IX40AM-IX40AM-CAT6A05
    SINBON(信邦)
    CABLE MOD 10P10C PLG - PLG 1.64
IX40AM-IX40AM-CAT6A05 数据手册
1 2 MOLD TYPE CONN1 OVERMOLD CONN1 OVERMOLD MOLD NO. SRO0847 SRO0848 3 4 5 6 ITEM REV. 5,6 4 01 ECN NO. 7 DATE BY Sep/03/2020 Aine Li 8 DESCRIPTION RELEASED A A 500.0 +20.0 -0 5.7±0.4 P1 34.0±0.5 34.0±0.5 5.7±0.4 P10 CONN 2 CONN 1 B P5 P6 1 26 D NOTES: 1. TESTING SPEC.: COND. RESISTANCE: 3Ω MAX. INSUL. RESISTANCE: 10MΩ MIN. TESTING VOLTAGE: 200V DC 2. FOLLOW IPC620 CLASS II STANDARD TO ASSEMBLY AND INSPECTION. 3. RoHS COMPLIANCE. P1 2 3 4 5 6 AWG C B P10 2 3 4 5 6 E P5 P6 WIRE RUN LIST CONN 1 1 2 4 5 6 7 9 10 SHELL COLOR BLUE WHITE ORANGE WHITE WHITE GREEN WHITE BROWN SHIELD CONN 2 1 2 4 5 6 7 9 10 SHELL C 6. 5. 4. 3. 2. A/R A/R A/R 2 2 1. A/R ITEM QTY D PLASTIC MASTERBATCH,BLACK,FOR TPU(A88270010001SD) TPU,SHORE A 78,NATURAL,POLYETHER,UL94V-0,HF (A51100057001SD) TPU,94A,BLACK,UL94V-0(A51100051001SD) COPPER FOIL, (W)5*(L)30mm (A4060020200SD) CONN., 10P, BLACK, HRS: IX40G-A-10S-CV(7.0) (A20151893001S) CABLE, ULCM, #26*4P+AM+B, BLACK, OD=6.0, CAT 6A (JPCW2421) DESCRIPTION THIS DRAWING CONTAINS CONFIDENTIAL INFORMATION AND IS THE PROPERTY OF SINBON ELECTRONICS CO., LTD. IT MAY NOT BE USED OR ITS CONTENTS COPIED OR DISCLOSED TO A THIRD PARTY WITHOUT PRIOR WRITTEN CONSENT AND IS TO BE RETURNED PROMPTLY UPON REQUEST BY SINBON ELECTRONICS CO., LTD. CUSTOMER : DigiKey CUSTOMER P/N : REV. N/A N/A UNLESS OTHERWISE SPECIFIED DRA. TOLERANCE : 1 ~ 10 11 ~ 30 31 ~ 50 51 ~ 200 201 ~ 400 > 401 ANGLES : : : : : : : ±1 ±2 ±3 ±5 ±7 ± 10 ± 1° Sep/03/2020 Aine Li CHK. Sep/03/2020 Kevin Qiu APR. Sep/03/2020 Kevin Qiu E SINBON Electronics Co., Ltd. DESCRIPTION : IX(M) to IX(M), Cat6A, 500mm PART NUMBER : REV. 01 IX40AM-IX40AM-CAT6A05 SIZE A3 UNIT SCALE mm NONE SHEET 1 of 1 GDP-D-071 A
IX40AM-IX40AM-CAT6A05 价格&库存
很抱歉,暂时无法提供与“IX40AM-IX40AM-CAT6A05”相匹配的价格&库存,您可以联系我们找货
