CSP-6R0L224R-TW
CSP-6R0L224R-TW
    CDA(智烽维)
    插件
    220 mF (EDLC) 超级电容器 6 V 径向,Can
CSP-6R0L224R-TW 数据手册
CSP(6.0V)Series FEATURES ● High power,high energy density ● Long cycle life,maintenance-free ● High Operating Voltage ● Lead terminals can be customized ● No Explosion Safety APPLICATIONS ● Consumer electronics, Ride thru power support, Back up power,Stand alone or augment existing,energy/power sourceexisting. OPERATING TEMPERATURE RANGE ● -40℃ to +65℃ @6.0V Balanced, 5.5V Unbalanced ● -40℃ to +85℃ @5.0V Balanced, 4.6V Unbalanced GENERAL SPECIFICATIONS Item Operating temperature Performance -40°C to +65°C Capacitance range 0.10F to 60F Capacitance tolerance -20%~+20% ; -10%~+30% Rated voltage 6.0 V Surge voltage 6.2 V Temperature characteristics Capacitance change: Within ±30% of initial measured value at +25°C Internal resistance: Within ±200% of initial measured value at +25°C High temperature load time After 65°C 1000 hours (at:6.0V): Capacitance change: ±30% of initial rated value Internal resistance: Within 3 times of initial specified value Projected cycle life (From rated voltage to 1/2 rated voltage at 25°C) After 500,000 cycles: Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Humidity characteristic Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Vibration resistance Amplitude:1.5mm /Frequency:10~55Hz /Duration of testing:6 hrs Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Shelf life After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-08-17 CSP(6.0V)Series DIMENSIONS DB Type: DA Type: L±1.5mm d±0.05mm D±1.0mm D±1.0mm L±1.5mm d±0.05mm W±1.0mm W±1.0mm P±0.5mm P±0.5mm 15mm min 15mm min (-)Negative 4mm min Cell Dia 4mm min D Ф4.0 Ф5.0 Ф6.3 Ф8.0 Ф10.0 Ф12.5 Ф16.0 Ф18.0 W 4 5 6.3 8 10 12.5 16 18 12 12 14 16 20 25 32 60 P(mm) DA Type 5.8 7.5 10.0 11.5 15.5 17.5 24.0 26.0 *for version with bent leads DC Type: DB Type 2.5 3.5 5.0 5.0 5.5 7.5 8.5 10.5 (-)Negative Фd 0.5 0.5 0.6 0.6 0.6 0.6 0.8 0.8 DZ Type:RADIAL BENT LEAD D±1.0mm L±1.5mm D±1.0mm L±1.5mm 3.0±0.5mm d±0.05mm d±0.05mm W±1.0mm P±0.5mm P±0.5mm W±1.0mm 15mm min 4mm min B mm±0.5mm (-)Negative (-)Negative Polarity Polarity Cell Dia Ф4.0 Ф5.0 Ф6.3 Ф8.0 Ф10.0 Ф12.5 Ф16.0 Ф18.0 D 4 5 6.3 8 10 12.5 16 18 W 12 12 14 16 20 25 32 60 *for version with bent leads P(mm) DC Type / / / 8 10 13 16 / DZ Type 5.8 7.5 10.0 11.5 15.5 17.5 24.0 26.0 B(mm) 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 Фd 0.5 0.5 0.6 0.6 0.6 0.6 0.8 0.8 No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-08-17 CSP(6.0V)Series STANDARD PRODUCTS Part Number Size Max.ESR Rated Rated Voltage Cap (F) ФWxDxL ESRAC ESRDC (V) (mm) (1kHz/mΩ) (mΩ) Maximum Endurance Current(A) Maximum Peak Current(A) Maximum Power Leakage Density Current (W/Kg) (72hrs/mA) Maximum Energy (W.h) Energy Density (Wh/kg) 1108 785 1108 3025 2265 2499 2880 2400 0.0005 0.0005 0.0011 0.0011 0.0022 0.0025 0.0075 0.0100 0.846 0.455 0.846 1.16 1.78 1.36 3.00 3.33 4286 4290 0.0024 0.0026 1.12 1.20 CSP-6R0L104R-TW CSP-6R0L124R-TW CSP-6R0L224R-TW CSP-6R0L224R-TWX CSP-6R0L474R-TWQ CSP-6R0L504R-TWX CSP-6R0L155R-TWQ CSP-6R0L225R-TW 6.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 0.1 0.12 0.22 0.22 0.47 0.5 1.5 2.2 CSP-6R0L474R-TW CSP-6R0L504R-TW 6.0 6.0 0.47 0.50 6.0V Series-Connected SuperCapacitors Modules(Miniaturized) 10*5*12 900 1800 0.10 0.25 0.001 9*4*12 2000 3600 0.09 0.19 0.001 10*5*14 900 1700 0.15 0.44 0.002 13*7*14 400 800 0.18 0.60 0.006 9*4*27 1100 1800 0.18 0.54 0.003 13*7*14 400 800 0.16 0.66 0.006 13*7*24 190 380 0.53 2.71 0.010 13*7*27 190 380 0.56 3.00 0.010 6.0V Series-Connected SuperCapacitors Modules 16*8*14 320 480 0.47 1.15 0.007 16*8*14 350 490 0.50 1.20 0.007 CSP-6R0L105R-TW 6.0 1.0 16*8*18 240 360 0.61 2.21 0.012 4762 0.0050 1.98 CSP-6R0L155R-TWX 6.0 1.5 16*8*18 260 320 0.59 2.84 0.013 3956 0.0075 2.68 CSP-6R0L155R-TW 6.0 1.5 16*8*22 200 300 0.74 3.10 0.014 4729 0.0075 2.46 CSP-6R0L255R-TWX 6.0 2.5 16*8*27 180 270 0.87 4.48 0.018 3907 0.0125 3.05 CSP-6R0L255R-TW 6.0 2.5 20*10*22 150 225 0.97 4.80 0.018 3810 0.0125 2.48 CSP-6R0L305R-TW 6.0 3.0 20*10*22 140 200 0.91 5.80 0.020 4198 0.0175 3.57 CSP-6R0L355R-TW 6.0 3.5 20*10*22 140 200 0.98 6.05 0.020 4198 0.0175 3.57 CSP-6R0L405R-TW 6.0 4.0 20*10*27 120 180 1.20 7.89 0.036 4156 0.0250 4.33 CSP-6R0L405R-TWX 6.0 4.0 25*13*22 120 180 1.20 7.89 0.036 4156 0.0250 4.33 CSP-6R0L505R-TWX 6.0 5.0 25*13*22 90 135 1.42 8.96 0.036 4118 0.0250 3.22 CSP-6R0L505R-TW 6.0 5.0 20*10*27 90 135 1.42 8.57 0.036 4118 0.0250 3.22 CSP-6R0L505R-TWQ 6.0 5.0 20*10*32 120 150 1.52 8.96 0.036 4235 0.0250 3.68 CSP-6R0L755R-TW 6.0 7.5 25*13*27 80 120 1.66 11.84 0.048 4453 0.0375 4.64 CSP-6R0L755R-TWQ 6.0 7.5 25*13*32 90 120 1.75 12.84 0.084 3600 0.0375 3.75 CSP-6R0L755R-TWX 6.0 7.5 25*13*22 80 150 1.35 10.59 0.030 3600 0.0375 4.69 CSP-6R0L106R-TW 6.0 10 25*13*32 70 105 1.93 14.63 0.066 4354 0.0500 5.29 CSP-6R0L106R-TWX 6.0 10 25*13*28 60 120 1.66 13.64 0.050 3428 0.0500 4.76 CSP-6R0L126R-TW 6.0 12.5 32*16*27 50 75 2.41 19.35 0.082 3516 0.0625 3.82 CSP-6R0156R-TW 6.0 15 32*16*32 40 60 2.92 23.68 0.090 3987 0.0750 4.15 CSP-6R0L256R-TW 6.0 25 36*18*42 32 48 3.96 34.09 0.126 3259 0.1250 4.53 CSP-6R0L306R-TW 6.0 30 36*18*42 30 45 4.09 38.30 0.145 3096 0.1500 4.84 CSP-6R0L506R-TW 6.0 50 36*18*62 26 39 5.30 50.85 0.288 2453 0.2500 5.54 CSP-6R0L606R-TW 6.0 60 36*18*62 24 28 5.51 56.96 0.260 2448 0.3000 6.12 Note: Adds passive balance. Balance options can be provided upon request. Customers can choose according to the application. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-08-17 CSP(6.0V)Series QUALITY AND RELIABILITY No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-08-17 CSP(6.0V)Series LIFE TIME AND TEMPERATURE PERFORMANCE The life of a Super Capacitor is impacted by a combination of operating voltage and the operating temperature according to the following equation : LS = LR × 2X × 2Y Which is X=(Tm-Ta)/10 Y= (Vr-Va)/0.2 Ls = Expected life of the super capacitor in the application LR = Load life rating of the super capacitor Tm = Max temperature rating of the super capacitor Ta = Ambient temperature of the application Vr = Rated voltage of the super capacitor Va = Maximum applied voltage on the super capacitor in the application No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-08-17 CSP(6.0V)Series SAFETY RECOMMENDATIONS WARNINGS REGULATORY • To Avoid Short Circuit, after usage or test, SuperCapacitors voltage needs to discharge to ≤ 0.1V • Do not Apply Overvoltage, Reverse Charge, Burn or Heat Higher than 150°C, explosion-proof valve may break open • Do not Press, Damage or disassemble the SuperCapacitors, housing could heat to high temperature causing Burns • If you observe Overheating or Burning Smell from the capacitor disconnect Power immediately, and do not touch • MSDS • RoHS Compliant • Reach Compliant TRANSPORTATION Not subjected to US DOT or IATA regulations UN3499,
CSP-6R0L224R-TW 价格&库存
很抱歉,暂时无法提供与“CSP-6R0L224R-TW”相匹配的价格&库存,您可以联系我们找货
