ZEST-N-UMTS(EU)
ZEST-N-UMTS(EU)
    SIRETTA
    MODEM CELLULAR 3G
ZEST-N-UMTS(EU) 数据手册
ZEST-N-UMTS (EU) Low Cost 3G Modem with RS232 and USB Serial Port Interfaces Key Features • • • • • • • • • RS232 serial port interface (RS485 to order) USB serial port interface Dual band 900 / 1800MHz UMTS 900 / 2100MHz Supply voltage capability 6-21V AT command driven Wall or DIN rail mountable Compact size 105 grams weight General Description The ZEST is an entry level industrial cellular modem, with serial RS232 and USB ports, offering key functionality within a rugged plastic enclosure. The ZEST is ideal for M2M applications requiring a simple but reliable modem for 3G data connection, using either a standard RS232 or USB interface. The USB port is used for sending / receiving data, but in addition can be used for supplying power. The ZEST-N-UMTS (EU) is a dual band GPRS and 900 / 2100MHz 3G modem providing EU coverage, for the EMEA and APAC regions. Further configurations including global quad band GPRS are also available. The ZEST enclosure comes ready to be either wall mounted or DIN rail mounted, an unusual feature at this price point. This capable low cost modem offers full nine pin functionality at the RS232 port to cater for all application requirements. It will be at home in any of the following applications: automatic meter reading, remote vending machine management, LED signage, POS connectivity and many other situations requiring GPRS / 3G connectivity in a reliable compact package measuring just 75 x 84 x 31mm. Despite its highly competitive price, the ZEST is built to the same exacting standards as the rest of the Siretta modem family. The ZEST will be a popular choice for many situations requiring just GPRS or 3G connectivity, and the flexible 6-21V power supply and a -40˚C to +85˚C operating temperature range allow the product to be used in most industrial applications. A member of the Olancha Group Ltd Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.co.uk www.siretta.co.uk Rev 1.2 ZEST-N-UMTS (EU) Low Cost 3G Modem with RS232 and USB Serial Port Interfaces Electrical Specifications USB Interface RS232 serial port USB serial port Interfaces: Operating frequencies: Dual band GSM: 900, 1800MHz 900, 2100MHz 3G Temperature range: Ports: 1 x Mini B USB Female Speed: USB 2.0 high speed 480(Mbit/s) ESD protection: 15kV -40 to +85°C Power supply: 6 - 21V System LED indicators: Cellular Interface RUN Data link: 100 to 200mA (peak) @ 12V GSM / GPRS / EDGE / UMTS / HSDPA / HSPA+ Standards: GPRS: Max 86kbps (DL & UL), lass 10 EDGE: Max 236.8kbps (DL & UL), Class 12 UMTS: Max 384kbps (DL & UL) HSPA+: Max 14.4 / 5.76Mbps (DL / UL) HSDPA: Max 3.6Mbps / 384kbps (DL / UL) CSD: Up to 9.6kbps SIM: 1 x (3V & 1.8V) Antenna interface: Software Protocols IP protocols: Serial port: PPP, TCP, UDP, ICMP, DDNS, Telnet TCP Client / Server, UDP, Modbus RTU to Modbus TCP, Virtual COM (COM port redirector) SMA female Serial Interface Ports: 1 x DB9 female Serial standards: RS232 ESD protection: ± 15KV Parameter: RS232: 1200bps to 115200bps DCD, RxD, TxD, DTR, GND, DSR, RTS, CTS, RI RS485 (option): A member of the Olancha Group Ltd Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Data+(A), Data-(B), GND Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.co.uk www.siretta.co.uk Rev 1.2 ZEST-N-UMTS (EU) Low Cost 3G Modem with RS232 and USB Serial Port Interfaces Mechanical Specifications 75 x 84 x 31mm (see drawing below) Dimensions: Weight: 105g Antenna connector: SMA Female (GSM) Mounting method: DIN Rail or Screw Mount 32.90 30.60 75.20 79.28 83.70 A member of the Olancha Group Ltd Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9014 +44(0)118 976 9020 sales@siretta.co.uk www.siretta.co.uk Rev 1.2
ZEST-N-UMTS(EU) 价格&库存
很抱歉,暂时无法提供与“ZEST-N-UMTS(EU)”相匹配的价格&库存,您可以联系我们找货
