4100810
4100810
    SIMCO-ION
    AEROSTAT GUARDIAN AIR FILTER REP
4100810 数据手册
W W W . S I M C O - I O N . C O M Ionization Solutions Overhead Ionizing Blower AEROSTAT® GUARDIAN Simco-Ion’s Aerostat Guardian Overhead Ionizing Blower provides superior static charge decay over an entire work surface area. Equipped with task lighting and an integrated heater, the Guardian offers user-friendly operation while effectively protecting sensitive components from ESD damage. Featuring Simco-Ion’s patented inherent balance and built-in emitter point cleaners, the Guardian is the lowest maintenance overhead ionizer available. Like Simco-Ion’s other Aerostat series ionizing air blowers, the Guardian operates on AC Technology to provide stable balance performance over long periods of use. It is available with airflow diffusers for superior static charge decay efficiency over a large work surface area. Without diffusers, the Guardian provides fast charge decay directly under the unit for targeted work surface coverage. Features Benefits • Inherently balanced to 0 ±10V • Protects even the most sensitive electronic components • Integrated heater and task lights • User-friendly—enhances operator comfort and efficiency • AC Technology • Stable balance over extended periods of use • Ionization light • Verifies that the unit is ionizing • Integrated manual emitter point cleaner • Easy to maintain Emitter Point Cleaner Specifications Input Voltage 120 VAC, 60 Hz, 0.5A (fan low, heater/light off); 2.5A (fan high, heater/light on) 230 VAC, 50 Hz, 0.2A (fan low, heater/light off); 1.5A (fan high, heater/light on) Discharge1 3.0 sec @ 18” (45.7 cm) center blower position; fan high-no diffusers (1000-100V) Balance 0 ±10V @ 18” (45.7 cm) from blower face Ion Emission AC Ionization Coverage 2’ x 4’ (61 cm x 122 cm) area Cleanroom Class Meets ISO 14644 Class 5 (Fed std. 209E Class 100) Emitters Stainless Steel emitter points Controls Fan speed control knob BLOWER ON; on/off switch HEATER & TASK LIGHT Indicators Orange IONIZATION STATUS; orange within on/off switches HEATER & TASK LIGHT Air Volume 150-300 cfm (low to high), combined 3-fan output Heated Air Temp 25°F (14°C) fan low; 11°F (6°C) fan high measured @ 6” (15 cm) in front of center fan above ambient; Audible Noise 50 dBA fan low; 60 dBA fan high Operating Env. Temperature 32-122°F (0-50°C); humidity 30-70% RH, non-condensing Ozone 0.02 ppm, measured @ 12” (30 cm) in front of unit LED Lamp 2 ea x 5W, 508 Lumen Air Filter 30 ppi open cell polyurethane foam (optional) Mounting Adjustable brackets and S-hooks provided Enclosure Powder-coated white enamel aluminum Weight 16 lb (7.3 kg) Dimensions 42.75”W x 4”H x 6.75”D (108.6 x 10.2 x 17.1 cm) Warranty Two year limited warranty 2 Certifications 230V, 50 Hz The Aerostat Guardian features a built-in manual emitter point cleaner for each fan. Using the emitter point cleaner takes only seconds. Cleaning the emitter points prevents the build-up of airborne debris. This keeps your Aerostat Guardian working in top form for the life of the unit. Discharge Times Performance Discharge time in seconds (1000-100V), fan speed set to high. Guardian blower 18” from CPM measuring plate. CPM test plate 1” from table. Discharge times slightly longer for 230 VAC, 50 Hz unit. 120V, 60 Hz 1. Tested in accordance with ANSI/ESD STM3.1-2015. 2. Test conducted in accordance with EPS EQQA-9577-019 using Dashibi Ozone Monitor Model 1003AH. Ordering Information 91-GUARDD-US01 Aerostat Guardian, 120V, 60 Hz 91-GUARD-US01 Aerostat Guardian (no diffusers), 120V, 60 Hz 91-GUARDD-EU01 Aerostat Guardian, 230V, 50 Hz, (EU) 91-GUARDD-UK01 Aerostat Guardian, 230V 50 Hz, (UK) 32-6356-02 Outlet Diffuser 4710017 Aerostat Guardian Air Filter Retainer (1 per fan required) 4100810 Aerostat Guardian Air Filter Pack (6 filters) 13-20520 Aerostat Guardian Task Light LED Lamp, 13W (2 per blower) Overhead Ionization application Simco-Ion, Technology Group 1141 Harbor Bay Parkway, Suite 201 Alameda, CA 94502 Tel: +1 (800) 367-2452 (in USA) Tel: +1 (510) 217-0460 DS-GUARD-01 Rev 4 - 9/19 © 2019 Simco-Ion All rights reserved. ioninfo@simco-ion.com www.simco-ion.com
4100810 价格&库存
很抱歉,暂时无法提供与“4100810”相匹配的价格&库存,您可以联系我们找货
