SIT8225AC-22-18E-25.000000
    SITIME(赛特时脉)
    SMD3225_4P
    有源晶振 25MHz 1.8V -20℃~+70℃ LVCMOS,LVTTL
SIT8225AC-22-18E-25.000000 数据手册
SiT8225 0.3 ps Jitter Oscillator for Networking The Smart Timing Choice The Smart Timing Choice Features Applications  25 MHz, 25.001200 MHz and 25.000625 MHz for Ethernet applications  SATA, SAS, Ethernet, 10Gb Ethernet, XAUI  100% pin-to-pin drop-in replacement to quartz-based oscillators  Computing, storage, networking, telecom, industrial control  Ultra low phase jitter: 0.3 ps  Frequency stability as low as ±10 PPM  Industrial or extended commercial temperature range  LVCMOS/LVTTL compatible output  Standby or output enable modes  Standard 4-pin packages: 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm2  Outstanding silicon reliability of 2 FIT or 500 million hour MTBF  Pb-free, RoHS and REACH compliant  Ultra short lead time Electrical Characteristics Parameter Output Frequency Range Frequency Stability Operating Temperature Range Supply Voltage Current Consumption OE Disable Current Standby Current Duty Cycle Rise/Fall Time Symbol f F_stab T_use Vdd Idd I_OD I_std DC Tr, Tf Min. Typ. Max. 25.000000, 25.001200, 25.000625 Unit Condition MHz -10 – +10 PPM -20 – +20 PPM -25 – +25 PPM -50 – +50 PPM -20 – +70 °C Extended Commercial -40 – +85 °C Industrial 1.71 1.8 1.89 V 2.25 2.5 2.75 V Supply voltages between 2.5V and 3.3V can be supported. Contact SiTime for additional information. 2.52 2.8 3.08 V 2.97 3.3 3.63 V – 31 33 mA No load condition, Vdd = 2.5V, 2.8V or 3.3V – 29 31 mA No load condition, Vdd = 1.8V – – 31 mA Vdd = 2.5V, 2.8V or 3.3V, OE = GND, output is Weakly Pulled – – 30 mA Vdd = 1.8 V. OE = GND, output is Weakly Pulled Down – – 70 A Vdd = 2.5V, 2.8V or 3.3V, ST = GND, output is Weakly Pulled – – 10 A Vdd = 1.8 V. ST = GND, output is Weakly Pulled Down 45 – 55 % Inclusive of Initial tolerance at 25 °C, and variations over operating temperature, rated power supply voltage and load – 1.2 2 ns 15 pF load, 10% - 90% Vdd – 2.2 – ns 30 pF load, 10% - 90% Vdd – 3.4 – ns 90% – – Vdd VOL – – 10% Vdd VIH 70% – – Vdd Pin 1, OE or ST Input Voltage Low VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedance Z_in – 100 250 kΩ Pin 1, OE logic high or logic low, or ST logic high 2 – – MΩ Pin 1, ST logic low Measured from the time Vdd reaches its rated minimum value Output Voltage High VOH Output Voltage Low Input Voltage High Startup Time OE Enable/Disable Time Resume Time RMS Period Jitter RMS Phase Jitter (random) First year Aging 10-year Aging T_start – 7 10 ms T_oe – – 150 ns T_resume – 6 10 ms T_jitt 45 pF load, 10% - 90% Vdd IOH = -6 mA, IOL = 6 mA, (Vdd = 3.3V, 2.8V, 2.5V) IOH = -3 mA, IOL = 3 mA, (Vdd = 1.8V) In standby mode, measured from the time ST pin crosses 50% threshold. Refer to Figure 5. – 1.5 2 ps Vdd = 2.5V, 2.8V or 3.3V – 2 3 ps Vdd = 1.8V T_phj – 0.25 0.3 ps IEEE802.3-2005 10GbE jitter measurement specifications F_aging -1.5 – +1.5 PPM 25°C -5 – +5 PPM 25°C Note: 1. All electrical specifications in the above table are specified with 15 pF output load and for all Vdd(s) unless otherwise stated. 2. Contact SiTime for custom drive strength to drive higher or multiple load, or SoftEdge™ option for EMI reduction. SiTime Corporation Rev. 1.01 990 Almanor Avenue Sunnyvale, CA 94085 (408) 328-4400 www.sitime.com Revised March 4, 2013 SiT8225 0.3 ps Jitter Oscillator for Networking The Smart Timing Choice The Smart Timing Choice Pin Configuration Pin 1 Symbol Functionality Top View Output Enable H or Open[3]: specified frequency output L: output is high impedance. Only output driver is disabled. Standby H or Open[3]: specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. OE/ ST 2 GND Power Electrical ground 3 OUT Output Oscillator output 4 VDD Power Power supply voltage OE/ST 1 4 VDD GND 2 3 OUT Note: 3. A pull-up resistor of
物料型号:SiT8225 器件简介:SiT8225是一款为网络应用设计的0.3皮秒抖动振荡器,提供25 MHz、25.001200 MHz和25.000625 MHz的频率选项,可作为石英基振荡器的100%引脚对引脚替代品。 引脚分配:1-OE/ST(输出使能/待机),2-GND(电源地),3-OUT(输出),4-VDD(电源电压)。 参数特性:包括输出频率范围、频率稳定性、工作温度范围、供电电压、电流消耗、占空比、上升/下降时间、输出电压高低电平、输入电压高低电平、输入上拉阻抗、启动时间、OE使能/禁用时间、待机恢复时间、RMS周期抖动、RMS相位抖动(随机)、首年老化、10年老化等。 功能详解:文档详细描述了OE/ST引脚的工作原理,包括输出使能和待机模式,以及如何通过该引脚实现频率输出或将输出置于高阻态。 应用信息:适用于SATA、SAS、Ethernet、10Gb Ethernet、XAUI等,以及计算、存储、网络、电信、工业控制等领域。 封装信息:提供标准4引脚封装,尺寸包括2.5 x 2.0、3.2 x 2.5、5.0 x 3.2、7.0 x 5.0 mm²。
SIT8225AC-22-18E-25.000000 价格&库存
很抱歉,暂时无法提供与“SIT8225AC-22-18E-25.000000”相匹配的价格&库存,您可以联系我们找货
