TCI-HL78-2153
TCI-HL78-2153
    SIERRAWIRELESS
    SOCKET ADAPTER FOR HL7800
TCI-HL78-2153 数据手册
10 9 6 7 8 3 4 5 REV 01 1 2 DESCRIPTION ECO DATE Prototype release DRAWN 17 OCTO 17 JPM APPD PYK H H A DETAIL A SCALE 10,000 4x CH. 0,80 x45° 0,20 SEE DETAIL 1,10 G A 0,10 5° 5° x4 60 0, B 4x 0,30 0,20 . 1,20 X R E 0 15,150 0,20 0,05 2 1, C D 17,30 80 0, R X 0,05 C 22,050 D 20,30 8x E C-C F CH SECTION 1,20 B 0,40 . CH X 1,20 F 0,05 X 23,050 0, 30 x4 0,10 A-A 2,60 SECTION G C C 18,150 0,05 X 4x n1,60 X A TOP VIEW BOTTOM VIEW SCALE 5,000 B B UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE PER THE FOLLOWING TOLERANCES: INCHES .X # .05 .X .XX # .01 .XX .XXX # .005 .XXX A UNLESS OTHERWISE NOTED, THIS DOCUMENT CONTAINS SIERRA WIRELESS CONFIDENTIAL INFORMATION. REPRODUCTION, USE, DISCLOSURE OR TRANSMITTAL OF ALL OR ANY PORTION OF THIS DOCUMENT IS PROHIBITED, EXCEPT TO THE EXTENT APPROVED BY SIERRA WIRELESS. SIERRA WIRELESS EXPRESSLY RESERVES ALL RIGHTS UNDER PATENTS, TRADEMARKS, COPYRIGHTS AND TRADE SECRETS. COPYRIGHT (C) 2011, SIERRA WIRELESS. 9 8 MATERIAL MM # # # PROJECT NAME CF3-V2 ANGLES .25 X # 5 $ .13 X.X # 1 $ .05 DRWN 17-10-12 JPM 17-10-12 PYK 17-10-12 DATE PRT FILENAME INTERPOSER_REV1_ SEE NOTE DRW FILENAME INTERPOSER_REV1_ DO NOT SCALE PRINT 5 RELEASE LEVEL PROI_RELEASE 4 13811 Wireless Way Richmond, British Columb Canada, V6V 3A4 Tel: 604.231.1100 A Fax: 604.231.1109 DATE CHK FINISH 6 DATE 0 DES ENGR SEE NOTE 7 PART DESCRIPTION 3 PROI_VERSION SIZE UNITS C MM SCALE: 5,000 DRAWING NO. 530xxxx 2 REV SHEET 1 OF 2 1 01 I NOTES APPLICABLE TO PART MANUFACTURER 1. DESCRIPTION AND APPLICATION: 2. APPLICABLE DOCUMENTS: RF SHIELD TO BE USED IN WIRELESS DEVICE ASME Y14.5M-1994 GEOMETRIC DIMENSIONING AND TOLERANCING EIA 432-2 16mm, 24mm, 32mm, 44mm & 56mm PUNCHED AND EMBOSSED CARRIER TAPING OF SURFACE MOUNT COMPONENTS FOR AUTOMATIC HANDLING 3. 3.1 3.2 3.3 3.4 MATERIAL: TBD THICKNESS: N/A PLATING: NONE COMPLETE TOOL DRAWINGS TO BE SUBMITTED TO SIERRA WIRELESS MECHANICAL ENGINEERING GROUP FOR APPROVAL. 3.5 PART/ASSEMBLY SHALL CONTAIN NO HAZARDOUS SUBSTANCES PER RoHS DIRECTIVE 2011/65/EU. 3.6 PART/ASSEMBLY SHALL CONFORM TO REACH REGULATION (EC) 1907/2006. 3.7 PART/ASSEMBLY WASTE DISPOSAL CONTROL SHALL CONFORM TO WASTE ELECTRICAL AND ELECTRONIC EQUIPMENT DIRECTIVE 2012/19/EU (WEEE). 3.8. PART SHOULD BE FREE OF ALL LUBRIFICATION OILS THAT MAY INPIDE SOLDERABILITY 3.9. PART SHALL CONFORM TO THE FOLLOWING SOLDERABILITY REQUIREMENTS AS DELIVERED: J-STD-002A STEAM AGING CATEGORY 3 AND SOLDERABILITY TEST B. 4. MECHANICAL REQUIREMENTS: 4.1 4.2 4.3 4.4 4.5 4.6 5. 5.4 5.5 7. e r i l P i m PARTS SHALL BE PACKAGED IN TAPE & REEL PACKAGING PER EIA ORIENTATION OF PART IN TAPE AND REEL TO BE AS SHOWN. EXCEPTIONS: 7.1 r o f Q ALL DIMENSIONS INDICATED ON DRAWING ARE CRITICAL TO FORM, FIT, OR FUNCTION. DIMENSIONS INDICATED WITH A X SYMBOL DENOTE QUALITY PROCESS CONTROL, (QPC), DIMENSIONS. QUALITY ASSURANCE PLAN: 5.3.1 THE SUPPLIER MUST DEVELOP A QUALITY ASSURANCE PLAN TO ENSURE CRITICAL PARAMETER COMPLIANCE. THE PLAN MUST BE SUBMITTED TO SIERRA WIRELESS FOR REVIEW. 5.3.2 THE SUPPLIER MUST MAINTAIN STATISTICAL PROCESS CONTROL, (SPC), OR 100% INSPECTION ON X PARAMETERS. 5.3.3 PRODUCTION LOT SAMPLES MUST DEMONSTRATE A CPk VALUE OF 1.33 OR HIGHER. IF THE CPk DROPS BELOW 1.33 AT ANY TIME DURING THE MANUFACTURE OF THIS PART, THEN THE SUPPLIER MUST 100% SCREEN ALL THOSE SPECIFIED CRITICAL PARAMETERS. FIRST ARTICLE: 5.4.1 FIRST ARTICLE VERIFICATION IS REQUIRED PRIOR TO INITIAL TOOL APPROVAL OR APPROVAL OF A TOOLING CHANGE. FIRST ARTICLE SHALL BE VERIFIED BY A RUN OF AT LEAST 100 PIECES UNDER CONDITIONS REPRESENTATIVE OF PRODUCTION. A DIMENSIONAL REPORT MUST BE SUBMITTED TO SIERRA WIRELESS ALONG WITH THE MEASURED PARTS. DIMENSIONAL REPORT: 5.5.1 CRITICAL PARAMETER CONFORMANCE MUST BE DEMONSTRATED BY INSPECTION OF AT LEAST 30 PIECES FROM THE FIRST ARTICLE RUN. ALL DIMENSIONS MUST BE MEASURED ON AT LEAST 5 PARTS OF THE FIRST ARTICLE RUN. A DIMENSIONAL REPORT MUST BE SUBMITTED TO SIERRA WIRELESS ALONG WITH THE MEASURED PARTS. PACKAGING: 6.1 6.2 y r a n QUALITY ASSURANCE REQUIREMENTS: 5.1 5.2 5.3 6. CONTROLLING GEOMETRY IS DEFINED BY THE 3D PRO/ENGINEER DATABASE. ALL SURFACES TO BE WITHIN 0.13mm OF DATABASE UNLESS OTHERWISE SPECIFIED. WHEREVER A CONFLICT EXISTS BETWEEN THE DRAWING AND THE DATABSE, THE DRAWING SHALL TAKE PRECEDENCE. DIMENSIONING AND TOLERANCING PER ASME Y14.5M-1994 A REFERENCE DIMENSION IS USED FOR INFORMATIONAL PURPOSES ONLY AND HAS NO TOLERANCE. IT IS DESIGNATED BY: (XX.XX). MAXIMUM BURR HEIGHT: 0.05mm 20% OF MATERIAL THICKNESS. NO LOOSE BURRS PERMITTED. ALL INSIDE BEND RADII NOT SHOWN SHALL BE 0.05mm. GRAIN DIRECTION SHALL BE AS SPECIFIED. e t o u MATERIAL AND TOOLING REQUIREMENTS: 432-1 OR 432-2. NO CHANGE SHALL BE ALLOWED ON PRODUCTION MATERIAL, REGARDLESS OF CHANGE AFFECTS REQUIREMENTS SPECIFIED, WITHOUT PRIOR EXPLICIT BY SIERRA WIRELESS MECHANICAL ENGINEERING GROUP. WHETHER SUCH WRITTEN APPROVAL UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE PER THE FOLLOWING TOLERANCES: INCHES .X # .05 .X .XX # .01 .XX .XXX # .005 .XXX MATERIAL MM # # # ANGLES .25 X # 5 $ .13 X.X # 1 $ .05 PROJECT NAME CF3-V2 DRWN FINISH SEE NOTE DO NOT SCALE PRINT DATE &DRAWN_BY:D 17-10-12 JPM 17-10-12 PYK 17-10-12 DES ENGR CHK SEE NOTE PART DESCRIPTION PRT FILENAME DATE model_name:180 DRW FILENAME INTERPOSER_REV1_ RELEASE LEVEL PROI_RELEASE 13811 Wireless Way Richmond, British Columb Canada, V6V 3A4 Tel: 604.231.1100 Fax: 604.231.1109 DATE PROI_VERSION SIZE UNITS C MM SCALE: DRAWING NO. 530xxxx REV SHEET 2 OF 2 01
TCI-HL78-2153 价格&库存
很抱歉,暂时无法提供与“TCI-HL78-2153”相匹配的价格&库存,您可以联系我们找货
