CXHP(2.7V)Series
www.cda-cap.com
FEATURES
● Low leakage current, long life
● High power,high energy density
● Small size and low-resistance
● Long cycle life,maintenance-free
● RoHS Directive Compliant
APPLICATIONS
● Consumer electronics,Ride thru power support,Back up
power,Stand alone or augment existing,energy/power
source.
OPERATING TEMPERATURE RANGE
● -40℃ to +65℃ @2.7V
● -40℃ to +85℃ @2.3V
GENERAL SPECIFICATIONS
Item
Performance
Operating temperature
-40°C to +70°C
Capacitance range
0.2F to 120F
Capacitance tolerance
-0%to+100%;-20%to+20%:-20%to+50%
Rated voltage
2.7 V
Surge voltage
2.85 V
Temperature characteristics
Capacitance change: Within ±30% of initial measured value at +25°C
Internal resistance: Within ±200% of initial measured value at +25°C
High temperature load time
After 70°C 1500 hours (at2.7V):
Capacitance change: ±30% of initial rated value
Internal resistance: Within 2 times of initial specified value
Projected cycle life
(From rated voltage to 1/2 rated
voltage at 25°C)
After 500,000 cycles:
Capacitance change: Within ±30 % of initial rated value
Humidity characteristic
Vibration resistance
Shelf life
Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C
Amplitude:1.5mm /Frequency:10~55Hz /Duration of testing:6 hrs
After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits.
No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw
Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product,
please be sure to contact our sales offices or agents immediately.
Spec. Date:2022-11-02
CXHP(2.7V)Series
www.cda-cap.com
DIMENSIONS
RADIAL LEAD TYPE
Size(mm)
RADIAL BENT LEAD TYPE
ФD
P
Фd
4
1.5
0.5
5
2.0
0.5
6.3
2.5
0.6
8
3.5
0.6
10
5.0
0.6
12.5
5.0
0.6
16
7.5
0.8
18
7.5
0.8
3.0 ±0.5mm
Style
B(mm)
A1
4.0
C1
2.0
STANDARD PRODUCTS
Part Number
Working Rated
Voltage Cap.
(V DC)
(F)
Dimensions
(mm)
D*L
Max.ESR
Maximum Maximum Maximum Power Maximum Energy
Leakage
Peak
Endurance Density
Energy
Density
ESRAC ESRDC
(72hrs/mA) Current(A) Current(A) (W/Kg)
(W.h)
(Wh/kg)
(1kHz/mΩ) (mΩ)
Radial Lead(Miniaturized)
0.09
1000
1820
0.001
0.17
833.1
0.0002
0.38
0.10
700
1200
0.002
0.19
1135.6
0.0002
0.34
0.11
700
1200
0.002
0.19
1249.7
0.0003
0.38
0.15
600
1000
0.002
0.40
1055.1
0.0003
0.87
0.15
600
1000
0.003
0.45
1077.3
0.0005
1.02
240
1600
0.006
0.52
0.14
1003
0.0005
1.86
0.16
700
1200
0.003
0.45
1093.5
0.0006
1.42
0.18
550
900
0.003
0.54
1023.2
0.0010
1.78
300
1500
0.006
0.54
0.16
1377.6
0.0012
1.92
0.18
200
400
0.003
0.66
3645
0.0012
1.62
0.33
200
400
0.006
1.16
2499.4
0.0012
2.17
CXHP2R7224R-TW
CXHP2R7224R-TWX
CXHP2R7304R-TW
CXHP2R7354R-TW
CXHP2R7504R-TWX
CXHP2R7504R- TW
CXHP2R7604R-TW
CXHP2R7105R-TWV
CXHP2R7105R-TWX
CXHP2R7125R-TWX
CXHP2R7125R-TW
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
0.22
0.22
0.3
0.35
0.5
0.5
0.6
1
1
1.2
1.2
4x10
5x10
4x10
5x10
5x12
6.3x12
4x22
4x25
6.3x12
6.3x11
5x22
CXHP2R7335R-TWX
2.7
3.3
6.3x22
90
180
0.010
2.44
0.53
3332.6
0.0033
3.18
CXHP2R7405R-TWV
2.7
4
6.3x25
90
130
0.010
2.44
0.53
3332.6
0.0040
3.18
CXHP(2.7V)Series
Part Number
CXHP2R7105R- TW
CXHP2R7205R- TW
CXHP2R7205R- TWQ
CXHP2R7255R- TW
CXHP2R7305R- TWX
CXHP2R7305R- TW
CXHP2R7335R- TW
CXHP2R7405R- TW
CXHP2R7475R- TW
CXHP2R7505R-TWX
CXHP2R7505R- TW
CXHP2R7605R- TW
CXHP2R7705R- TW
CXHP2R7705R- TWX
CXHP2R7805R- TW
CXHP2R7805R- TWX
CXHP2R7106R- TW
CXHP2R7106R- TWQ
CXHP2R7106R-TWX
CXHP2R7126R- TW
CXHP2R7156R- TW
CXHP2R7156R- TWX
CXHP2R7186R- TW
CXHP2R7206R- TW
CXHP2R7206R- TWQ
CXHP2R7256R- TW
CXHP2R7306R- TW
CXHP2R7306R- TWX
CXHP2R7356R-TWX
CXHP2R7356R-TW
CXHP2R7406R-TWX
CXHP2R7506R- TW
CXHP2R7506R- TWQ
CXHP2R7506R- TWX
CXHP2R7606R- TW
CXHP2R7107R-TWV
CXHP2R7127R- TWV
Working Rated
Voltage Cap.
(V DC)
(F)
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
2.7
1
2
2
2.5
3
3
3.3
4
4.7
5
5
6
7
7
8
8
10
10
10
12
15
15
18
30
30
35
35
40
50
50
50
60
100
120
Dimensions
(mm)
DxL
8x12
8x12
8x20
8x16
8x16
8x20
8x20
10x20
10x20
8x25
10x20
10x20
10x20
8x25
10x25
12.5x20
10x25
10x30
12.5x20
12.5x20
12.5x26
12.5x20
12.5x26
12.5x26
12.5x30
16x25
16x30
16x25
16x30
16x35
12.5x46
18x40
12.5x50
18x35
18x40
18x60
18x60
www.cda-cap.com
Max.ESR
Leakage
Peak
Endurance Density
Energy
Density
ESRAC ESRDC
(W.h)
(Wh/kg)
(1kHz/mΩ) (mΩ)
Radial Lead
160
240
0.006
1.09
0.47
4050
0.0010
1.13
100
280
0.010
1.73
0.49
2924
0.0020
1.90
100
120
0.012
2.15
0.55
2924
0.0020
2.15
130
180
0.025
2.27
0.59
4115
0.0025
2.32
130
195
0.012
2.56
0.59
4116
0.0030
2.79
100
120
0.012
2.79
0.65
4486
0.0030
2.34
100
150
0.012
2.98
0.74
4486
0.0033
2.57
70
170
0.015
3.65
0.79
2339
0.0040
2.40
72
170
0.017
3.60
0.75
2340
0.0047
2.50
90
135
0.015
4.03
0.87
3857
0.0051
3.01
75
113
0.015
4.32
0.97
3535
0.0051
2.30
75
113
0.020
5.20
0.97
3518
0.0061
2.77
75
113
0.020
5.29
0.97
3535
0.0071
3.22
90
135
0.015
4.86
0.87
3600
0.0071
3.94
60
150
0.020
4.61
0.93
2303
0.0081
2.80
60
150
0.020
7.58
1.35
3557
0.0081
2.94
65
98
0.030
6.84
1.15
3451
0.0101
3.89
50
75
0.030
7.71
1.43
3800
0.0101
3.30
45
68
0.030
8.06
1.42
3757
0.0101
2.94
50
75
0.036
8.53
1.35
3381
0.0122
3.52
40
60
0.050
10.66
1.80
3359
0.0152
3.50
45
68
0.040
10.06
1.42
3550
0.0152
4.16
40
60
0.055
12.27
1.66
3645
0.0183
5.06
30
60
0.060
13.50
2.70
2692
0.0203
3.10
35
53
0.055
13.17
1.93
3920
0.0203
4.76
27
50
0.060
15.00
2.09
2419
0.0253
3.50
0.070
18.41
2.53
2664
0.0304
3.70
25
38
0.072
19.06
2.41
3049
0.0304
3.97
22
33
0.080
21.93
2.79
3194
0.0354
4.27
19
42
0.086
23.86
3.24
3220
0.0354
3.65
0.080
23.68
3.01
3694
0.0405
5.47
16
24
0.105
30.68
3.96
2848
0.0506
3.96
18
35
0.105
28.72
3.40
3640
0.0506
5.69
18
27
0.110
30.92
3.52
2700
0.0506
5.06
15
23
0.150
34.47
4.09
2880
0.0608
4.28
13
45.76
5.30
2136
0.1013
4.82
13
48.50
5.30
2039
0.1215
5.52
*with appropriate voltage derating operating temperature can be extended to 85°C
CXHP(2.7V)Series
www.cda-cap.com
QUALITY AND RELIABILITY
CXHP(2.7V)Series
www.cda-cap.com
LIFE TIME AND TEMPERATURE PERFORMANCE
The life of a Super Capacitor is impacted by a combination of operating voltage and
the operating temperature according to the following equation :
LS = LR × 2X × 2Y
Which is X=(Tm-Ta)/10 Y= (Vr-Va)/0.2
Ls = Expected life of the super capacitor in the application
LR = Load life rating of the super capacitor
Tm = Max temperature rating of the super capacitor
Ta = Ambient temperature of the application
Vr = Rated voltage of the super capacitor
Va = Maximum applied voltage on the super capacitor in the application
CXHP(2.7V)Series
www.cda-cap.com
SAFETY RECOMMENDATIONS
WARNINGS
REGULATORY
• To Avoid Short Circuit, after usage or test, SuperCapacitor voltage needs
to discharge to ≤ 0.1V
• Do not Apply Overvoltage, Reverse Charge, Burn or Heat Higher than
150°C, explosion-proof valve may break open
• Do not Press, Damage or disassemble the SuperCapacitors, housing could
heat to high temperature causing Burns
• If you observe Overheating or Burning Smell from the capacitor
disconnect Power immediately, and do not touch
• MSDS
• RoHS Compliant
• Reach Compliant
TRANSPORTATION
Not subjected to US DOT or IATA regulations
UN3499,
很抱歉,暂时无法提供与“CXHP2R7224R-TW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+31.584891+4.09915
- 10+22.2307010+2.88514
- 50+18.5043450+2.40153
- 100+17.35286100+2.25209
- 500+15.40298500+1.99903
- 1000+14.799301000+1.92068
- 4320+13.851824320+1.79772
- 国内价格
- 1+5.35680
- 10+4.38480
- 30+3.88800
- 100+3.40200
