SFC6V250
SFC6V250
    SMCDIODESOLUTIONS(桑德斯)
    DIODE ZENER SILICON 6.2V 20MA 10
SFC6V250 数据手册
SFC5V650-SFC1250 Technical Data Data Sheet N2075, Rev. - SFC5V650 Thru SFC1250 Flip Chip Zener Diode Features       Zener Voltage: 5.6V 6.2V 6.8V 10V 12V Case: WLCSP Space saving, low profile Very small dimensions:1.0mm*0.6mm*0.28mm 20mA forward current 500mW Power dissipation Case: WLCSP Applications Circuit Diagram  Voltage Regulation  Voltage Reference  Protection and Clamping Maximum Ratings: Characteristics Symbol Condition Max. Units Nominal Power Dissipation PD Derate above 25℃ 500 mW Forward Voltage VF @IF=10mA, Pulse, TJ=25℃ 0.9 V Operating Temperature Range TJ - -55 to +150 C Storage Temperature Range Tstg - -55 to +150 C  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SFC5V650-SFC1250 Technical Data Data Sheet N2075, Rev. - Electrical Characteristics @ TJ=25 C: Zener voltage Device SFC5V650 SFC6V250 SFC6V850 SFC1050 SFC1250 Zener Impedence Leakage Current Max. Max. ZZT @ IZT ZZK @ IZK mA Ω Ω mA uA Volts 20 20 20 20 20 11 7 5 17 30 1600 1000 750 600 600 0.25 0.25 0.25 0.25 0.25 5 5 3 3 1 3 4 5 8 9.1 Nom. VZ ① @ IZT Volts 5.6 6.2 6.8 10 12 @ IZK Max. IR @ VR Note: ①Vz Tolerance is ±5% Ordering Information: Device SFC5V650-SFC1250 Package Plating Shipping WLCSP Cu+Sn 6000pcs/reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SFC5V650-SFC1250 Technical Data Data Sheet N2075, Rev. - Mechanical Dimensions (in millimeters:WLCSP) mechanical size(mm) Item Material A Si A1 Cu 0.008 A2 Sn 0.003 A3 PI min typ max 0.240 0.260 0.280 0.003 b 0.004 0.005 0.500 L2 0.200 0.250 0.300 L3 0.200 0.250 0.300 e 0.650 D 0.590 0.63 E 0.990 1.03  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SFC5V650-SFC1250 Technical Data Data Sheet N2075, Rev. - Carrier Tape and Reel Specification(in millimeters) Marking Diagram XX WW YY ║ WW YY XX = cathode = week code = year code = device code Where 56 =SFC5V650 62 =SFC6V250 68 =SFC6V850 10 =SFC1050 12 =SFC1250  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  SFC5V650-SFC1250 Technical Data Data Sheet N2075, Rev. DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
SFC6V250 价格&库存
很抱歉,暂时无法提供与“SFC6V250”相匹配的价格&库存,您可以联系我们找货
