4011425
4011425
    SIMCO-ION
    电离器 台式,便携式 120VDC
4011425 数据手册
W W W . S I M C O - I O N . C O M Ionization Solutions Compact Ionizing Blower minION 2 TM Simco-Ion’s minION2 Ionizing Blower is designed to control electrostatic charges in sensitive electronics assembly and automated tool applications requiring stable operation with fast discharge time performance. The minION2 is built to deliver big performance and reliability in a compact package with a practical feature set. A combination of unique, patented features incorporated in this product makes it possible for the minION2 to deliver industry-leading performance. Simco-Ion’s steady-state DC corona ion technology provides a patented control circuitry to deliver consistent performance. Performance is enhanced by the use of patented radial ion emitter design. Our unique geometry and airflow control provides performance meeting the demands of electronics and critical assembly manufacturers with corona ion technology. minION2 uses a modular wiring system that allows power delivery by “daisy-chaining” up to 3 units on one standard, modular power supply. Hardwiring of power can be accommodated by the use of a terminal block located on the back of the unit. The terminal block also features a relay contact output of the fault signal to enable remote monitoring. An optional clamp-on articulating arm stand is available for applications requiring an elevated position or to save work surface space. Features Benefits • Compact design • Portable enough for field service applications; large enough for permanent benchtop or in-tool operation • Self-balancing control circuit technology • Self-monitoring to ensure controlled, consistent ion output • Modular Wiring System • 24 VDC input power supplied by a wall AC adapter or by local tool power; up to 3 units daisy-chained from one power source • Local LED and relay contact alarm signal • Convenient indication of fault ionization operation Designed for Convenient Mounting Specifications Input Voltage 24 VDC, 250 mA, 6W Balance ±10V using auto-adjust Discharge 2 sec @ 1’ (30 cm), fan high (1000-100V) Coverage 1’ x 3’ (30 x 91 cm) area Controls Two position OFF/ON Fan Speed Recessed potentiometer Indicators Green POWER; Red FAULT LEDs Airflow 21-42 cfm Audible Noise 52 dBA (max), fan speed high @ 2’ (61 cm) from unit Operating Env. Temperature 32-122°F (0-50°C); humidity 30-70% RH, non-condensing Emitters Six stainless steel Connectors Two 4P4C “handset” modular/power; plug-type terminal block/power and fault signal Power Supply Universal 100-240 VAC input (IEC-320)/24 VDC, 1.66A output (suitable to power up to 3 units) Mounting Stainless steel; optional articulating arm Enclosure White reinforced polycarbonate Dimensions 3.875”W x 5.375”H x 2.375”D (98 x 136 x 60 mm) Weight 1.1 lb (0.5 kg) Warranty Two year limited warranty 1 The minION2 ionizer is designed for portable or permanent operation. The stand provided can be used in a permanent operation by bolting it to a sturdy flat surface such as a wall or shelf. The optional Articulating Arm offers flexibility for directed ionization into hard to reach target areas. minION2 with Optional Articulating Arm Discharge Time (typical) High Fan Speed Certifications 1. Tested in accordance with ANSI/ESD STM3.1-2015. Ordering Information 4012230 minION2 (no DC power supply), locking stand, 4P cable 4011424 minION2 (no DC power supply) 4011425 minION2 with 100/120 VAC to 24 VDC power supply, North America 4011426 minION2 with 230 VAC to 24 VDC power supply, Continental Europe 4011427 minION2 with 230 VAC to 24 VDC power supply, United Kingdom 4015592 MinION2 with 230 VAC to 24 VDC power supply, China 5051141 Articulating arm kit Positive/Neg ative Ions minION2 ionization for bowl feeder application. Simco-Ion, Technology Group 1141 Harbor Bay Parkway, Suite 201 Alameda, CA 94502 Tel: +1 (800) 367-2452 (in USA) Tel: +1 (510) 217-0460 DS-minION_V3 - 9/19 © 2019 Simco-Ion All rights reserved. ioninfo@simco-ion.com www.simco-ion.com
4011425 价格&库存
很抱歉,暂时无法提供与“4011425”相匹配的价格&库存,您可以联系我们找货
