SIT2019AEES-28S
SIT2019AEES-28S
    SITIME
    SC-74A, SOT-753
    OSCILLATOR PROGRAMMABLE
SIT2019AEES-28S 数据手册
SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Features Applications  Frequencies between 115.194001 MHz to 137 MHz accurate to 6 decimal places  Industrial, medical, avionics and other high temperature applications  Operating temperature from -40°C to 125°C. For -55°C option, refer to SiT2020 and SiT2021  Industrial sensors, PLC, motor servo, outdoor networking equipment, medical video cam, asset tracking systems, etc.  Supply voltage of 1.8V or 2.5V to 3.3V  Excellent total frequency stability as low as ±20 ppm  Low power consumption of 5mA typical at 1.8V  LVCMOS/LVTTL compatible output  5-pin SOT23-5 package: 2.9mm x 2.8mm  RoHS and REACH compliant, Pb-free, Halogen-free and Antimony-free  For AEC-Q100 clock generators, refer to SiT2024 and SiT2025 Electrical Specifications Table 1. Electrical Characteristics[1,2] Parameters Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 115.194001 – 137 MHz F_stab -20 – +20 ppm -25 – +25 ppm -30 – +30 ppm -50 – +50 ppm Refer to Table 14 for the exact list of supported frequencies list of supported frequencies Frequency Stability and Aging Frequency Stability Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load (15 pF ± 10%). Operating Temperature Range Operating Temperature Range (ambient) T_use -40 – +105 °C Extended Industrial -40 – +125 °C Automotive Supply Voltage and Current Consumption Supply Voltage Current Consumption OE Disable Current Standby Current Vdd Idd I_od I_std 1.62 1.8 1.98 V 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 6.2 8 mA No load condition, f = 125 MHz, Vdd = 2.8V, 3.0V or 3.3V – 5.4 7 mA No load condition, f = 125 MHz, Vdd = 2.5V – 4.8 6 mA No load condition, f = 125 MHz, Vdd = 1.8V – – 4.8 mA Vdd = 2.5V to 3.3V, OE = Low, output in high Z state. – – 4.3 mA Vdd = 1.8V, OE = Low, output in high Z state. – 2.6 8.5 A Vdd = 2.8V to 3.3V, ST = Low, Output is Weakly Pulled Down – 1.4 5.5 A Vdd = 2.5V, ST = Low, Output is Weakly Pulled Down – 0.6 3.5 A Vdd = 1.8V, ST = Low, Output is Weakly Pulled Down LVCMOS Output Characteristics Duty Cycle Rise/Fall Time DC 45 – 55 % All Vdds Tr, Tf – 1.0 2.0 ns Vdd = 2.5V, 2.8V, 3.0V or 3.3V, 20% - 80% – 1.3 2.5 ns Vdd = 1.8V, 20% - 80% – 1.0 3 ns Vdd = 2.25V - 3.63V, 20% - 80% Output High Voltage VOH 90% – – Vdd IOH = -4 mA (Vdd = 3.0V or 3.3V) IOH = -3 mA (Vdd = 2.8V or 2.5V) IOH = -2 mA (Vdd = 1.8V) Output Low Voltage VOL – – 10% Vdd IOL = 4 mA (Vdd = 3.0V or 3.3V) IOL = 3 mA (Vdd = 2.8V or 2.5V) IOL = 2 mA (Vdd = 1.8V) SiTime Corporation Rev. 1.0 990 Almanor Avenue, Sunnyvale, CA 94085 (408) 328-4400 www.sitime.com Revised October 16, 2014 SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Table 1. Electrical Characteristics[1,2] (continued) Parameters Symbol Min. Typ. Max. Unit Condition Input Characteristics Input High Voltage VIH 70% – – Vdd Input Low Voltage VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedence Z_in 50 87 150 k Pin 1, OE logic high or logic low, or ST logic high – – M Pin 1, ST logic low 2 Pin 1, OE or ST Startup and Resume Timing Startup Time T_start – – 5 ms Measured from the time Vdd reaches 90% of final value T_oe – – 130 ns T_resume – – 5 ms f = 115.194001 MHz. For other frequencies, T_oe = 100 ns + 3 * clock periods Measured from the time ST pin crosses 50% threshold Enable/Disable Time Resume Time Jitter RMS Period Jitter T_jitt Peak-to-peak Period Jitter T_pk RMS Phase Jitter (random) T_phj – 1.6 2.5 ps f = 125 MHz, Vdd = 2.5V, 2.8V, 3.0V or 3.3V – 1.8 3 ps f = 125 MHz, Vdd = 1.8V – 12 20 ps f = 125 MHz, Vdd = 2.5V, 2.8V, 3.0V or 3.3V – 14 30 ps f = 125 MHz, Vdd = 1.8V – 0.5 0.8 ps f = 125 MHz, Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps f = 125 MHz, Integration bandwidth = 12 kHz to 20 MHz Notes: 1. All electrical specifications in the above table are specified with 15 pF output load and for all Vdd(s) unless otherwise stated. 2. The typical value of any parameter in the Electrical Characteristics table is specified for the nominal value of the highest voltage option for that parameter and at 25 °C temperature. Table 2. Pin Description Pin Symbol 1 GND Power 2 NC No Connect 3 OE/ ST/NC Electrical ground OE/ST/NC NC No connect Output Enable H[4]: specified frequency output L: output is high impedance. Only output driver is disabled. Standby H or Open[4]: specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. No Connect 3 2 GND 1 Any voltage between 0 and Vdd or Open[4]: Specified frequency output. Pin 3 has no function. 4 VDD Power Power supply voltage[3] 5 OUT Output Oscillator output Notes: 3. A capacitor of value 0.1 µF or higher between Vdd and GND is required. 4. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 3 is not externally driven. If pin 3 needs to be left floating, use the NC option. Rev. 1.0 Top View Functionality [3] Page 2 of 12 4 5 VDD OUT Figure 1. Pin Assignments www.sitime.com SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice N Table 3. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C Vdd -0.5 4 V Electrostatic Discharge – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C Junction Temperature[5] – 150 °C Note: 5. Exceeding this temperature for extended period of time may damage the device. Table 4. Thermal Consideration[6] JA, 4 Layer Board JC, Bottom 421 175 (°C/W) Package SOT23-5 (°C/W) Note: 6. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. Table 5. Maximum Operating Junction Temperature[7] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 105°C 115°C 125°C 135°C Note: 7. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 6. Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev. 1.0 Page 3 of 12 www.sitime.com SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Test Circuit and Waveform[8] Vout Test Point Vdd Tr 5 15pF (including probe and fixture capacitance) 4 1 2 3 Power Supply 0.1µF Tf 80% Vdd 50% 20% Vdd High Pulse (TH) Low Pulse (TL) Period Vdd 1k OE/ST Function Figure 3. Output Waveform Figure 2. Test Circuit Note: 8. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagrams 90% Vdd Vdd Vdd 50% Vdd Pin 4 Voltage T_start [9] No Glitch during start up ST Voltage T_resume CLK Output CLK Output T_resume: Time to resume from ST T_start: Time to start from power-off Figure 4. Startup Timing (OE/ST Mode) Figure 5. Standby Resume Timing (ST Mode Only) u Vdd Vdd 50% Vdd OE Voltage OE Voltage 50% Vdd T_oe T_oe CLK Output CLK Output HZ T_oe: Time to re-enable the clock output T_oe: Time to put the output in High Z mode Figure 6. OE Enable Timing (OE Mode Only) Figure 7. OE Disable Timing (OE Mode Only) Note: 9. SiT2019 has “no runt” pulses and “no glitch” output during startup or resume. Rev. 1.0 Page 4 of 12 www.sitime.com SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Performance Plots[10] 1.8 V 2.5 V 2.8 V 3.0 V 3.3 V DUT 2 DUT 3 DUT 4 DUT 5 DUT 6 DUT 7 DUT 8 DUT 9 DUT 10 25 6.5 20 Frequency (ppm) 6.0 5.5 Idd (mA) DUT 1 5.0 4.5 4.0 15 ) 10 m p 5 p  (y c n 0 e u ‐5 q e Fr ‐10 ‐15 3.5 ‐20 ‐25 3.0 115 120 125 130 135 ‐40 ‐20 0 Frequency (MHz) 2.8 V 3.0 V 3.3 V 1.8 V 4.0 55 3.5 54 2.5 2.0 1.5 1.0 100 120 2.5 V 2.8 V 3.0 V 3.3 V 52 51 50 49 48 47 0.5 46 115 120 125 130 45 115 135 120 125 Figure 10. RMS Period Jitter vs Frequency 1.8 V 2.5 V 2.8 V 130 135 Frequency (MHz) Frequency (MHz) 3.0 V Figure 11. Duty Cycle vs Frequency 3.3 V 1.8 V 2.5 2.5 2.0 2.0 Fall time (ns) Rise time (ns) 80 53 3.0 0.0 1.5 1.0 2.5 V 2.8 V 3.0 V 3.3 V 1.5 1.0 0.5 0.5 0.0 0.0 -40 -20 0 20 40 60 80 100 -40 120 -20 0 20 40 60 80 100 120 Temperature (°C) Temperature (°C) Figure 12. 20%-80% Rise Time vs Temperature (125 MHz Output) Rev. 1.0 60 Figure 9. Frequency vs Temperature Duty cycle (%) RMS period jitter (ps) 2.5 V 40 Temperature (°C) Figure 8. Idd vs Frequency 1.8 V 20 Temperature (°C) Figure 13. 20%-80% Fall Time vs Temperature (125 MHz Output) Page 5 of 12 www.sitime.com SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Performance Plots[10] 1.8 V 2.5 V 2.8 V 3.0 V 3.3 V 1.8 V 2.0 2.5 V 2.8 V 3.0 V 3.3 V 1.0 0.9 1.8 IPJ (ps) IPJ (ps) 0.8 1.6 1.4 1.2 1.0 115 0.7 0.6 0.5 120 125 130 0.4 115 135 120 125 130 135 Frequency (MHz) Frequency (MHz) Figure 14. RMS Integrated Phase Jitter Random (12 kHz to 20 MHz) vs Frequency[11] Figure 15. RMS Integrated Phase Jitter Random (900 kHz to 7.5 MHz) vs Frequency[11] Notes: 10. All plots are measured with 15 pF load at room temperature, unless otherwise stated. 11. Phase noise plots are measured with Agilent E5052B signal source analyzer. Rev. 1.0 Page 6 of 12 www.sitime.com SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Programmable Drive Strength The SiT2019 includes a programmable drive strength feature to provide a simple, flexible tool to optimize the clock rise/fall time for specific applications. Benefits from the programmable drive strength feature are: • Improves system radiated electromagnetic interference (EMI) by slowing down the clock rise/fall time. • Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time. • Ability to drive large capacitive loads while maintaining full swing with sharp edge rates. For more detailed information about rise/fall time control and drive strength selection, see the SiTime Application Notes section: http://www.sitime.com/support/application-notes. EMI Reduction by Slowing Rise/Fall Time Figure 16 shows the harmonic power reduction as the rise/fall times are increased (slowed down). The rise/fall times are expressed as a ratio of the clock period. For the ratio of 0.05, the signal is very close to a square wave. For the ratio of 0.45, the rise/fall times are very close to near-triangular waveform. These results, for example, show that the 11th clock harmonic can be reduced by 35 dB if the rise/fall edge is increased from 5% of the period to 45% of the period.   trise=0.05 0 Harmonic amplitude (dB) SiT2019 Drive Strength Selection Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage. 1. Select the table that matches the SiT2019 nominal supply voltage (1.8V, 2.5V, 2.8V, 3.0V, 3.3V). 2. Select the capacitive load column that matches the application requirement (5 pF to 30 pF) 3. Under the capacitive load column, select the desired rise/fall times. 4. The left-most column represents the part number code for the corresponding drive strength. 5. Add the drive strength code to the part number for ordering purposes. Calculating Maximum Frequency Based on the rise and fall time data given in Tables 7 through 11, the maximum frequency the oscillator can operate with guaranteed full swing of the output voltage over temperature can be calculated as follows: trise=0.1 trise=0.15 trise=0.2 10 M a x F re q u e n c y = trise=0.25 trise=0.3 trise=0.35 trise=0.4 trise=0.45 -10 -20 1 5 x T rf_ 2 0 /8 0 where Trf_20/80 is the typical value for 20%-80% rise/fall time. -30 -40 Example 1 -50 -60 Calculate fMAX for the following condition: -70 -80 The SiT2019 can support up to 30 pF in maximum capacitive loads with up to 3 additional drive strength settings. Refer to the Rise/Tall Time Tables (Table 7 to 11) to determine the proper drive strength for the desired combination of output load vs. rise/fall time. 1 3 5 7 9 11 Harm onic num ber Figure 16. Harmonic EMI reduction as a Function of Slower Rise/Fall Time Jitter Reduction with Faster Rise/Fall Time Power supply noise can be a source of jitter for the downstream chipset. One way to reduce this jitter is to speed up the rise/fall time of the input clock. Some chipsets may also require faster rise/fall time in order to reduce their sensitivity to this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to Table 11) to determine the proper drive strength. • Vdd = 3.3V (Table 11) • Capacitive Load: 30 pF • Desired Tr/f time = 1.46 ns (rise/fall time part number code = U) Part number for the above example: SiT2019AIU12-33E-136.986300 Drive strength code is inserted here. Default setting is “-” High Output Load Capability The rise/fall time of the input clock varies as a function of the actual capacitive load the clock drives. At any given drive strength, the rise/fall time becomes slower as the output load increases. As an example, for a 3.3V SiT2019 device with default drive strength setting, the typical rise/fall time is 0.46 ns for 5 pF output load. The typical rise/fall time slows down to 1 ns when the output load increases to 15 pF. One can choose to speed up the rise/fall time to 0.72 ns by then increasing the driven strength setting on the SiT2019 to “F.” Rev. 1.0 Page 7 of 12 www.sitime.com SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Rise/Fall Time (20% to 80%) vs CLOAD Tables Table 7. Vdd = 1.8V Rise/Fall Times for Specific CLOAD Table 8. Vdd = 2.5V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ C LOAD 5 pF 15 pF 30 pF Drive Strength \ C LOAD 5 pF 15 pF 30 pF T 0.93 n/a n/a R 1.45 n/a n/a E 0.78 n/a n/a B 1.09 n/a n/a U 0.70 1.48 n/a 0.62 1.28 n/a 0.65 1.30 n/a T E 0.54 1.00 n/a 0.43 0.96 n/a 0.34 0.88 n/a F or "-": default U or "-": default F Table 9. Vdd = 2.8V Rise/Fall Times for Specific CLOAD Table 10. Vdd = 3.0V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ C LOAD 5 pF 15 pF 30 pF Drive Strength \ CLOAD 5 pF 15 pF 30 pF R 1.29 n/a n/a R 1.22 n/a n/a B 0.97 n/a n/a n/a n/a 0.55 1.12 n/a B T or "-": default 0.89 T E 0.51 1.00 n/a 0.44 1.00 n/a E 0.38 0.92 n/a 0.34 0.88 n/a 0.83 n/a 0.81 1.48 U F 0.30 0.29 0.27 0.76 1.39 U or "-": default F Table 11. Vdd = 3.3V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF R 1.16 n/a n/a B T or "-": default 0.81 n/a n/a 0.46 1.00 n/a E 0.33 0.87 n/a U F 0.28 0.79 1.46 0.25 0.72 1.31 Note: 12. “n/a” in Table 7 to Table 11 indicates that the resulting rise/fall time from the respective combination of the drive strength and output load does not provide rail-to-rail swing and is not available. Rev. 1.0 Page 8 of 12 www.sitime.com SiT2019 High Frequency, High Temp, One-Output Clock Generator The Smart Timing Choice The Smart Timing Choice Pin 3 Configuration Options (OE, ST, or NC) Pin 3 of the SiT2019 can be factory-programmed to support three modes: Output Enable (OE), standby (ST) or No Connect (NC). These modes can also be programmed with the Time Machine using field programmable devices. In addition, the SiT2019 has “no runt” pulses, and “no glitch” output during startup or resume as shown in the waveform captures in Figure 17 and Figure 18. Output Enable (OE) Mode In the OE mode, applying logic Low to the OE pin only disables the output driver and puts it in Hi-Z mode. The core of the device continues to operate normally. Power consumption is reduced due to the inactivity of the output. When the OE pin is pulled High, the output is typically enabled in
SIT2019AEES-28S 价格&库存
很抱歉,暂时无法提供与“SIT2019AEES-28S”相匹配的价格&库存,您可以联系我们找货
