4006992-01
4006992-01
    SIMCO-ION
    TOP GUN IOINZING BLOW OFF GUN 12
4006992-01 数据手册
W W W . S I M C O - I O N . C O M Ionization Solutions Top Gun™ Ionizing Air Gun TOP GUN Simco-Ion’s Top Gun Ionizing Air Gun is a high-performance ionizing air gun designed for a wide variety of electronic manufacturing, medical and assembly applications. Balanced to 0±15V, the Top Gun features high blow-off force and low air consumption providing high efficiency cleaning and maximum static charge decay. A filter at the exit of the gun ensures that the air is clean. The gun body is lightweight but durable. It features a light-touch trigger, making it comfortable even for extended use. All functionality is built into the gun, including a flow control valve, a balance adjustment for calibration, and a two level LED which indicates both power and ionization. Both the gun and cable are static dissipative. A hanger is provided for easy mounting. Features Benefits • Lightweight, Ergonomic Design • Maximum user comfort prevents operator fatigue and increases productivity • Flow Control Valve for Adjustable Airflow • Airflow use that meets the specific application requirements • Electrically balanced ion output • Protects ESD senstive components and assemblies • Integrated, Replaceable Filter-Nozzle • Insures air contacting the target area is clean • Ionization Indicator Light • Eliminates the guesswork of ionization at target area Specifications Top Gun with Optional Sidekick Top Gun 3 The Top Gun with Sidekick offers hands-free operation and flexible positioning during assembly and manufacturing processes. A foot pedal controls both ionization and airflow, which reduces compressed air costs and extends the life of the ionizer. The flexible gun mount allows the operator to focus the ionized airflow where it is needed. The stand includes a steel bracket for easy bench-top mounting. Input Voltage 120 VAC, 60 Hz, 0.2A; 230 VAC, 50 Hz, 0.1A Discharge 1.3 sec @ 6” (15.2 cm), 30 psi (±1000-100V); 0.5 sec @ 2” (5 cm), 60 psi (±1000-100V)1 Balance ±15V Flow 2.4 scfm @ 30 psi (68/min, 2 bar); 4.6 scfm @ 60 psi (130/min, 4 bar); 7.4 scfm @ 100 psi (210/min, 7 bar) Blow-off Force 180g @ 100 psi, 2” diameter target 3” from the gun Air Pressure Pressure relief in nozzle complies with OSHA requirements Audible Noise 76 dbA @ 30 psi input (2 bar); 89 dbA @ 60 psi input (4 bar); 97 dbA @ 100 psi input (7 bar); measured 24” (600 mm) from nozzle Operating Env. Temperature: 32-104°F (0-40°C); humidity: 30-60% RH (non-condensing) Ozone 0.001 ppm measured 18” (450 mm) from gun, operation @ 15 psi (1 bar) Filter 0.01 micron rating; replacement filters available Gas Input 100 psi max; Clean Dry Air (CDA) or Nitrogen Gas Connection 1/4” NPT (female) Air Hose Static dissipative polyurethane, 7’ or 14’ standard, 5’ or 14’ with optical sensor (integral to gun and control module) 4005105 Top Gun 3, 120V, 7' Cable/Hose Assembly, 60 Hz, UL, cUL, North America Enclosure Gun: Static dissipative polycarbonate/ABS blend; cable: static dissipative polyurethane 4005106 Top Gun 3, 230V, 7' Cable/Hose Assembly, 50 Hz, CE, Continental Europe Dimensions Gun: 6.5 oz (185g); air hose: 1.25 ounces/ft (115g/m) 4009894 Top Gun 3, 230V, 7' Cable/Hose Assembly, 50 Hz, CE, United Kingdom Warranty 2 year limited warranty 4015642 Top Gun 3, 230V, 7' Cable/Hose Assembly, 50 Hz, CE, China 4006599 Top Gun 3, 120V, 14' Cable/Hose Assembly, 60 Hz, UL, cUL, North America 4006600 Top Gun 3, 230V, 14' Cable/Hose Assembly, 50 Hz, CE, Continental Europe 4009895 Top Gun 3, 230V, 14' Cable/Hose Assembly, 50 Hz, CE, United Kingdom 4015643 Top Gun 3, 230V 14' Cable/Hose Assembly, 50 Hz, CE, China 4012199 Top Gun 3, 120V, 5' Cable/Hose Assembly, optical sensor, 60 Hz, North America 4012200 Top Gun 3, 230V, 5' Cable/Hose Assembly, optical sensor, 50 Hz, CE, Continental Europe 4012201 Top Gun 3, 230V, 5' Cable/Hose Assembly, optical sensor, 50 Hz, CE, United Kingdom 4012202 Top Gun 3, 120V, 14' Cable/Hose Assembly, optical sensor, 60 Hz, North America 4012203 Top Gun 3, 230V, 14' Cable/Hose Assembly, optical sensor, 50 Hz, CE, Continental Europe 4012204 Top Gun 3, 230V, 14' Cable/Hose Assembly, optical sensor, 50 Hz, CE, United Kingdom 4006992 Top Gun 3, 120V, Sidekick (hands-free stand), 60 Hz, UL, cUL, North America 4007005 Top Gun 3, 230V, Sidekick (hands-free stand), 50 Hz, CE, Continental Europe 4015644 Top Gun 3, 230V, Sidekick (hands-free stand), 50 Hz, CE, China 4012205 Top Gun 3, 120V, Sidekick (hands-free stand), optical sensor, 60 Hz, North America 4012206 Top Gun 3, 230V, Sidekick (hands-free stand), optical sensor, 50 Hz, CE, Continental Europe 5050696 Filter/Nozzle Kit (2 per pkg) 5051416 Filter Premium Replacement Kit (2 per pkg) Certification 230V, 50 Hz • Foot pedal permits hands-free operation Ordering Information Control Module 120 VAC, 50/60 Hz, .10A; 230 VAC, 50/60 Hz, .05A Dimensions 5.20W x 6.45H x 3.35D in. (132 x 164 x 85 mm) Enclosure Powder-coated steel Weight 6 lbs (2.7 kg) 1. Tested in accordance with ANSI/ESD STM3.1-2006. Top Gun with Optical Sensor For automated assembly, all versions of the Top Gun are available with an optional Optical Sensor, which automatically activates the gun when an object is in range. The Optical Sensor has an “adjustable range” from 1-30 inches. • Fully adjustable 18 inch neck focuses the ionized airflow • Tabletop bracket provides easy mounting 120V, 60 Hz (except versions w/optical sensor) Power Top Gun Sidekick Optical Sensor Applications • Medical device manufacturing and packaging • Precision parts assembly • Particulate removal in optics • Cleaning glass or molded parts prior to finishing • Cleaning thermo-formed trays Simco-Ion Technology Group 1750 North Loop Rd., Ste 100 Alameda, CA 94502 Tel: 800.367.2452 (in USA) Tel: 510.217.0600 DS-TopGun 5200870_V2 - 08/12 © 2012 Simco-Ion All rights reserved. w o r l d w i d e l e a d e r s i n s t a info@simco-ion.com www.simco-ion.com t i c c o n t r o l
4006992-01 价格&库存
很抱歉,暂时无法提供与“4006992-01”相匹配的价格&库存,您可以联系我们找货
    库存:44
