6001119
6001119
    SIERRAWIRELESS
    2.249GHz GNSS,LTE 面板 RF 天线 698MHz ~ 3.8GHz 面板安装
6001119 数据手册
AirLink Antenna Datasheet EMBEDDED MODULES HL SERIES Sierra Wireless AirLink® Antenna: 3-in-1 SharkFin AirLink® Antenna: 3-in-1 SharkFin Tested and certified to operate with AirLink routers and gateways, the 3-In-1 SharkFin has a compact OEM style housing that contains 2x2 MiMo antenna elements for 2G, 3G, and 4G LTE frequencies and an active antenna for GNSS with 26dB gain LNA. Specification PART NO. 6001119 ELECTRICAL DATA Frequency Range Elements 2 & 3 698-960, 1710-2170, 2500-3800MHz Operational Bands Elements 2 & 3 2G/3G/4G LTE Peak gain: Isotropic Elements 2 & 3 2dBi (698-960MHz), 5dBi (1710-3800MHz) Isolation with 4m/13’ CS29 Cellular >11dB Typical Efficiency w/o Cable Loss Elements 2 & 3 > 50% Correlation Co-efficient Elements 2 & 3 < 0.2 Polarisation Vertical Pattern Omni-directional Impedance 50Ω Max Input Power 25W MECHANICAL DATA Dimensions Total Height (excluding whip) 50mm (2.2”) Length 170mm (6.77”) Width 60mm (2.4”) Operating Temp -40° / +80°C (-40° / 176°F) Material ASA, EPDM, Aluminium Alloy Colour Black Weight 913g Ingress Protection IP 66 sierrawireless.com/airlink Sierra Wireless AIRLINK® ANTENNA: 3-IN-1 SHARKFIN GPS/GNSS DATA Frequency Range Specification Element 1 1562-1612MHz VSWR
6001119 价格&库存
很抱歉,暂时无法提供与“6001119”相匹配的价格&库存,您可以联系我们找货
