SNYPER-LTE+ SPECTRUM (EU) 数据手册
SNYPER-LTE+ Spectrum (EU)
4G/LTE,3G/UMTS & 2G/GSM Network Signal Analyser with liveSCAN
General Description
The SNYPER-LTE+ Spectrum (EU) is a high performance, multi-language
network signal analyser dedicated to surveying the 4G/LTE(EU), 3G/UMTS &
2G/ GSM European networks.*
The SNYPER-LTE+ Spectrum (EU) can save multiple surveys locally in
memory and incorporates Siretta’s leading liveSCAN feature which allows
you to perform real time graphical site surveys on the full colour SNYPER
display.*
The SNYPER-LTE+ Spectrum is supplied with an omni-directional antenna
to detect “hotspots” in buildings and perform site surveys and also includes
a directional antenna kit to perform point-to-point antenna alignment.
The SNYPER can survey the local network and display results from all
discovered cellular cell towers observed in the area. Results are ordered
from highest to lowest “visible” base-station signal and the key network
parameters of each are displayed
*SNYPER-LTE+ Spectrum (EU) does not require a SIM in order to function.
Features
Featured Applications
Enhanced cellular surveying of new
and existing installations on 4G, 3G
and 2G networks
Establish most suitable operator for
application
Evaluate your “preferred” MNO’s
performance
Use liveSCAN to determine antenna
alignment to a selected base-station
Results are reported in CSV &
graphical HTML format
Registered in England No. 08405712
VAT Registration No. GB163 04 0349
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9000
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.0
General Features
Environmental
2 Supported Bands GSM | GPRS:
900/1800MHz
2 Supported Bands UMTS/HSPA+:
900/2100MHz
Dimensions
SNYPER: 141mm x 76mm x 36mm
Antenna: 78mm x 11mm
5 Supported Bands LTE:
800/900/1800/2100/2600MHz
Weight
Without antenna: 200 grams
With supplied antenna: 207 grams
Blue antenna for 700MHz to 2300 MHz
Operating Temperature Range: -10 to +50 deg C
Silver/Grey Antenna for 2600MHz
Storage Temperature Range: -20 to +50 deg C
liveSCAN feature for scanning selected base-stations
Large easy to read LCD display
Operating Humidity Range: 20 to 85% RH Noncondensing
No SIM required for operation
Battery: Lithium Ion 3.7V, 2000mAh
Saves multiple cellular surveys
Logical menus and operation
Life: 48 hours based on 20 surveys /day at room
temperature with auto power off enabled
Long life rechargeable battery
Warm up time: 2s
0.5m USB cable for download/charging
USB car charger included
Rugged and durable construction
Supplied in a hard carry case
Multiple language support
(English/French/German/Italian/Spanish)
Reporting
HTML Reporting
Graphical display ordered by signal strength
Listing of advanced cellular parameters
Complete summary breakdown for all recorded cells
Recorded survey date and time
Integrated mapping portal enabled
(registration required)
Interfaces
CSV Reporting
Complete survey breakdown for each recorded cell
1 x USB 2.0 FS(12 MBits/s) for PC interface and for
battery charging
1 x SMA female cellular antenna connector
Red LED charging indicator
Display: 2.4” Diagonal QVGA 240 x 320 RGB TFT
with LED backlight
Display: 80 degree viewing angle
Display Brightness: 500md/m2
Power Supply
Mains Input: 100-240V 50/60Hz
Multi-region Heads: UK / EU /US / AU
Charger O/P: 5V DC 2000mA
Approvals and Compliance
CE
Siretta Ltd
Basingstoke Road
Spencers Wood
Reading
Berkshire RG7 1PW
sales
fax
email
web
+44(0)118 976 9000
+44(0)118 976 9020
sales@siretta.com
www.siretta.com
Rev 1.0
SNYPER-LTE+ SPECTRUM (EU) 价格&库存
很抱歉,暂时无法提供与“SNYPER-LTE+ SPECTRUM (EU)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+9830.242631+1274.18661
