92-6115-US
92-6115-US
    SIMCO-ION
    电离器,风枪 台式,壁式安装 120VAC
92-6115-US 数据手册
W W W . S I M C O - I O N . C O M Ionization Solutions TM AirForce Ionizing Blow-off Gun MODEL 6115 The Simco-Ion AirForce Ionizing Blow-off Gun was designed with the operator in mind. The AirForce’s lightweight, flexible air hose—just 3/8” in diameter—moves with the operator and makes work easier. No high voltage cable means improved operator safety. The gun’s ergonomic design—with a light touch trigger and easy-view LED—minimizes fatigue and eliminates wrist hyperextension. The compact console can be mounted anywhere, so it doesn’t take up valuable workspace but is still easily accessible. To make the work environment more pleasant, the AirForce also features low audible noise. Strong blow-off power makes the AirForce effective in removing particle contamination and ideal for use in clean process applications. The 6115 is the only gun product rated at ISO 14644 Class 4 cleanliness (Fed. Std. 209e Class 10 equivalent). Steady-state DC ion emission provides efficient ionization with an average discharge time of less than 1.0 second. Results are even better because Simco-Ion IsoStat technology means the static charge is controlled with constantly balanced ionization. Features Benefits • Ergonomic gun design • Reduces fatigue and wrist hyperextension • Flexible, lightweight air hose with integral low voltage power cable • Moves with the operator and does not interfere with work • Replaceable emitter point assembly and quickeject filter • Minimizes maintenance downtime • Strong blow-off force • Effective removal of particle contamination • Steady-state DC ion emission • Fast discharge times; efficient ion delivery • IsoStat® technology • Intrinsically balanced; no calibration needed • Durable static-dissipative materials • Holds up to high impact; ESD-safe • ISO 14644 Class 4 cleanliness operation • Suitable for use in cleanroom applications for semiconductor, medical and HDD applications High Reliability Specifications Discharge ±1000-100V 1.0 sec @ 6” (15.2 cm), 30 psi Balance ±30V Cleanroom Class Meets ISO 14644 Class 4 (Fed Std. 209E Class 10) Console Power 24 VAC, 10W powered from wall transformer Indicators Green on both console and gun Ion Emission Steady-state DC Emitters Tungsten emitter points Audible Noise 70 dBA @ 1m, 30 psi Conducted EMI 29 dbµV; average level 100 KHz to 1.1 MHz Ozone
92-6115-US 价格&库存
很抱歉,暂时无法提供与“92-6115-US”相匹配的价格&库存,您可以联系我们找货
92-6115-US
    • 1+15122.281011+1955.52067
