6001111
6001111
    SIERRAWIRELESS
    2.4GHz,5GHz 蓝牙,Wi-Fi 鞭状,倾斜 RF 天线 连接器安装
6001111 数据手册
Sierra Wireless Antenna 4-in-1 SharkFin Sierra Wireless Antenna – 4-in-1 SharkFin Tested and certified to operate with AirLink routers and gateways, the 4-in-1 SharkFin has a compact OEM style housing that contains 2x2 MiMo antenna functions for 2G, 3G, and 4G LTE frequencies, an active antenna for GNSS with 26dB gain LNA and dual band Wi-Fi (2.4/5.0GHz) in a compact package. Specification PART NO. 6001198 ELECTRICAL DATA Frequency Range 3G/4G Elements 698-960, 1710-2170, 2500-3800MHz Wi-Fi Element 2.4 / 4.9-6.0GHz 3G/4G Elements 2dBi (698-960MHz) | 5dBi (1710-3800MHz) Wi-Fi Element 4dBi Isolation with 5m 16’ CS29 Cellular > 11dB Typical Efficiency w/o Cable Loss 3G/4G Elements > 50% Correlation Co-efficient 3G/4G Elements < 0.2 Peak gain: Isotropic Polarisation Vertical Pattern Omni-directional Impedance 50Ω Max Input Power 25W sierrawireless.com | All specifications subject to change without notice 1 Sierra Wireless Antennas DATASHEET DATASHEET – Antenna 4-in-1 SharkFin Specification GPS/GNSS DATA Frequency Range 1562-1612MHz VSWR
6001111 价格&库存
很抱歉,暂时无法提供与“6001111”相匹配的价格&库存,您可以联系我们找货
  • 1+123.671511+16.00799
