CXP-3R0304R-TW
CXP-3R0304R-TW
    CDA(智烽维)
    插件
    300 mF (EDLC) 超级电容器 3 V 径向,Can 700 毫欧 @ 1kHz 85°C 时为 1000 小时
CXP-3R0304R-TW 数据手册
CXP(3.0V)Series FEATURES ● High power,high energy density ● Long cycle life,maintenance-free ● 3.0V High Operating Voltage ● High reliability ● No Explosion Safety APPLICATIONS ● Consumer electronics,Smart meter, Back up power, Stand alone or augment existing,energy/power source. OPERATING TEMPERATURE RANGE ● -40℃ to +65℃ @3.0V ● -40℃ to +85℃ @2.5V GENERAL SPECIFICATIONS Item Performance Operating temperature -40°C to +65°C Capacitance range 0.22F to 600F Capacitance tolerance -20%~+50% ;-20%~+20%; -10%~+30%; -0%~+30% Rated voltage 3.0 V Surge voltage 3.15 V Temperature characteristics Capacitance change: Within ±30% of initial measured value at +25°C Internal resistance: Within ±200% of initial measured value at +25°C High temperature load time After 65°C 1000 hours (at:3.0V): Capacitance change: ±30% of initial rated value Internal resistance: Within 3 times of initial specified value Projected cycle life (From rated voltage to 1/2 rated voltage at 25°C) After 500,000 cycles: Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Humidity characteristic Vibration resistance Shelf life Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Amplitude:1.5mm /Frequency:10~55Hz/X,Y,Z(2hrs) /Duration of testing:6 hrs Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CXP(3.0V)Series DIMENSIONS RADIAL LEAD TYPE Size(mm) RADIAL BENT LEAD TYPE ФD P Фd 4 1.5 0.5 5 2.0 0.5 6.3 2.5 0.6 8 3.5 0.6 10 5.0 0.6 13 5.0 0.6 16 7.5 0.8 18 7.5 0.8 3.0 ±0.5mm SOLDER PIN TYPE 2-PIN 100~250F PART Terminal S1 type Style B(mm) A1 4.0 C1 2.0 SOLDER PIN TYPE 2-PIN 350~600F PARTS Terminal Z2 type (+)Positive 18.4±0.1mm (-)Negative Polarity SOLDER PIN TYPE 4-PIN 350~600F PART Terminal S4 type 5.0±0.1mm 21.1±0.2mm No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CXP(3.0V)Series STANDARD PRODUCTS Part Number Working Rated Voltage Cap. (V DC) (F) Dimensions (mm) D*L CXP-3R0224R-TWX CXP-3R0224R-TW CXP-3R0304R-TW CXP-3R0354R-TW CXP-3R0504R-TW CXP-3R0604R-TW CXP-3R0105R-TWV CXP-3R0105R-TWX CXP-3R0125R-TW CXP-3R0125R-TWX CXP-3R0355R-TW CXP-3R0455R-TW 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 0.22 0.22 0.3 0.35 0.5 0.6 1.0 1 1.2 1.2 3.5 4.5 4*10 5*10 4*10 5*10 5*12 4*22 4*25 6.3*12 5*22 6.3*11 6.3*22 6.3*25 CXP-3R0105R-TW CXP-3R0205R-TWX CXP-3R0205R-TW CXP-3R0335R-TW CXP-3R0405R-TW CXP-3R0505R-TWX CXP-3R0505R-TW CXP-3R0705R-TW CXP-3R0705R-TWQ CXP-3R0106R-TWX CXP-3R0106R-TWQ CXP-3R0106R-TW CXP-3R0126R-TW CXP-3R0156R-TWX CXP-3R0156R-TW CXP-3R0206R-TW CXP-3R0206R-TWQ CXP-3R0226R-TW CXP-3R0256R-TWQ CXP-3R0256R-TW CXP-3R0306R-TW CXP-3R0356R-TWX CXP-3R0356R-TW CXP-3R0506R-TW CXP-3R0606R-TW CXP-3R0107R-TWV CXP-3R0127R-TWV 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 1 2 2 3.3 4 5 5 7 7 10 10 10 12 15 15 20 20 22 25 25 30 35 35 50 60 100 120 8*12 8*12 8*16 8*20 10*20 8*25 10*20 10*20 10*25 10*25 10*30 12.5*20 12.5*25 12.5*30 12.5*25 12.5*25 12.5*30 12.5*35 12.5*35 16*25 16*30 16*30 16*35 18*40 18*40 18*60 18*60 Max.ESR Maximum Maximum Maximum Power Leakage Peak Endurance Density ESRAC ESRDC (72hrs/mA) Current(A) Current(A) (W/Kg) (1kHz/mΩ) (mΩ) Radial Lead(Miniaturized) 1000 1820 0.001 0.19 0.09 1028.6 700 1200 0.002 0.36 0.10 1021.7 700 1200 0.001 0.25 0.10 1123.1 600 1000 0.002 0.40 0.12 1253.1 400 700 0.002 0.44 0.15 1330.0 700 1200 0.003 0.50 0.16 1350.0 550 900 0.003 0.60 0.18 1263.2 240 1500 0.006 0.60 0.29 1108 200 400 0.006 1.29 0.33 3085.7 250 500 0.006 1.10 0.20 3085.7 90 130 0.010 2.71 0.53 4114.3 90 120 0.010 3.0 0.56 3512.2 Radial Lead 180 860 0.006 1.21 0.47 1322 130 260 0.006 1.15 0.26 1483 100 360 0.010 2.21 0.61 2609 98 280 0.012 3.31 0.74 2660 75 113 0.018 4.20 0.90 4141 90 135 0.015 4.48 0.87 4141 75 113 0.018 4.80 0.97 3794 70 170 0.020 4.79 0.79 2118 60 150 0.024 6.44 1.20 2769 55 83 0.030 8.22 1.25 4156 45 68 0.036 8.96 1.51 4417 45 68 0.036 8.96 1.42 4033 40 60 0.048 10.47 1.66 4288 35 53 0.062 12.59 1.93 4209 30 45 0.048 13.43 1.92 5581 35 47 0.050 13.64 1.66 3981 33 45 0.072 15.08 1.98 4195 34 48 0.060 14.50 1.97 3103 26 41 0.082 18.99 2.40 4858 25 38 0.082 19.35 2.41 3491 20 30 0.090 23.68 2.92 3930 20 40 0.070 21.88 3.09 3103 18 25 0.105 26.99 3.30 4310 18 20 0.075 37.50 3.96 4154 15 20 0.100 40.90 2.00 4000 13 20 0.260 50.85 5.30 2523 12 15 0.300 61.45 6.72 2688 Maximum Energy (W.h) Energy Density (Wh/kg) 0.0002 0.0002 0.0003 0.0004 0.0006 0.0007 0.0013 0.0013 0.0015 0.0013 0.0041 0.0050 0.71 0.87 0.79 1.05 1.08 1.75 2.19 1.92 2.68 1.86 3.93 4.07 0.0013 0.0025 0.0025 0.0041 0.0063 0.0063 0.0063 0.0088 0.0088 0.0125 0.0125 0.0125 0.0150 0.0188 0.0188 0.0250 0.0250 0.0275 0.0313 0.0313 0.0375 0.0438 0.0438 0.0625 0.0750 0.1250 0.1370 1.32 2.75 2.17 2.84 2.47 3.23 2.47 2.92 3.37 3.97 3.45 3.15 3.57 3.84 4.36 3.91 4.81 4.58 5.48 3.79 4.09 5.03 4.71 4.81 5.56 5.69 6.20 *with appropriate voltage derating operating temperature can be extended to 85°C No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CXP(3.0V)Series STANDARD PRODUCTS Working Rated Part Number Voltage Cap. (V DC) (F) Dimensions (mm) D*L Max.ESR ESRAC Leakage ESRDC (72hrs/mA) (1kHz/mΩ) (mΩ) Maximum Maximum Maximum Energy Endurance Density Energy Density Current(A) Current(A) (W/Kg) (W.h) (Wh/kg) Peak Power SOLDER PIN TYPE 2-PIN CXP-3R0107R-TW 3.0 100 22*45 8.0 11.2 0.276 70.75 6.84 4231 0.1250 5.48 CXP-3R0127R-TW 3.0 120 22*50 7.5 10.5 0.345 79.65 7.40 3594 0.1500 5.24 CXP-3R0157R-TWX 3.0 150 22*55 7.0 9.8 0.460 93.40 7.00 3800 0.2000 7.00 CXP-3R0167R-TW 3.0 160 22*55 7.0 9.5 0.460 94.20 8.00 3800 0.2100 7.00 CXP-3R0157R-TW 3.0 150 25*50 7.0 9.8 0.460 91.09 8.22 3150 0.1875 5.36 CXP-3R0227R-TW 3.0 220 30*50 6.0 8.4 0.598 115.87 9.83 2726 0.2750 5.83 CXP-3R0257R-TW 3.0 250 30*55 5.5 7.7 0.667 128.21 10.71 2877 0.3125 6.41 SOLDER PIN TYPE 2-PIN / SOLDER PIN TYPE 4-PIN CXP-3R0357R-TW 3.0 350 35*60 3 3.5 1.00 235.90 13.90 2657 0.4300 6.83 CXP-3R0367R-TW 3.0 360 35*60 4.0 5.4 0.98 183.42 14.49 2657 0.4500 5.98 CXP-3R0387R-TW 3.0 380 35*60 3.8 5.1 1.05 193.26 14.86 2751 0.4750 6.21 CXP-3R0407R-TW 3.0 400 35*66 3.5 4.7 1.15 207.61 16.15 2537 0.5000 5.55 CXP-3R0437R-TW 3.0 430 35*66 3.2 4.5 1.24 223.14 16.55 2505 0.5625 5.87 CXP-3R0487R-TW 3.0 480 35*70 3.1 4.4 1.35 234.30 17.17 2405 0.6050 6.13 CXP-3R0507R-TW 3.0 500 35*65 2.9 3.4 1.30 277.70 18.75 2405 0.6250 7.81 CXP-3R0607R-TW 3.0 600 35*70 3 3.5 1.50 290.30 19.95 3760 0.7500 9.14 *with appropriate voltage derating operating temperature can be extended to 85°C No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CXP(3.0V)Series QUALITY AND RELIABILITY No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CXP(3.0V)Series LIFE TIME AND TEMPERATURE PERFORMANCE The life of a Super Capacitor is impacted by a combination of operating voltage and the operating temperature according to the following equation : LS = LR × 2X × 2Y Which is X=(Tm-Ta)/10 Y= (Vr-Va)/0.2 Ls = Expected life of the super capacitor in the application LR = Load life rating of the super capacitor Tm = Max temperature rating of the super capacitor Ta = Ambient temperature of the application Vr = Rated voltage of the super capacitor Va = Maximum applied voltage on the super capacitor in the application No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-05-17 CXP(3.0V)Series SAFETY RECOMMENDATIONS WARNINGS REGULATORY • To Avoid Short Circuit, after usage or test, SuperCapacitor voltage needs to discharge to ≤ 0.1V • Do not Apply Overvoltage, Reverse Charge, Burn or Heat Higher than 150°C, explosion-proof valve may break open • Do not Press, Damage or disassemble the SuperCapacitors, housing could heat to high temperature causing Burns • If you observe Overheating or Burning Smell from the capacitor disconnect Power immediately, and do not touch • MSDS • RoHS Compliant • Reach Compliant TRANSPORTATION Not subjected to US DOT or IATA regulations UN3499,
CXP-3R0304R-TW 价格&库存
很抱歉,暂时无法提供与“CXP-3R0304R-TW”相匹配的价格&库存,您可以联系我们找货
