W W W . S I M C O - I O N . C O M
Ionization Solutions
Wide Performance
Ionizing Blower
AEROSTAT® FPD
The Aerostat FPD series of products has been designed to control electrostatic charges in flat panel assembly
and electronics manufacturing applications requiring stable operation with exceptionally fast discharge time
performance. The FPD ionizing blowers are built for reliability and simplicity.
Aerostat FPD utilizes reliable, low maintenance AC corona technology with high flow rate fans to provide
fast static discharge performance. The inherent stability of the Aerostat FPD reduces maintenance frequency
and a built-in emitter cleaner reduces maintenance time. Our unique geometry and airflow control provides
consistent performance, meeting the demands of product assembly operations.
The Aerostat FPD’s self-monitoring feature assures the user of controlled, consistent ion output. A light
indicates both that power is applied to the unit and that ions are being produced. Performance is enhanced
by the use of Simco-Ion’s industry-leading and highly reliable AC technology.
Features
Benefits
• High output, high-velocity fans
• Extremely fast static charge neutralization over a wide
horizontal or vertical application area
• Inherently balanced ionization
• Offers consistent performance with low maintenance
frequency
• Ionization indicator light
• Visual indication that the target product is being
neutralized
• Built-in emitter point cleaner
• Continued blower operation will require little maintenance
• Optional fan air filter
• Protection for internal components from environmental
contamination
FPD Coverage Areas
Specifications
The Aerostat FPD ionization blower comes in either 2-fan, 3-fan or
4-fan chassis lengths. Each length is designed for optimal coverage
area and a variety of applications:
Input Voltage
120 VAC, 60 Hz: 0.3A (2-fan); 0.4A (3-fan); 0.5A (4-fan)
230 VAC, 50 Hz: 0.2A (2-fan); 0.2A (3-fan); 0.3A (4-fan)
Balance
0 ±10V
Discharge
1.0 sec @ 1’ (0.3 m) center blower position; fan high(1000-100V)1
Blower
Overhead Applications
Benchtop Applications
Switch
ON/OFF switch
2-fan
2’ W x 2’ L (0.6m x 0.6m)
2’ W x 5’ L (0.6m x 1.5m)
Fan Speed
Recessed fan speed control
3-fan
2’ W x 3’ L (0.6m x 0.9m)
3’ W x 5’ L (0.9m x 1.5m)
Indicators
Ionization ON light
Audible Noise
59-69 dBA (max), measured @ 2’ (0.6m) from blower
4-fan
2’ W x 4’ L (0.6m x 1.2m)
4’ W x 5’ L (1.2m x 1.5m)
Air Velocity2
Fan Speed:
Low:
High:
Operating Env.
Temperature 50-90°F (10-32°C); humidity 30-70% RH, non-condensing
Ozone
Equilibrium concentration
很抱歉,暂时无法提供与“4011007”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+15792.340971+2040.21733
