QUARTZ-ONYX-GW42-5G (GL) WITH ACCESSORIES 数据手册
QUARTZ-ONYX
5G 4 x LAN, Dual SIM, Low Latency Industrial Router
Key Features
5G/4G/3G industrial router
Supports 5G SA/NSA ultra speed network
MIPS Dual-core 880 MHz
256 Mb Flash
2 Gb DDR3 RAM
4x Gigabit Ethernet ports
Resilient against strong magnetic interference
Metal enclosure for tough industrial applications
Dual SIM for failover / backup between networks
VPN: PPTP/L2TP/L2TP V3/GRE/IPSec/Open VPN
Optional GPS
Optional storage capacities avaliable- MOQ applies
1 × DC Power Interface (7.5 to 32 V DC)
General Description
The QUARTZ-ONYX is powered with a Mediatek
880 MHz MIPS dual-core processor with 256 Mb
flash and 2 Gb of DDR3 RAM which drives the Linux
based operating system.
A Quectel RM500QAE module is driven by the
Qualcomm Snapdragon X55 5G Modem which
provides the cellular capabilities of the QUARTZONYX and is manufactured on a leading edge 7 nm
semiconductor fabrication process coupled with
dual sim operation to provide seamless connectivity.
With Four Gigabit Ethernet interfaces, the QUARTZONYX also offers RS232 and RS485 interfaces that
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
may be used to connect serial ports on products
such as door access control panels and alarm
panels to the Internet.
Enhanced connectivity is provided by an intelligent
GPIO interface that can send SMS messages on
change of input state, and control outputs based on
input state or SMS messages received.
Wi-Fi 5 comes as standard.
Optional GPS using a 56-channel u-blox 7 engine
for asset tracking applications is also available.
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 1.1
QUARTZ-ONYX
Additional Features
Supports DHCP server
Supports DNS proxy and Dynamic DNS
(DDNS)
LED status lights
Supports 802.11 a/b/g/n/ac wireless
standards
Optional Interfaces
» Optional SMA Female Antenna Interface for GPS
» Optional Storage 16/32/64/128/256 GB
Environmental
Supports captive portal
Local and remote management
SNMP network management, NTP support
LCP/ICMP/flow/heartbeat check
Cellular
5G:
n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/
n40/n41/n66/n71/n77/n78/n79
LTE:
B1/B2/B3/B4/B5/B7/B8/B12/B13/B14/B17/
B18/B19/B20/B25/B26/B28/B29/B30/B32/
B34/B38/B39/B40/B41/B42/B43/B46/B48/
B66/B71
WCDMA:
B1/B2/B3/B4/B5/B6/B8/B19
Interfaces
4 x GbE
(3 x LAN, 1 x LAN/1 x WAN Configurable)
4 x I/O
(2 x Input, 2 x Output)
2 x RS232 (based on 2 wire interface)
1 x RS485 (if RS232 is not utilised)
Wi-Fi: 802.11 a/b/g/n/ac
2 x SIM Slot
4 x SMA (Female) 5G Antenna Interface
2 x SMA-RP Wi-Fi
Ruggedised industrial enclosure
Dimensions: 132 mm x 112 mm x 44 mm
(without antenna)
Approx Weight: 400g (not including accessories
and model dependent)
Operating Temperature Range: -30 to +75 °C
Storage Temperature Range: -40 to +85 °C
Relative Humidity: 0 - 95% Non-condensing
Router Settings
Network Protocols
» IPv4
» PPPoE
» UDP/TCP/ICMP/NTP/DHCP
» Modbus/TCP
» HTTP/HTTPS
» SNMP
Network Features
» Cellular/WAN failover
» VLAN
» Bandwidth management
» NAT/DMZ
» IP passthrough/port redirection
» Static/dynamic routing
» Captive portal
VPN
» PPTP/L2TP V3
» GRE
» IPSec
» OpenVPN
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
email
web
+44(0)118 976 9000
sales@siretta.com
www.siretta.com
Rev 1.1
QUARTZ-ONYX
Data Rates*
Power Specifications
5G SA Mode
» Maximum downlink speed: 2.1 Gbps
» Maximum uplink speed: 900 Mbps
5G NSA Mode
» Maximum downlink speed: 2.5 Gbps
» Maximum uplink speed: 650Mbps
LTE
» Maximum downlink speed: 1.0 Gbps
» Maximum uplink speed: 200 Mbps
WCDMA (3G)
» Maximum download speed: 42 Mbps
(DC-HSDPA)
» Maximum uplink speed: 5.76 Mbps
(HSUPA)
Idle: 550 mA @ +12VDC
Communications: 680 mA @ +12VDC
Cellular Antenna Specifications
Frequency range:
600-960/ 1710-2680/ 3400-3600/4800-4900
Gain: 3dBi
VSWR:
QUARTZ-ONYX-GW42-5G (GL) WITH ACCESSORIES 价格&库存
很抱歉,暂时无法提供与“QUARTZ-ONYX-GW42-5G (GL) WITH ACCESSORIES”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7782.50373
- 3+7458.23751
