6001125
6001125
    SIERRAWIRELESS
    2.249GHz GNSS,LTE 面板 RF 天线 698MHz ~ 3.8GHz 面板安装
6001125 数据手册
AirLink Antenna Datasheet EMBEDDED MODULES HL SERIES Sierra Wireless AirLink® Antenna: 3-in-1 Panel AirLink® Antenna: 3-in-1 Panel The 3-In-1 Panel has been tested and certified to provide MiMo LTE antenna function for AirLink routers and gateways. The compact, robust low profile housing is ground plane independent, weatherproof and contains two antenna elements with effective isolation and correlation covering all current global cellular and LTE bands in freq. range 698-960/1710-3800MHz as well as an active GNSS antenna for applications which require position or timing function. Specification PART NO. 6001125 / 6001124 (without GNSS) ELECTRICAL DATA Frequency Range Peak gain: Isotropic* Elements 1 & 2 698-960 / 1710-3800MHz Element 3 1562-1612MHz Cellular 698-960MHz 1.5dBi 1710-2700MHz 4.5dBi 2500-3800MHz 5dBi Pattern Omni-directional Nominal Impedance 50Ω Max Input Power 20W GNSS DATA Frequency Range 1562-1612MHz LNA Gain 26dB Polarisation Right Hand Circular Operating Voltage 3-5VDC Current Typical
6001125 价格&库存
很抱歉,暂时无法提供与“6001125”相匹配的价格&库存,您可以联系我们找货
