SIT5711ACCTW-33E-20.000000F 数据手册
Emerald OCXOs
for Precision Time Synchronization
±5 ppb stability, ±50 ppt/qC ΔF/ΔT
Smallest package, 9 x 7 mm2
Unmatched ease-of-use
SiTime’s Emerald Platform™ Stratum 3E OCXOs are designed to solve the long-standing problems of quartz OCXOs, which are
sensitive to environmental conditions, require protective components, and are difficult to use. Emerald OCXOs provide the best
dynamic performance (under airflow, thermal shock, vibration, shock, and EMI), programmability for the shortest lead time, and
the smallest size. Also available in standard OCXO footprints, these devices can be used as drop-in replacements for quartz
OCXOs while improving system performance and robustness.
Benefits
Features
Enhance system robustness/performance in harsh environments
Reduce design/manufacturing overhead by eliminating placement
Exceptional dynamic stability under airflow, fast temp ramp
±5 to ±50 ppb over-temp stability
constraints and shielding requirements
±50 ppt/°C frequency slope (ΔF/ΔT)
Shrink system size with smallest OCXO package, fewer
2e-11 ADEV at 10 seconds averaging time, under airflow
supporting components
0.1 ppb/g vibration, for outdoor pole mounted equipment
Minimize time error in time synchronization applications
Applications
SONET/SDH Stratum 3E
4G/5G RRH, DU
IEEE 1588 Boundary Clocks
and Grandmasters
Macro Base Stations
Carrier Class Routers
Optical Transport
Digital Switching
Test Instrumentation
Synchronous Ethernet
Resistant to microphonic and/or board bending effects
On-chip regulators for power supply noise filtering
±0.25 ppb daily aging, ±500 ppb 20 year aging
Excellent holdover through a wide range of conditions
Programmable platform, any frequency from 1 to 220 MHz
LVCMOS or clipped sinewave output
No activity dips or micro jumps
GR-1244 Stratum 3E compliant
Contact SiTime for ±3 ppb or better stability options,
2
105°C operating temperature, and I C frequency tuning
Four package options (actual size)
Industry’s smallest 9.0 x 7.0 x 6.5H mm OCXO, plus 3
industry standard packages for drop-in replacement of quartz
Emerald OCXOs
Device Type
Device
Frequency
(MHz)
SiT5711
1 to 60
Temp.
Range (°C)
Stability
(ppb)
Output
Type
Package
Size (mm2)
±5 to ±8 [2]
9.0 x 7.0
Precision
OCXO
SiT5712
SiT5701
60 to 220
1 to 60
-20 to 70
-40 to 85
[1]
±5 to ±8
[2]
±15 to ±50 [2]
LVCMOS,
14.0 x 9.0
Clipped Sine
Wave
20.0 x 13.0
25.0 x 22.0
SiT5702
60 to 220
±15 to ±50
[2]
1. Contact SiTime for 105°C products. 2. Contact SiTime for tighter stability options. 3. Contact SiTime for I2 C options.
SiTime, a MEMS and analog semiconductor company, is the leader in frequency-control solutions. We combine innovative MEMS and
programmable analog technologies with our systems expertise to break through the limitations of legacy quartz products and deliver the
industry’s best timing solutions. Our configurable products provide the most stable timing that enables customers to differentiate their
systems with higher performance, small size and better reliability.
© 2018 SiTime Corp. The information contained herein is subject to change without notice. www.sitime.com
Rev. 1.1 12/07/2018
SIT5711ACCTW-33E-20.000000F 价格&库存
很抱歉,暂时无法提供与“SIT5711ACCTW-33E-20.000000F”相匹配的价格&库存,您可以联系我们找货
