X-PUTTY-900
X-PUTTY-900
    SHIULI(旭立)
    热敏式 硅油灰 900 克容器
X-PUTTY-900 数据手册
X-putty Thermal Conductive Putty LiPOLY X-putty is a one-part dispensable material with thermal conductivity 3.0W/m*K. High deformation can fill small air gaps perfectly to remove tolerance. It also can overcome overflow and drying problems to increase the thermal conductivity. X-putty is a great alternative to thermal grease and ideally suited for dispensing using the dispensing robot. FEATURES / Thermal conductivity:3.0 W/m*K / Bond line thickness:100-3000µm / Designed to remove manufacturing tolerances / Does not produce stress on delicate components / No vertical flow / Dispensable for serial manufacture / For any high compression and low stress application TYPICAL APPLICATION / Between CPU and heat sink / Between a component and heat sink / High speed mass storage drives / Telecommunication hardware / Flat-panel displays / Set-top box / IP CAM CONFIGURATIONS / Cartridges: 30ml, 55ml, 330ml / Bucket: 1kg, 25kg PRESERVATION It can be preserved for 60 months under the condition of unopened and under room temperature 25℃ TYPICAL PROPERTIES X-putty TEST METHOD UNIT Gray Visual - Silicone - - 17000 DIN 53018 Pa.s 2.8 ASTM D792 g/cm³ -60~180 - °C Bond line thickness 100~3000 - μm Shelf life 60 months - - ROHS & REACH Compliant - - 12 ASTM D149 KV/mm >10¹³ ASTM D257 Ohm-m 3.0 ASTM D5470 W/m*K Thermal impedance@10psi 0.110 ASTM D5470 °C-in²/ W Thermal impedance@30psi 0.080 ASTM D5470 °C-in²/ W Thermal impedance@50psi 0.075 ASTM D5470 °C-in²/ W PROPERTY Color Resin base Viscosity Density Application temperature ELECTRICAL Dielectric breakdown Volume resistivity THERMAL Thermal conductivity VERTICAL RELIABILITY Using 3.0mm pad as a gap control, put the putty between the aluminum and the glass panel mark the initial position. Then, place it in the oven with 125℃ for 1,000 hours and observe its displacement after reliability test. X-putty X-putty Base Line Material no dropped or changed after high temperature aging testing Note: All specifications provided by LiPOLY are subject to change without notice. The test methods used by LiPOLY are based on the TIM Tester method and ASTM D5470 test method. These test methods are used as the definition standards for LiPOLY. Property values provided in this document are not for product specifications or guaranteed. This document does not guarantee the performance and quality required for the purchaser’s specific purpose. The purchaser needs to evaluate and verify the safety before using the material. We strongly recommend the purchaser pre-test the product and verify the performance of the product under the purchaser’s specific conditions. Liability and use of the product are the responsibility of the end user. LiPOLY makes no warranty as to the suitability, merchantability, or non-infringement of any LiPOLY material or product for any specific or general uses. LiPOLY shall not be liable for incidental orconsequential damages of any kind. All LiPOLY products are sold in accordance with the LiPOLY Terms and Conditions in effect at the time of purchase and a copy of which will be furnished upon request. All rights reserved, including LiPOLY trademarks or registered trademarks of LiPOLY or its affiliates. Statements concerning possible or suggested uses made herein shall not be relied upon or be constructed as a guaranty of patent infringement. Copyright 2022 LiPOLY.
X-PUTTY-900 价格&库存
很抱歉,暂时无法提供与“X-PUTTY-900”相匹配的价格&库存,您可以联系我们找货
