LC200-UMTS STARTER KIT (EU)
    SIRETTA
    ROUTER 3G EVDO REV B GPS
LC200-UMTS STARTER KIT (EU) 数据手册
LC200 Series linkCONNECT Starter Kit Quick Start Guide Rev 1.2 What’s in the Box? As standard, the LC200 starter kit comes with the following: »» LC200-XXXX modem »» LC200 PSU Multi Adaptor »» Mike 1A antenna »» 1M USB-A to USB-B (Mini) Cable »» RS232 to USB cable »» Quick start guide Important Note The LC200 modem requires a data enabled SIM card to work. The unit is supplied without a SIM, please acquire a SIM from a suitable SIM provider - please note “Three” SIM cards will not work with the LC200-GPRS(EU). inspired wireless technology Setting up the LC200 SIM Step 1. Insert a SIM card fully into the SIM slot. Once the SIM card has been correctly inserted, a click will be heard. Step 2. Screw the antenna onto the LC200. Twist the antenna connector clock-wise until the antenna is firmly connected. inspired wireless technology Step 3. Using the supplied RS232 cable, connect the RS232 connector into the RS232 port on the LC200. Connect the USB connector (other end of the cable) into a USB port on your PC. RS232 cable The USB-Serial converter will appear in windows Device Manager as ‘Prolifc USB to serial’ and will be allocated a COM port number. Step 4. Download the configuration tool using the following link. http://www.siretta.co.uk/downloads/config_utility.exe inspired wireless technology Step 5. Select the correct COM port for your system and click ‘Connect’ in the configuration tool window. Ensure COM port selected is the one allocated to the ‘Prolific USB-Serial’ cable Step 6. Plug the power supply into the LC200 and connect it to a mains supply. The green LED on the LC200 will light up continuously, indicating that power has been supplied. inspired wireless technology Step 7. Change the device settings as required and click ‘Save’ to make changes to the unit. NOTE - For more information please see the ‘linkCONNECT Software Manual’ Log window Configuration window Step 9 Step 8 Your LC200 is now ready to connect to your application using the system settings. When power is applied, some debug information will appear in the Log window and the current (default) settings will appear in the Configuration window on the left. Make any desired changes to the settings and click ‘Save’. As a minimum you have to specify the APN and password. inspired wireless technology Step 8. Save the configuration file - manage settings. Save settings Step 9. Basic connection details: linkCONNECT as client sending data to server with fixed IP address. Check unlock for editing. Client settings: gprs_apn: SIM supplier will provide this gprs_userid: SIM supplier will provide this gprs_passwd: SIM supplier will provide this dns_primary: SIM supplier will provide this dns_secondary: SIM supplier will provide this mode: client
LC200-UMTS STARTER KIT (EU) 价格&库存
很抱歉,暂时无法提供与“LC200-UMTS STARTER KIT (EU)”相匹配的价格&库存,您可以联系我们找货
