6001123
    SIERRAWIRELESS
    2IN1 DOME ANTENNA - 2XLTE, BOLT
6001123 数据手册
AirLink Antenna Datasheet EMBEDDED MODULES HL SERIES Sierra Wireless AirLink® Antenna: 2-in-1 Dome AirLink® Antenna: 2-in-1 Dome The 2-In-1 low profile MiMo Dome has been tested and certified to operate with AirLink routers and gateways. The antenna enclosure contains two isolated high performance antenna elements spanning 698-2700MHz MIMO/diversity at LTE frequencies. The antenna in ground plane independent, and maintains a high level of performance even when mounted on a non-metallic surface. Specification PART NO. 6001123 ELECTRICAL DATA Frequency Rang Elements 1 & 2 698-960 / 1700-2700MHz Operational Bands Elements 1 & 2 2G/3G/4G LTE Peak gain: Isotropic Elements 1 & 2 Isolation* Elements 1 & 2 698-960MHz 2.3dBi 1710-2700MHz 5dBi > 15dB Correlation Co-efficient < 0.1 Polarisation Vertical Impedance 50Ω Max Input Power 25W MECHANICAL DATA Dimensions Height 62 mm (2.4”) Diameter 176 mm (6.7”) Operating Temp -22°/ 176°F (-30° / +80°C) Material ASA & Diecast Aluminum Colour White Ingress Protection IP66 Weight 1282g sierrawireless.com/airlink Sierra Wireless AIRLINK® ANTENNA: 6-IN-1 DOME MOUNTING DATA Mounting Type Bolt Mount Mounting hole 19mm (3/4”) CABLE DATA Cell / LTE Cables Type CS29 Length 5m (16ft) Termination SMA Plug *Measured with 5m (17’) of CS29 cable About Sierra Wireless Sierra Wireless is building the Internet of Things with intelligent wireless solutions that empower organizations to innovate in the connected world. We offer the industry’s most comprehensive portfolio of 2G, 3G, and 4G embedded modules and gateways, seamlessly integrated with our secure cloud and connectivity services. OEMs and enterprises worldwide trust our innovative solutions to get their connected products and services to market faster. For more information, visit www.sierrawireless.com. Sierra Wireless, the Sierra Wireless logo, AirLink, and the red wave design are trademarks of Sierra Wireless. Other registered trademarks that appear on this brochure are the property of the respective owners. © 2017 Sierra Wireless, Inc. 2017.05.15
6001123 价格&库存
很抱歉,暂时无法提供与“6001123”相匹配的价格&库存,您可以联系我们找货
