SKELMOD 102V
SKELMOD 102V
    SKELETON
    模块
    88 F (EDLC) 超级电容器 102 V 模块 7.6 毫欧 65°C 时为 1500 小时
SKELMOD 102V 数据手册
+ 102V DC nominal voltage + Ultra-low ESR + Long lifetime - 1 million duty cycles + Integrated Ultracapacitor Management System for effective cell balancing + CAN bus communication + 19 inch rack system compatible SMA102V88FAF TECHNICAL UNIT VALUE SPECIFICATIONS Electrical Nominal voltage V 102 Absolute maximum voltage V 108 Rated capacitance F 88 Rated DC 10ms ESR mΩ 6.2 Rated DC 1s ESR mΩ 7.6 Specific energy3 Wh/kg 4.8 Energy density4 Wh/L 4.3 Maximum series voltage VDC 1500* Rated maximum peak current (for 1 s duration)1 A 2689 Typical short circuit current kA 21.25 Maximum stored energy2 Wh 127.1 Rated nominal power (DC 10ms ESR): Power5 kW 419.5 Specific power6 kW/kg 15.8 Power density7 kW/L 14.2 Rated practical power (DC 1s ESR): Power5 kW 342.2 Specific power6 kW/kg 12.9 Power density7 kW/L 11.6 Cells in total pcs 36 Cell type SCA3200 Life* Life at 102 V and maximum operating temperature Shelf life @ RT, uncharged Projected cycle life @ RT between 102 V and 56 V Temperature Operating temperature range Storage temperature range Ultracapacitor management system Nominal auxiliary supply voltage Auxiliary supply voltage range Constant current consumption at 24V DC Cell balancing method Temperature monitor Voltage monitor Communication interface Connectors Power connector Signal connectors Connector location Hours 1500 Years 10 Cycles 1 000 000 °C °C -20 to +60* -40 to +50 V 24 V 16-33 A 0.07** Controlled resistive balancing 6 NTC sensors Individual Cell CAN bus 2.0B Ø 13.5 mm Trough hole D-sub DE-9 Male D-sub DE-9 Female Front Copyright © 2020 Skeleton Technologies GmbH. All rights reserved. 02-SMR-200325-2A Page 1/2 SMA102V88FAF TECHNICAL SPECIFICATIONS UNIT VALUE Standards International protection marking (for enclosure) Isolation protection EMC immunity EMC emissions IEC 60529, IP 20 IEC 62477-1, OVC2, PD2 IEC 61000-6-2 IEC 61000-6-3 Thermal parameters*** Thermal resistance given at ΔT 30 °C (Rth) °C/W Thermal capacitance (Cth) kJ/°C Maximum continuous current (at ΔT 15 °C) A Maximum continuous current (at ΔT 30 °C) A Maximum continuous current (at ΔT 40 °C) A Physical parameters Typical mass kg Typical volume L 0.065 25 172 245 281 26.5 29.6 76.25 152.5 424 76.9 24.7 13.1 501.5 450 4 24.7 480 13.5 THRU 31.5 465 486 449 27 2X 21.75 9 THRU 253 480 * For maximum series voltage IE32 (EN 60721-3-3) requirements must be followed. For lower temperature contact Skeleton Technologies ** Inrush current for the auxiliary supply: 0.18A *** Thermal parameters given for cooling airflow rate of 85CFM 5 2 3 4 6 7 8 + Name of Manufacturer, Part number, Serial number, Rated voltage + Rated capacitance, Negative and positive terminals, Warning marking + Total energy in watt-hours + All information provided on this data sheet and all subsequent ultracapacitors sales and testing are subject to Standard Terms of Service (ToS) available on www.skeletontech.com, document General Terms of Sale for Skeleton Technologies OÜ Skeleton Technologies GmbH Sales and Headquarters Schücostraße 8, 01900 Großröhrsdorf, Germany info@skeletontech.com www.skeletontech.com Copyright © 2020 Skeleton Technologies GmbH. All rights reserved. 02-SMR-200325-2A Page 2/2
SKELMOD 102V 价格&库存
很抱歉,暂时无法提供与“SKELMOD 102V”相匹配的价格&库存,您可以联系我们找货
