 2.05 2.17 2.52 2.17 2.19 2.39 2.85 2.63 3.06 3.06 2.70 2.84 2.70 2.84 3.18 3.50 3.50 4.20 4.67 3.65 3.37 3.40 3.73 3.65 3.80 4.30 4.80 5.00 5.90 Note: Adds passive balance. Balance options can be provided upon request. Customers can choose according to the application. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CHP(5.5V)Series www.cda-cap.com QUALITY AND RELIABILITY No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CHP(5.5V)Series www.cda-cap.com LIFE TIME AND TEMPERATURE PERFORMANCE The life of a Super Capacitor is impacted by a combination of operating voltage and the operating temperature according to the following equation : LS = LR × 2X × 2Y Which is X=(Tm-Ta)/10 Y= (Vr-Va)/0.2 Ls = Expected life of the super capacitor in the application LR = Load life rating of the super capacitor Tm = Max temperature rating of the super capacitor Ta = Ambient temperature of the application Vr = Rated voltage of the super capacitor Va = Maximum applied voltage on the super capacitor in the application No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CHP(5.5V)Series www.cda-cap.com SAFETY RECOMMENDATIONS WARNINGS REGULATORY • To Avoid Short Circuit, after usage or test, SuperCapacitors voltage needs to discharge to ≤ 0.1V • Do not Apply Over voltage, Reverse Charge, Burn or Heat Higher than 150°C, explosion-proof valve may break open • Do not Press, Damage or disassemble the SuperCapacitor, housing could heat to high temperature causing Burns • If you observe Overheating or Burning Smell from the capacitor disconnect Power immediately, and do not touch • MSDS • RoHS Compliant • Reach Compliant TRANSPORTATION Not subjected to US DOT or IATA regulations UN3499,
CHP5R5L104R-TW 价格&库存
很抱歉,暂时无法提供与“CHP5R5L104R-TW”相匹配的价格&库存,您可以联系我们找货
CHP5R5L104R-TW
    • 1+5.33600
    库存:5000
    CHP-5R5L104R-TW
      • 1+7.00812
      • 10+6.34716
      • 30+5.98752
      • 100+5.57928
      • 400+5.40432
      • 800+5.31684
      库存:325
