ZEST-N-UMTS STARTER KIT
    SIRETTA
    ROUTER NO CELL
ZEST-N-UMTS STARTER KIT 数据手册
ZEST Series 2G/3G Modem Starter Kit Quick Start Guide Rev 1.3 Whats in the Box? As standard, the ZEST starter kit comes with the following*: »» ZEST series modem »» Power supply »» Mike 1A antenna »» RS232 male to USB cable »» Quick start guide NOTE - The ZEST modem requires a data enabled SIM card to work. The unit is supplied without a SIM, please acquire a SIM from a suitable SIM provider - please note Three SIM cards will not work with the ZEST-N-GPRS. *If you have purchased the ZEST as a standalone modem, you will need to purchase the other accessories separately from www.siretta.co.uk Setting up the ZEST SIM Step 1. Insert a SIM card fully into the SIM slot. Once the SIM card has been correctly inserted, a click will be heard. Step 2. Screw the antenna* onto the ZEST. Twist the antenna connector clock-wise until the antenna is firmly connected. Step 3. Using the supplied RS232 to USB cable, connect the RS232 male connector into the RS232 port on the ZEST. Connect the USB connector (other end of the cable) into a USB port on your PC. RS232 to USB cable Step 4. Open ‘HyperTerminal’ on your PC. You will be requested to enter the number of the COM port your are using to communicate between the ZEST and PC. Upon request, ensure the following information is inserted: »» Bits Per Second: 115200 »» Data Bits: 8 »» Parity: None »» Stop Bit: 1 »» Flow Control: Hardware Step 5. Plug the power supply* into the ZEST. Ensure the mains supply is plugged into a power source and switched on. The green LED on the ZEST will light up continuously**, this indicates that power has been supplied. See table 1 below for LED indication. Table 2. LED status Name Colour Status Description POWER Green ON ZEST is powered on POWER Green OFF ZEST is powered off *The power supply used in this drawing may be different to the one supplied, however the application process of the power supply is the same. **If this step fails, please try again. If it fails a second time, please contact your Siretta representative or call us on +44 (0)118 976 9014. Step 6. In the ‘Hyperterminal’ command window, type in the command: AT The command window will respond with: OK Your ZEST is now connected and ready to start communication. B C D E F Mounting the ZEST The ZEST has an integrated DIN rail mount housing which allows the unit to connect on to the standard rail widely used for mounting industrial control equipment inside equipment racks. This has been adopted as a European (EN) and International (ISO) Standard. 1 Hook the bottom modem DIN rail clip onto the bottom of the DIN rail 2 Push modem 45° until the top DIN rail clip locks onto the top of DIN rail 2 1 G Further Information For more information when using your ZEST, a range of hardware and software manuals are available to download. You can request these from your Siretta representative, alternatively these can be download from www.siretta.co.uk sales +44 (0)118 976 9014 fax +44 (0)118 976 9020 accounts +44 (0)118 976 9069 email sales@siretta.co.uk www.siretta.co.uk Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW United Kingdom Company No. 08405712 VAT Registration No. GB163 04 0349 A member of the Olancha Group Ltd Rev 1.3
PDF文档中包含了以下信息: 1. 物料型号:型号为LM324,属于四运算放大器。
2. 器件简介:LM324是一款通用的四运算放大器,具有高增益带宽积、低输入偏置电流和低功耗的特点。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,引脚4为正电源,引脚7为负电源,引脚8为接地。
4. 参数特性:包括电源电压范围、静态电流、增益带宽积等。
5. 功能详解:LM324可以用于各种线性或非线性应用,如信号放大、滤波器、电压比较器等。
6. 应用信息:广泛应用于模拟信号处理领域。
7. 封装信息:提供多种封装类型,如SOIC、PDIP等。
以上信息为您提供了LM324运算放大器的详细技术参数和应用指南。
ZEST-N-UMTS STARTER KIT 价格&库存
很抱歉,暂时无法提供与“ZEST-N-UMTS STARTER KIT”相匹配的价格&库存,您可以联系我们找货
