SIT5721AC-KW333-T-24.57600F 数据手册
SiT5721
1 to 60 MHz, Stratum 3E
DCOCXO
The SiT5721 is the industry’s
smallest Stratum 3E digitally
controlled OCXO with ±5 ppb
frequency stability and 150
ppt/°C frequency slope (ΔF/ΔT). This device is engineered to provide the best
dynamic performance. Leveraging SiTime’s unique DualMEMS™ and
TurboCompensation™ temperature sensing technology, this DCOCXO delivers
the most stable timing in the presence of environmental stressors such as
airflow, temperature perturbation, vibration, shock, and electromagnetic
interference (EMI).
The environmental robustness of SiT5721 enables unmatched ease-of-use and
simplifies system design:
Can be placed anywhere on the PCB
No mechanical cover or shielding needed for thermal isolation
No external regulators required
No additional sealing needed for high humidity environments
The SiT5721 can be factory-programmed to any frequency between 1 and 60
MHz. In addition to industry leading performance, the DCOCXO is offered in a 9
x 7 mm package, the smallest Stratum 3E OCXO available.
Oscillator Type
DCOCXO
Frequency
1 to 60 MHz
Frequency Stability (ppm)
±0.005 (±5 ppb), ±0.008 (±8 ppb)
Operating Temperature
Range (°C)
-20 to 70, -40 to +80
Output type
LVCMOS, Clipped sinewave
Package Type (mm²)
9.0 x 7.0
Features
Frequency Slope: ±150 ppt/°C; Contact SiTime for ±3
ppb stability; Contact SiTime for -40° to 105°C;
Voltage Supply (V)
3.3
Pull Range (ppm)
±6.25
Availability
Sampling
10 times better dynamic stability under airflow and fast temp. ramp, ensures best
system performance in harsh environments
±5 ppb over-temp. stability
2e-11 ADEV at 10 sec under airflow
±150 ppt/°C frequency slope (ΔF/ΔT)
Unmatched ease-of-use, simplifying system design
No restrictions on PCB placement
No mechanical shielding needed for thermal isolation
Resistant to humidity
No external regulator needed
Smallest size, ideal for high density and small form factor systems
9 x 7 mm footprint, 75% smaller
6.5 mm height, 40% thinner
20 times better vibration resistance, ideal for outdoor pole mounted equipment
Resistant to microphonic and/or board bending effects, ideal for large telecom
PCBs
Programmable platform eliminates long lead times and customization cost
associated with legacy quartz DCOCXO
Any frequency from 1 to 60 MHz
LVCMOS or clipped sine-wave outputs
On-chip regulators, no need for external LDOs or ferrite beads
Semiconductor-level quality and reliability, batch to batch consistency
No activity dips or micro jumps
Applications
SONET/SDH Stratum 3E
4G/5G RRH, DU
Base Stations
Core and edge routers
Carrier class switches
IEEE 1588 boundary clocks
IEEE 1588 grandmasters
GNSS disciplined timing modules
Instrumentation
Power & energy
Defense & aerospace
Long-range communications
https://www.sitime.com/products/stratum‐3e‐dcocxos/sit5721/3‐26‐20
SIT5721AC-KW333-T-24.57600F 价格&库存
很抱歉,暂时无法提供与“SIT5721AC-KW333-T-24.57600F”相匹配的价格&库存,您可以联系我们找货
