XL3ED8K5MI-111YXC-32M 数据手册
CRYSTAL UNIT
YSX221SL
Applications
Small Size
Features
‧SmartWearable
‧Dimensions:2.55 x 2.05 x 0.55 mm.
‧High precision and high frequency stability.
IOT Communication.
‧Standard Frequency: 12 to 54MHz
‧Excellent heat resistance and environmental
characteristics.
Specifications
12 to 54 MHz
Standard Frequency
Vibration Mode
AT Fundamental
8pF,10pF, 20pF, or specify
Load Capacitance
Frequency Tolerance (at 25 ℃)
±10ppm, ±20ppm, or specify
Frequency Versus Temperature Characteristics
Operating Temperature
±20ppm, or specify
-20~+70℃,-40~+85℃,or specify
Storage Temperature
-40~+85℃ or specify
Shunt Capacitance
3 pF Max.
1~200μWMax. (100uW typical)
Level of Drive
Aging (at 25 ℃)
±3ppm/year Max.
Equivalent Series Resistance(ESR)
Fundamental
12 ~ 14 MHz
14 ~ 30 MHz
30 ~ 48 MHz
48 ~ 54 MHz
150 Ω Max.
100 Ω Max.
60 Ω Max.
50 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
2.5±0.05
2 .0 5±0 .05
4
3
4
GND
3
Marking
GND
2
1
To p V i ew
2
0. 55 ± 0. 0 5
1
S i d e Vi e w
1.0
0. 85 1 . 0
0 .9
0. 9
2
4
B o t t om Vi e w
0.9
0.7
0.65
1
To p V i e w C r y s t al C o n n e ct io n
To p V i e w S u g g e s t e d L a y o ut
3
www.yxcxtal.com
CRYSTAL UNIT
YSX221SL
Small Size
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-2520
180±2.0
8.0±0.3
2.70±0.1
2.25±0.1
4.0±0.1
1.05±0.1
61.0±1.0
8.0±1.0
3000 pcs per reel
www.yxcxtal.com
XL3ED8K5MI-111YXC-32M 价格&库存
很抱歉,暂时无法提供与“XL3ED8K5MI-111YXC-32M”相匹配的价格&库存,您可以联系我们找货
