6001214
6001214
    SIERRAWIRELESS
    网络 支架 配用 AirLink LX60
6001214 数据手册
AirLink LX60 Datasheet Sierra Wireless EMBEDDED MODULES HL SERIES AirLink® LX60 Dual Ethernet LTE Router BENEFITS Ÿ Out-of-Box LTE Connectivity: Add LTE connectivity to your existing equipment Ÿ Enables edge processing with optional secure linux-based embedded application framework (ALEOS Application Framework) Ÿ Dual Ethernet, RS232 & RS485 and multiple I/O to connect to a wide variety of field equipment Ÿ LTE and LTE-M/NB-IoT variants for global deployments, and extended coverage and depth (in-building and below ground) to reach challenging locations Ÿ Integrated 7-36VDC industrial grade power supply and –30C to +65C temperature range to provide superior reliability without need for additional power conditioning or adapters Ÿ ALMS Cloud or AMM On-Premises Management single-pane device management across all devices Ÿ GNSS for fleets Dual Ethernet LTE Router, for Primary or Backup Connectivity The AirLink® LX60 is designed for Commercial and Enterprise LTE network connectivity. Dual Gigabit Ethernet and serial ports make it ideal to connect machines and provide primary or backup network connectivity. LX60 provides purpose-built, secure, reliable, managed Cellular LTE networking in Building Automation, Digital Signage, Taxis, ATMs, Kiosks and Point-of-Sale terminals. As part of the AirLink Essential series, the LX60 is designed to meet the environmental and performance requirements of these applications, while delivering superior reliability and uninterrupted operation in fixed, indoor and protected outdoor environments. LX60 is available with optional Wi-Fi + GNSS and rated for shock, vibration and vehicle power supplies. It offers Dual Band 802.11ac Wi-Fi and dedicated 48 Channel GNSS, meeting the demands of Commercial fleets and Taxis requiring connectivity. The LX60 comes in LTE Cat 4 regional variants, and a Global LPWA (Low-Power Wide Area) variant offering LTE-M/NB-IoT for applications where low data rates, enhanced cellular coverage and global deployment is required. Purpose-Built, Secure, Reliable, Managed Cellular LTE Networking IDEAL APPLICATIONS Primary or backup connectivity for: Ÿ IoT/M2M Ÿ WAN Failover Applications Ÿ Building Automation Ÿ Digital Signage Ÿ Taxis, Light Transport Vehicles Ÿ ATMs, Kiosks, Point of Sale, Lottery Application Example - Building Automation sierrawireless.com/LX60 AirLink® LX60 Dual Ethernet LTE Router LX60 Australia & New Zealand Global Cat-4 (WP7607) Up to 150 Mbps Cat-4 (WP7609) Up to 150 Mbps Cat-M1/NB1 (WP7702) Cat-M1: 300kbps Cat-NB1: 27kbps Up to 50 Mbps Up to 50 Mbps Cat-M1: 375kbps Cat-NB1: 65kbps 1900(B2), AWS(B4), 850(B5), 700(B12), 2100(B1), 1800(B3), 2600(B7), 700(B13), 700(B17), 1700(B66) 900(B8), 800(B20), 700(B28) 2100(B1), 1800(B3), 850(B5), 2600(B7), 900(B8), 700(B28) 2100(B1), 1900(B2), 1800(B3), AWS(B4), 850(B5), 900(B8), 700(B12), 700(B13), 700(B17), 850 (B18), 850(B19), 800(B20), 850(B26),700(B28) 1900(B2), AWS(B4), 850(B5) 2100(B1), 850(B5), 900(B8) North America EMEA LTE CATEGORY Peak D/L Cat-4 (WP7610) Up to 150 Mbps Peak U/L Up to 50 Mbps 4G LTE Frequency Bands 3G WCDMA/HSPA+ LTE Frequency Bands 2G GSM/GPRS 2100(B1), 900(B8) LTE-M/NB-IoT 900, 1800 Frequency Bands 850, 900, 1800, 1900 APPROVALS Regulatory Carrier FCC, IC, PTCRB PART NUMBER 1104580 1104572 (Wi-Fi + GNSS) 1104493 (Wi-Fi + GNSS + Telemetry) HOST INTERFACES GCF, CE Verizon, AT&T 1104046 1104047 (Wi-Fi + GNSS) GCF, RCM FCC, IC, PTCRB, GCF, CE Planned: Telstra Verizon (Cat-M1), AT&T (Cat-M1) 1104048 1104049 (Wi-Fi + GNSS) 1104030 Specification 2 Gigabit RJ-45 Ethernet ports SECURITY RS-232 serial port (DB-9) Inbound and Outbound Trusted IP 3 SMA antenna connectors (cellular, diversity, GNSS) MAC Address Filtering 1 SMA for LTE-M version PCI compatible 1 RP SMA antenna connector (Wi-Fi) Secure Firmware Update Active GNSS antenna support SATELLITE NAVIGATION GNSS (OPTIONAL) Aux Port (RS-485/GPIO) Accuracy: < 1.5m (50%), < 3.15m (95%) Support for 10 clients, WPA2 Enterprise Acquisition Time: 1s Hot Start Output power 16dBm Reports: NMEA 0183 V3.0, TAIP, RAP, XORA Access Point or Client Mode (Wi-Fi as WAN) Multiple Redundant Servers Reliable Store and Forward Single SSID Support Captive Portal LAN (ETHERNET/USB) Configurable I/O (5 pins total) Ÿ 5 Digital Inputs: ON Voltage: 2.7 to 36 VDC Ÿ 1 Digital Open Collector Output > sinking 300 mA Ÿ 3 Analog Inputs: 0.5-5/0.5-10 VDC (range selectable) Ÿ Configurable Pull-ups for dry contact input NETWORK MANAGEMENT Secure mobile network & asset management application available in the cloud or licensed platform in the enterprise data center Fleet wide firmware upgrade delivery Router configuration and template management Router staging over the air and local Ethernet connection DHCP Server Over-the-air software and radio module firmware updates IP Passthrough Device Configuration Templates VLAN Configurable monitoring and alerting Host Interface Watchdog Remote provisioning and airtime activation (where applicable) PPPoE SERIAL Dedicated GNSS Receiver supporting GPS, GLONASS, BeiDou, Galileo Tracking Sensitivity: -162 dBm Dual Band 2.4/5GHz Wi-Fi 802.11 b/g/n/ac (Wave2 Client Mode) INPUT/OUTPUT Remote Authentication (LDAP, RADIUS, TACACS+) DMZ Inbound and Outbound Port filtering USB 2.0 Micro-B Connector WI-FI (Optional) Specification EVENTS ENGINE TCP/UDP PAD Mode Event Types: Digital Input, Network Parameters, Data Usage, Timer, Power, Device Temperature and Voltage Report Types: RAP, SMS, Email, SNMP Trap, TCP (Binary, XML, CSV) PPP DNP3 Interoperability NETWORK AND ROUTING Network Address Translation (NAT) Custom event triggers and reports Configurable interface, no programming Modbus (ASCII, RTU, Variable) Ethernet WAN Port Forwarding Verizon PNTM NEMO/DMNR IPv6 Gateway VRRP Policy Routing Reliable Static Route Dynamic DNS Event Actions: Drive Relay Output ENVIRONMENTAL Operating Temperature: -30°C to +65°C / -22°F to +149°F Storage Temperature: -40°C to +85°C / -40°F to +185°F Humidity: 90% RH @ 60°C Military Spec MIL-STD-810G conformance to shock, vibration, thermal shock, and humidity IP20 rated ingress protection AirLink® LX60 Dual Ethernet LTE Router Specification VPN IPsec, GRE, and OpenVPN Client INDUSTRY CERTIFICATIONS Up to 5 concurrent tunnels Split Tunnel Dead Peer Detection (DPD) ROUTER MANAGEMENT AT Command Line Interface (Telnet/SSH/Serial) Environmental: RoHS2, REACH, WEEE SUPPORT AND WARRANTY SMS Commands APPLICATION ALEOS Application Framework (AAF) Direct 24/7 Technical Support 3-year standard warranty; optional 2-year warranty extension 1-day Accelerated Hardware Replacement available through participating resellers Ÿ Input Voltage: 7 to 36 VDC Low voltage disconnect to prevent battery drain Built-in protection against voltage transients including 5 VDC engine cranking Ignition Sense with time delay shutdown DIMENSIONS Includes 1st Year AirLink Complete: AirLink Management Service (ALMS) Ÿ Ÿ LUA Scripting Language POWER Safety: IECE Certification Bodies Scheme (CB Scheme), UL 60950 Vehicle Usage: ISO7637-2, SAE J1455 (Shock, Vibration, Electrical) Environmental: RoHS2, REACH, WEEE Hazardous Environments: Class 1 Div 2 - Ambient temperatures of -30°C to +60°C Local web user interface SNMP Specification ACCESSORIES 146 mm x 42 mm x 100 mm (106 mm including connectors) 5.74 in x 1.65 in x 3.93 in (4.17 in including connectors) In the box: DC Power Cable and Quick Start Guide Other Accessories (sold separately): 2000579 AC Adapter, 12VDC 6001110 Cellular Paddle Antenna 6001111 Wi-Fi 2.4/5Hz Paddle Antenna 250g (weight) 6001214 DIN Rail Bracket *For carrier specific band support please refer to the hardware user guide. 6001231 Panel Antenna (LPWA) For Antenna options visit: sierrawireless.com/antennas AirLink Networking Solution - Related Products DIMENSIONS AIRLINK NETWORK MANAGEMENT SOLUTIONS AIRLINK MANAGEMENT SERVICE (ALMS) Ÿ Secure, Cloud-based network and asset management Ÿ Remotely deploy, configure, monitor and manage AirLink devices Ÿ Carrier-grade, high availability, secure, global infrastructure AIRLINK MANAGER / MOBILITY MANAGER (AM/AMM) Ÿ Deployable in the enterprise data center (on-premises) or in the cloud Ÿ Advanced, end-to-end network and asset management for both fixed and mobile networks. Ÿ Remote, real-time configuration, control and troubleshooting of AirLink devices AIRLINK VPN APPLIANCE AIRLINK CONNECTION MANAGER Contact USAT 605 Eastowne Drive Chapel Hill, NC 27514 Phone: Email: Web: (888) 550-8728 info@usatcorp.com https://usatcorp.com Ÿ VPN appliance built from the ground up for Airlink routers & gateways Ÿ Simplify deployment and management of your VPN solution, extending the enterprise to the network edge for fixed and mobile endpoints Ÿ Carrier agnostic – ACM doesn’t require fixed and/or public IP Ÿ Compatible with FIPS 140-2, and always-on VPN capability About Sierra Wireless Sierra Wireless is building the Internet of Things with intelligent wireless solutions that empower organizations to innovate in the connected world. We offer the industry’s most comprehensive portfolio of 2G, 3G, and 4G embedded modules and gateways, seamlessly integrated with our secure cloud and connectivity services. OEMs and enterprises worldwide trust our innovative solutions to get their connected products and services to market faster. For more information, visit www.sierrawireless.com. Sierra Wireless, the Sierra Wireless logo, AirPrime, and the red wave design are trademarks of Sierra Wireless. Other registered trademarks that appear on this brochure are the property of the respective owners. © 2020 Sierra Wireless, Inc.
6001214
物料型号:AirLink LX60 器件简介:Sierra Wireless AirLink LX60 是一款双以太网LTE路由器,提供LTE网络连接,适用于商业和企业级应用。
引脚分配:具有2个千兆RJ-45以太网端口、RS-232串行端口(DB-9)、USB 2.0 Micro-B连接器、3个SMA天线连接器(蜂窝、分集、GNSS)、1个RP SMA天线连接器(Wi-Fi)。
参数特性:支持LTE Cat 4和全球LPWA(低功耗广域网)变体,提供LTE-M/NB-IoT,适用于低数据速率、增强的蜂窝覆盖和全球部署。
功能详解:具备集成的7-36VDC工业级电源和-30°C至+65°C的温度范围,提供卓越的可靠性,无需额外的电源调节或适配器。
应用信息:适用于物联网/机器对机器(M2M)、广域网(WAN)故障转移应用、楼宇自动化、数字标牌、出租车、轻型运输车辆、自动柜员机(ATM)、自助服务亭、彩票销售点等。
封装信息:尺寸为146mm x 42mm x 100mm,重量为250克,符合MIL-STD-810G标准,适用于震动、热冲击和湿度环境,IP20等级的防护。
6001214 价格&库存
很抱歉,暂时无法提供与“6001214”相匹配的价格&库存,您可以联系我们找货
