4008630
4008630
    SIMCO-ION
    电离器 悬挂式 120VAC
4008630 数据手册
W W W . S I M C O - I O N . C O M Ionization Solutions Cleanroom-rated Overhead Ionizing Blower GUARDIAN CR2000 Simco-Ion’s Guardian CR2000 Cleanroom-rated Overhead Ionizing Blower is designed specifically for use in cleanroom applications. The Guardian CR2000 features a patented circuit that results in a balanced delivery of positive and negative ions, which ensures that the unit will maintain an ion balance of 0 ±10V. Balance stability is further enhanced by the use of Simco-Ion’s unique “ion shields” at the fan outputs to reduce parasitic ion loss. The Guardian CR2000 ensures cleanroom compatibility with all fan and air bearing silicone-free surfaces. Fan assemblies are particle-tested to ISO 14644 Class 4 (Fed Std. 209E Class 10) particle limits. The Guardian CR2000 is also equipped with Simco-Ion’s patented built-in emitter point cleaner. A lockout switch prevents tampering with the desired performance level. Built-in balance and ion output monitors verify the presence of balanced, ionized air. A standard power outlet on each Guardian CR2000 blower allows for daisy-chaining up to 10 units. Unlike some overhead ionizers which link to an external device to provide real-time monitoring, the Guardian CR2000 has sophisticated internal monitoring circuitry which assures that the unit is ionizing and that the balance circuit is functioning. Features Benefits • Inherently balanced to 0 ±10V • Protects even the most sensitive electronic components • Ion balance and ion output monitors • Verifies that the unit is ionizing and balanced • Lockout key switch • Helps maintain desired ionization performance level • Silicone-free component surfaces • ISO 14644 Class 4 (Fed Std. 209E Class 10) cleanroom compatibility • Integrated emitter point cleaner • Provides fast, easy maintenance Emitter Point Cleaner Specifications Input Voltage 2-fan: 120 VAC, 50/60 Hz, 0.2A; 230 VAC, 50/60 Hz, 0.1A 3-fan: 120 VAC, 50/60 Hz, 0.3A; 230 VAC, 50/60 Hz, 0.15A Balance 0 ±10V @ 18” (46 cm) from blower face The Guardian CR2000 features a built-in emitter point cleaner for each fan. Using the emitter point cleaner takes only seconds. Cleaning the emitter points prevents the build-up of airborne debris. This keeps your Guardian CR2000 working in top form for the life of the unit. Discharge 3.0 sec @ 18” (46 cm) center blower position fan high (1000-100V) Coverage 2-fan: 2’ x 3’ (61 x 91 cm) area; 3-fan: 2’ x 4’ (61 x 121 cm) area Cleanroom Class Meets ISO 14644 Class 4 (Fed std. 209E Class 10) Emitters Stainless Steel emitter points Controls 3-position key switch OFF, ADJUSTABLE, HIGH; recessed fan speed control Application-specific Blower Lengths Indicators Ionization Status: green NORMAL, red MAINTENANCE LEDs Air Volume 2-fan: 90 cfm fan low, 180 cfm high fan; 3-fan: 135 cfm fan low, 270 cfm high fan Air Velocity 200 fpm (1.0 m/s) fan low; 400 fpm (2.0 m/s) fan high measured @ 18” (46 cm) Audible Noise 48 dBA fan low; 58 dBA fan high measured @ 2’ (61 cm) Operating Env. Temperature 32-122°F (0-50°C); humidity 30-70% RH, non-condensing The Guardian CR2000 Overhead Ionizing Blower comes in either 2-fan or 3-fan chassis lengths. Each length is designed for optimal coverage area and for variety of applications: • A 2-fan overhead blower will provide coverage for 2-foot by 3-foot area • A 3-fan overhead blower covers a 2-foot by 4-foot area Ozone 0.02 ppm measured @ 18” (46 cm) above test plate Power Outlets Input IEC 320; output IEC 320, allows power connection (daisy-chain) of up to 10 units in series from one power source Mounting Adjustable brackets and S hooks provided Enclosure Aluminum with glossy white polyurethane finish Dimensions 2-fan: 31.75”W x 4”H x 6.75”D (81 x 10 x 17 cm) 3-fan: 42.75”W x 4”H x 6.75”D (109 x 10 x 17 cm) Weight 2-fan: 12 lb (5.5 kg); 3-fan: 15 lb (6.8 kg) Warranty Two year limited warranty 1 Certifications 230V, 50 Hz 120V, 60 Hz 1. Tested in accordance with ANSI/ESD STM3.1-2015. Ordering Information 4008729 Guardian CR2000 2-fan, 120V, 60 Hz, UL, North America 4008730 Guardian CR2000 2-fan, 230V, 50 Hz, CE, Continental Europe 4008804 Guardian CR2000 2-fan, 230V, 50 Hz, CE, United Kingdom 4008630 Guardian CR2000 3-fan, 120V, 60 Hz, UL, North America 4008705 Guardian CR2000 3-fan, 230V, 50 Hz, CE, Continental Europe 4008805 Guardian CR2000 3-fan, 230V, 50 Hz, CE, United Kingdom 5050542 Overhead Blower Daisy-chain Kit, 10’ power cord Discharge Time Performance Discharge time in seconds (1000-100V), fan speed set to high; Guardian CR2000 blower 18” from CPM measuring plate; CPM test plate 6” from table; discharge times slightly longer for 230 VAC, 50 Hz unit. Simco-Ion, Technology Group 1141 Harbor Bay Parkway, Suite 201 Alameda, CA 94502 Tel: +1 (800) 367-2452 (in USA) Tel: +1 (510) 217-0460 DS-Guardian CR2000_V4 - 11/19 © 2019 Simco-Ion All rights reserved. ioninfo@simco-ion.com www.simco-ion.com
4008630 价格&库存
很抱歉,暂时无法提供与“4008630”相匹配的价格&库存,您可以联系我们找货
    • 1+16640.932531+2152.75866
