EM DEV KIT_6001173
EM DEV KIT_6001173
    SIERRAWIRELESS
    EM - AirPrime® EM 蜂窝式开发平台 评估板
EM DEV KIT_6001173 数据手册
M.2 Development Kit Kit Contents • • • • • • • • • (1) M.2 development kit printed circuit assembly (2) Ultra-wideband 4G dipole swivel terminal antennas (6) RF cables—MHF4 micro coaxial cables (3 for Main/AUX/GNSS, 3 spares) (1) MHF4L connector push/pull tool (1) USB cable (Type A to micro-B 3.0) (1) AC wall adapter power supply and international plug kit (1) micro-SIM to SIM adapter (2) Thermal pads (1 to install on heat shield, 1 spare). Pad type: 29.0 x 39.5mm TENNVAC GP5000 (2) M2x3 Phillips head module screws (1 to install module, 1 spare) Module Insertion 1. 2. Remove backing from the thermal pad (both sides), and position the thermal pad on the heat sink. Insert the module as shown. (Insert at a 25º angle, rotate down, and push fully into the connector.) ß à ROTATE á LEAD-IN ä EXTRACT ã PUSH RISE UP 25° â MATE HOW TO MATE (INSTALL) AND EXTRACT MATE: EXTRACT: 3. ß ã â ä Secure the module with an M2 screw. SIM Card Connection 1. 2. Slide the SIM card into CN202 (top left corner of the PCB), noting the location of the notched corner. (If ESIM is enabled, DO NOT use a SIM in CN202.) If supporting dual SIMs, insert a second SIM card into CN206. Power Source Selection Connector CN101 (PWR IN SELECT) © 2015 Sierra Wireless. All rights reserved. 2400430, Rev. 1 Jump Description Connector(s) to use Pins 1 & 2 Power provided by barrel jack (AC adapter) CN103 Pins 3 & 4 Power provided by banana jack (3.125–4.4VDC) Disable on-board LDO CN114 (VCC) & CN116, or CN115 (VCC_MODULE) & CN116 Pins 5 & 6 Power provided by USB cable CN105 13811 Wireless Way Richmond, BC Canada, V6V 3A4 Main +1 604 231 1100 Fax +1 604 231 1109 www.sierrawireless.com Switch Settings Switch Position Default SW100 1 Off 3.0V 2 On 3.3V 3 Off 3.6V 4 Off 4.2V 1 Off SIM DETECT 1 On=Ignore SIM 1 Detect; Off=Normal mode 2 Off SIM DETECT 2 On=Ignore SIM 2 Detect; Off=Normal mode 3 Off ESIM ENABLE On=Enable ESIM; Off=Disable ESIM (Note: Leave switch in OFF position; ESIM is not populated.) 4 Off W_Disable1_N On=Set to logic low; Off=Set to logic high 5 Off W_Disable2_N On=Set to logic low; Off=Set to logic high 6 Off DPR On=Set to logic low; Off=Set to logic high 7 Off SIM2 DISABLE On=Disable SIM 2; Off=Enable SIM 2 8 On Power ON On=Enable module; Off=Disable module 9 On Enable 1.8V—VCC Module On=Enable 1.8V; Off=Disable 1.8V 10 Off NC SW200 SW201 Operation Button switch Description Select voltage for EM module (When selected power source is barrel jack or USB cable) Not connected Reset Module Test Points Connector CN207 Pin # Description 1 NC 2 Connector CN208 Pin # Description 1 NC POWER_OFF 2 GND 3 NC 3 VBAT 4 W_DISABLE_N 4 NC 5 NC 5 PCM_CLK 6 W_DISABLE2_N 6 UIM1_DET 7 VBAT 7 PCM_DIN 8 WAKE_ON_WWAN_N 8 RESET_N 9 UIM2_RST 9 PCM_OUT 10 UIM1_CLK 10 WWAN_LED 11 UIM2_CLK 11 PCM_SYNC 12 UIM_RST 12 I2C_DATA 13 UIM2_DATA 13 NC 14 UIM_DATA 14 ANT_CTL0 15 UIM2_VCC 15 NC 16 UIM_VCC 16 ANT_CTL1 17 COEX3 17 UIM2_DET 18 DPR 18 ANT_CTL2 19 UART_RXD 19 I2C_CLK 20 UART_TXD 20 ANT_CTL3
EM DEV KIT_6001173 价格&库存
很抱歉,暂时无法提供与“EM DEV KIT_6001173”相匹配的价格&库存,您可以联系我们找货
EM DEV KIT-6001173
  • 1+4068.395161+526.99946
库存:10
