4002612
4002612
    SIMCO-ION
    AEROSTAT XC EXTENDED COVERAGE BE
4002612 数据手册
W W W . S I M C O - I O N . C O M Ionization Solutions Extended Coverage Ionizing Blower AEROSTAT® XC Simco-Ion’s Aerostat XC Extended Coverage Ionizing Blower provides excellent coverage, balance stability, and rapid static charge decay times. The XC can be used in a variety of electronics and medical assembly environments. It features inherent balance to 0 ±10V to protect sensitive electronic components. The XC features Simco-Ion’s emitter point cleaner, an ionization status light and an integrated heater. The XC neutralizes static across a broad three-foot by six-foot area and operates on AC technology to provide stabled balanced performance over time. Features Benefits • Inherently balanced to 0 ±10V • Protects even the most sensitive electronic components • Rapid static charge decay times over a wide area • Neutralizes charges over the entire workbench • Integrated emitter point cleaner • Easy to maintain sustainable static charge control • Ionization status light • Easy to verify the presence of ionization • Integrated Heater • Provides a comfortable working environment for operators, ensuring continuous operation • Optional Air Filter • Adapts for use in extremely dusty environments Wide Variety of Applications Specifications Input Voltage 120 VAC, 60 Hz: 0.6A (high fan/heater off); 3.6A (high fan/heater on) 220-230 VAC, 50 Hz: 0.3A (high fan/heater off); 1.8 (high fan/heater on) Discharge 1.5 sec @ 1’ (30 cm); fan speed high (1000-100V)1 Balance 0 ±10V Ion Emission AC Ionization Emitters Stainless Steel Controls POWER ON/OFF switch, WARM AIR ON/OFF switch; FAN SPEED control LOW/ MEDIUM/HIGH, Emitter Point Cleaner Knob Indicators Orange IONIZATION status; orange within POWER and WARM AIR switches Coverage 3’ x 5’ to 2.5’ x 6’ (91 x 152 cm) to (76 x 183 cm) area Air Volume 70 cfm (low), 95 cfm (medium), 120 cfm (high) Air Velocity2 Fan Speed: 1’ 2’ 3’ 4’ Low: 600 300 180 150 Medium: 800 400 220 180 High: 1000 500 250 200 Heated Air Temp (heater optional) Fan high: 4-5°F (2-3°C) above ambient Fan medium: 4-5°F (2-3°C) above ambient; Fan low: 5-7°F (3-4°C) above ambient (measured @ 12” in front of blower) Operating Env. Temperature 50-95°F (10-35°C); humidity 30-70% RH, non-condensing Audible Noise Fan speed: low 52 dB, medium 58 dB, high 64 dB Ozone 0.05 ppm, measured @ 6” in front of unit3 Air Filter 30 ppi open cell polyurethane foam (optional) Mounting Metal stand/bracket included (optional pedestal mount kit for elevated mounting and locking stand kit) Enclosure Powder-coated white steel Dimensions 15.375”W x 4.5”H x 8.125”D (39.1 x 11.4 x 20.6 cm) Weight 17.5 lb (7.9 kg) Warranty Two year limited warranty Certifications 230V, 50 Hz The Aerostat XC is designed to control damage to sensitive components and products from both electrostatic discharge and electrostatic attraction in a wide variety of applications. The Aerostat XC is widely used in the electronics manufacturing and medical device assembly, test and packaging processes. The Aerostat XC is also designed for use in the module assembly and test processes within the flat panel display industry. Discharge Times Discharge times are tested in accordance with ANSI/ESD STM3.1-2006. Each point shows the discharge times (1000-100V) with high fan/low fan speed. Times are slightly higher with 230V/50 Hz unit. 120V, 60 Hz 1. Tested in accordance with ANSI/ESD STM3.1-2015. 2. Velocity in fpm measured at center line of air stream. 3. Test conducted in accordance with EPA EQQA-0577-019 using Dasibi Ozone Monitor Model 1003AH. Ordering Information 4002612 Aerostat XC, 120V, 60 Hz, North America 4002667 Aerostat XC, 230V, 50 Hz, Continental Europe 4009044 Aerostat XC, 230V, 50 Hz, United Kingdom 4015593 Aerostat XC, 230V, 50 Hz, China 4007151 Aerostat XC without heater, 230V, 50 Hz, China 5050282 Aerostat XC Pedestal Mount Kit 5051321 Aerostat XC Air Filter Kit 33-6010-01 Locking Stand Kit 4470059 Aerostat XC Air Filter Replacement Conveyor Application Simco-Ion, Technology Group 1141 Harbor Bay Parkway, Suite 201 Alameda, CA 94502 Tel: +1 (800) 367-2452 (in USA) Tel: +1 (510) 217-0460 DS-AeroStat XC_V5 - 9/19 © 2019 Simco-Ion All rights reserved. ioninfo@simco-ion.com www.simco-ion.com
4002612 价格&库存
很抱歉,暂时无法提供与“4002612”相匹配的价格&库存,您可以联系我们找货
