6001197
6001197
    SIERRAWIRELESS
    2.249GHz,2.4GHz,5GHz GNSS,LTE,Wi-Fi 面板 RF 天线 698MHz ~ 3.8GHz 面板安装
6001197 数据手册
AirLink Antenna Datasheet EMBEDDED MODULES HL SERIES Sierra Wireless AirLink® Antenna: 6-in-1 SharkFin AirLink® Antenna: 6-in-1 SharkFin Tested and certified to operate with AirLink routers and gateways, the 6-in-1 SharkFin has a compact OEM style housing that contains 2x2 MiMo antenna function for 2G, 3G, and 4G LTE frequencies, an active antenna for GNSS with 26dB gain LNA and offers dual band 3x3 MiMo Wi-Fi (2.4/5.0GHz) in a compact package. Specification PART NO. 6001197 ELECTRICAL DATA Frequency Range Elements 2 & 3 698-960, 1710-2170, 2500-3800MHz Elements 4 & 5 2.4 / 4.9-6.0GHz Element 6 (Whip) 2.4 / 4.9-6.0GHz Operational Bands Peak gain: Isotropic* Isolation with 4m/13’ CS29 Elements 2 & 3 2G/3G/4G LTE Elements 4, 5 & 6 2.4/5GHz Wi-Fi Elements 2 & 3 2dBi (698-960MHz), 5dBi (1710-3800MHz) Elements 4, 5 &6 4dBi (2.4GHz), 6dBi (5.8GHz) Cellular > 11dB Wi-Fi > 19dB Typical Efficiency w/o Cable Loss Elements 2 & 3 > 50% Correlation Co-efficient Elements 2 & 3 < 0.2 Polarisation Vertical Pattern Omni-directional Impedance 50Ω Max Input Power 25W * Excluding cable loss sierrawireless.com/airlink Sierra Wireless AIRLINK® ANTENNA: 6-IN-1 SHARKFIN GPS/GNSS DATA Frequency Range Specification Element 1 1562-1612MHz VSWR
6001197 价格&库存
很抱歉,暂时无法提供与“6001197”相匹配的价格&库存,您可以联系我们找货
