Lighting Transformer (LT Series)
The compact LT Transformer components offer Safety Extra Low
Voltage (SELV) outputs designed for industries and OEM installations
of landscape, track, recessed and LED lighting, as well as security
systems, in the commercial, consumer and industrial sectors.
When SELV outputs are required to operate control equipment
and other electronic devices, a step-down transformer is needed to
convert from 120V or 277V to 12V. Offering a safer work environment,
the SELV isolation provided by Signal’s LT Transformer Series eliminates potential
shock hazards. The LT277-50-12 is ideal for 480V, 3 phase 4-wire systems, where line
voltage to neutral is equal to single phase 277V 50/60 Hz. The LT120-50-12 is designed
for single phase 120V 50/60 Hz supplies.
Features
Applications & Industries
• UL recognized to North American Harmonized standards:
UL5085-1-2 and CSA C22.2 No. 66
• Easy to mount and can be hardwired via standard
1/2" conduit hardware and a straight box connection
• Corrosion-resistant surface coating that is
environmentally resilient
• Insulation: Class B (130°C) UL 1446
• Lead Wire Connections: 18AWG UL 1015
• Rugged construction at a reasonable price
• OEM installations of landscape, track, recessed and
LED lighting
• Security systems in the commercial, consumer and
industrial sectors
Part No.
VA
Primary Rating
Secondary Rating
LT277-50-12
50
277V, 50/60 Hz
12V @ 4.17 A
LT120-50-12
50
120V, 50/60 Hz
12V @ 4.17 A
W
VA
Size
L
H
LW
Inches (mm)
2.60 (66)
50
2.18 (55.3)
3.10 (78.7)
6.0 (152)
Weight
lbs. (kg)
1.7 (.77)
LW
GRY
WHT
L
PRI
SEC
120V or
12V
277V INPUT
OUTPUT
277V BLUE
120V BLACK
W
H
Custom versions available upon request.
ORN
RoHS
Compliant
© 2020 Signal Transformer Inc. Specifications subject to change without notice. 04.20
128 Atlantic Avenue, Lynbrook, NY 11563
Toll Free 866-239-5777 | Tel 516-239-5777 | Fax 516-239-7208
sales@signaltransformer.com | techhelp@signaltransformer.com
belfuse.com/signal
很抱歉,暂时无法提供与“LT277-50-12”相匹配的价格&库存,您可以联系我们找货
