91-FMX-004
91-FMX-004
    SIMCO-ION
    FMX-004 HAND HELD FIELDMETER WIT
91-FMX-004 数据手册
w w w . s i m c o - I O N . c o m Ionization Solutions Handheld Electrostatic Fieldmeter FMX-004 Simco-Ion’s Model FMX-004 Fieldmeter is a compact handheld electrostatic fieldmeter used for locating and measuring static charges. Its pocket size makes it handy to use and four-button operation makes it easy to operate. The FMX-004 measures static voltages within ±30 kV (30,000V) at a distance of 1 inch. Results are simultaneously displayed numerically and in bar graph format. POWER on/off, ZERO adjustment, MODE and HOLD are all push-button operation. The HOLD button allows the display to retain the static charge reading. This is especially useful where the display is difficult to see during measurement. Two LED guide lights to help position the fieldmeter at the right distance from a charged test object. The conductive case and ground snap facilitate grounding for accurate measurement. The circuitry of the FMX-004 has been designed to make measurements in areas using air ionization. Features Benefits • Digital display with color-coded bar graphs • Easy to read especially in low light environments • Lightweight, compact design • Convenient to use in hard to reach areas • Distance ranging lights • Ensures accurate distancing and measurements • Audible alarm feature • User convenience feature to insure proper operation • Battery-powered with an auto shut-off feature • Extends battery life; energy efficient • Analog Output • Signals to a chart recorder or other device for hard copy documentation of static charge levels Specifications Range Balance Special Features 0 to ±1.49 kV (low range); ±1.0 kV to ±30 kV (high range) 0 to ±300V 1" ±0.2" (25 mm ±0.5 mm); LED guide for correct distance (between charged object and Fieldmeter) 3s 3 beeps POWER ON W/AUTO OFF disabled; short beeps @ 1s interval 5s before power off AUTO POWER-OFF; continuous beep sound OVER RANGE Analog Output Auto Power-off Power turns off automatically after 5 min; [A.OFF] is displayed whenever this feature is disabled Operating Env. Temperature 50-100ºF (10- 40ºC); humidity 0-60% RH (non-condensing) Power 9V, 6F22Y manganese battery Battery Life Approximately 30 hours Enclosure Conductive resin (ABS) Dimensions 4.8”L x 2.9”W x 1.0”D (123 x 73 x 25 mm) Weight 6 oz (170g) Warranty Two year limited warranty Distance Response Time Accuracy LCD Display LCD Renewal Rate Bar Graph Range Digital Display Ordering Information 91-FMX-004 Two LED guide lights to help position the fieldmeter at the right distance from a charged test object. The conductive case and ground snap facilitate grounding for accurate measurement. The circuitry of the FMX-004 has been designed to make measurements in areas using air ionization. The FMX-004 has an optional cable and bracket kit available. The bracket enables the fieldmeter to be mounted for continuous reading collection. The analog output cable allows you to feed an output signal to a PLC, data acquisition card, data logger, chart reader or other devices. Maintenance As with most measuring devices, calibration is necessary for optimal performance. We recommend recalibrating the FMX-004 once a year. Simco-Ion offers recalibration services that include a certificate with or without data. FMX-004 Hand-Held Fieldmeter with Charge Plate Simco-Ion, Technology Group 1141 Harbor Bay Parkway, Suite 201 Alameda, CA 94502 Tel: +1 (800) 367-2452 (in USA) Tel: +1 (510) 217-0460 DS-FMS004_V3 - 10/20 © 2020 Simco-Ion All rights reserved. ioninfo@simco-ion.com www.simco-ion.com
91-FMX-004 价格&库存
很抱歉,暂时无法提供与“91-FMX-004”相匹配的价格&库存,您可以联系我们找货
91-FMX-004
    • 1+8837.497481+1147.94609
    库存:26
