OT8ED8K5JI-111YXC-100M
    YXC(扬兴科技)
    SMD7050_4P
    有源晶振 100MHz 1.8V~3.3V-40℃~+85℃
OT8ED8K5JI-111YXC-100M 数据手册
CRYSTAL OSCILLATOR YSO110TR Wide Voltage Applications Features ‧Consumer Electronics Industrial Control IOT ‧Frequency range:1MHz-54MHz . ‧Ultra Small SMD seam sealed ‧Package Size: 1.6 x1.2 , 2.0 x1.6 2.5 x2.0 , 3.2 x2.5 , 5.0 x3.2 , 7.0 x5.0mm crystal oscillator units. Specifications 1MHz to 54MHz, or specify Frequency Range Parameter 1.8V~3.3V Output Type CMOS ±10ppm, ±20ppm, or specify Frequency Tolerance(at 25℃) Output Load 15pF Operating Temperature Range -40~+85℃, -40~+125℃, or specify Storage Temperature Range -55~+125℃ Frequency Versus Temperature Characteristics ± 20ppm, ± 30ppm, ± 50ppm, or specify Voltage Vol ( Max. ) / Vol ( Min. ) VOH = 90%Vdd/VOL = 10%Vdd Duty Cycle 45~55% Start-up Time 3ms Max. Rise Time/Fall Time 4nS Max Supply Current See Below Frequency Aging (at 25℃) ±3 ppm / year Max. Current Consumption Power Dissipation Vcc=1.8~3.3V 15pF only 1.000~40.000MHZ Supply Voltage (V) 7050/5032/3225 1.8V 4mA max 2.5V 3.3V 4.5mA max 5mA max 2520/2016/1612 4mA max Pin Dimension 41.000~54.000MHZ 7050/5032/3225/2520 9mA max 10mA max 12mA max Pin Assignments Pin #1 #2 #3 #4 FUNCTION Tri-state GND OUTPUT VDD www.yxcxtal.com 2016/1612 10mA max CRYSTAL OSCILLATOR YSO110TR Wide Voltage Dimensions and Patterns [unit:mm] Package Size – Dimensions (Unit: mm) Recommended Land Pattern (Unit: mm) #3 #2 #4 0.60max #1 Bottom View #2 1.25±0.1 MARKING #1 #3 0.57±0.1 0.7±0.1 0.775 0.5 0.775 0.6 0.2 0.6 1.65±0.1 #4 0.475±0.1 0.5±0.1 0.475±0.1 1.6 x1.2mm #3 #3 0.1 0.57±0.1 0.7±0.1 0.775 0.5 0.775 2.5±0.1 0.9 0.95 0.9 #4 #3 0.95 0.8±0.1 0.8 0.65 0.8 0.65 MARKING #2 2.0±0.1 #1 0.68 2.5 x2.0mm #2 #4 #2 0.85max #1 Bottom View 1.65±0.1 MARKING #1 0.675 0.3 0.675 2.05±0.1 #4 0.475±0.1 0.5±0.1 0.475±0.1 2.0 x1.6mm 0.78 0.4 3.2 x2.5mm 3.2±0.15 1.3 1.0 1.2 0.9 #3 0.9±0.1 #4 www.yxcxtal.com 1.1 0.8 1.1 1.0 2.5±0.1 MARKING 1.3 #2 0.65 #1 CRYSTAL OSCILLATOR YSO110TR Wide Voltage 5.0 x 3.2mm 1.4 2.54±0.1 5.0±0.2 #2 2.2 1.0 MARKING 3.2±0.1 1.2 #1 #4 #3 1.2±0.1 1.2 2.54 7.0 x 5.0mm 7.00±0.15 #2 2.0 #3 5.08±0.15 3.28 1.4±0.1 #4 2.2 2.6±0.1 MARKING 1.4±0.15 0.6±0.15 5.0±0.1 #1 1.8 Notes: 1.A capacitor of value 0.01uf~0.1uf or higher between Vdd and GND is required. Reflow Soldering Profile Temperature Pre Heating Temperature Tp1 ~ Tp2 = + 170 °C Heating Temperature TMlt = + 220 °C Peek Temperature TMax. = + 260 °C +260℃ TMax. +220℃ Tmlt Point of measuring In case of Solder ability Terminal. In case of Resistance to soldering heat Surface. Tp2 Tp1 35s 100s t(time) www.yxcxtal.com CRYSTAL OSCILLATOR YSO110TR Wide Voltage Test Circuit Taping Specification(Unit: mm) Size(OSC) A B C D E F G H SMD-7050 180±2.0 16.0±0.3 7.50±0.1 5.50±0.1 8.0±0.1 2.00±0.1 61.0±1.0 16.0±1.0 SMD-5032 180±2.0 12.0±0.3 5.40±0.1 3.60±0.1 8.0±0.1 1.70±0.1 61.0±1.0 12.0±1.0 SMD-3225 180±2.0 8.0±0.3 3.40±0.1 2.70±0.1 4.0±0.1 1.50±0.1 61.0±1.0 8.0±1.0 SMD-2520 180±2.0 8.0±0.3 2.90±0.1 2.40±0.1 4.0±0.1 1.20±0.1 61.0±1.0 8.0±1.0 SMD-2016 180±2.0 8.0±0.3 2.30±0.1 1.90±0.1 4.0±0.1 0.95±0.1 61.0±1.0 8.0±1.0 SMD-1612 180±2.0 8.0±0.3 1.80±0.1 1.40±0.1 4.0±0.1 0.80±0.1 61.0±1.0 8.0±1.0 www.yxcxtal.com
物料型号:YSO110TR WideVoltage
器件简介:YSO110TR WideVoltage是一款宽电压的晶体振荡器,适用于工业控制、物联网等领域。
引脚分配:1号引脚为三态(Tri-state),2号引脚为地(GND),3号引脚为输出(OUTPUT),4号引脚为电源(VDD)。
参数特性: - 频率范围:1MHz至54MHz - 输出类型:CMOS - 频率容差:±10ppm, 20ppm或指定 - 输出负载:15pF - 工作温度范围:-40°C至+85°C或-40°C至+125°C - 存储温度范围:-55°C至+125°C - 频率随温度变化特性:+20ppm, 30ppm, ±50ppm或指定 - 电压变化最大值/最小值:VOH=90%Vdd/VOL=10%Vdd - 占空比:45%至55% - 启动时间:最大3ms - 上升时间/下降时间:最大4ns - 供电电流:见下表
功能详解:YSO110TR WideVoltage晶体振荡器具有超小型SMD封装,适用于需要密封晶体振荡器单元的应用。
应用信息:适用于工业控制、物联网(IOT)等。
封装信息:提供多种尺寸的封装,包括1.6x1.2mm、2.0x1.6mm、2.5x2.0mm、3.2x2.5mm、5.0x3.2mm、7.0x5.0mm等。
OT8ED8K5JI-111YXC-100M 价格&库存
很抱歉,暂时无法提供与“OT8ED8K5JI-111YXC-100M”相匹配的价格&库存,您可以联系我们找货
