M12A-05CFSFS-UL24N10
    SINBON(信邦)
    CBL 5POS FMALE TO FMALE 3.28
M12A-05CFSFS-UL24N10 数据手册
1 3 2 MOLD TYPE CONN. OVERMOLD CONN. COVER 4 5 6 MOLD NO. ITEM REV. CPO0220 PPO0239 4,5 6 01 ECN NO. 7 DATE BY Sep/03/2020 Aine Li 8 DESCRIPTION RELEASED A A 1000.0 +50.0 -0 44.4(1.748") 49.7(1.957") P1 CONN 1 M12 B P5 3 4 5 6 2 4 5 6 AWG 24 P3 P2 1 C B CONN 2 P2 P3 P4 P1 M12 P4 WIRE RUN LIST CONN 1 COLOR 1 BROWN 2 WHITE 3 BLUE 4 BLACK 5 GRAY P5 C CONN 2 1 2 3 4 5 D E D NOTES: 1. TESTING SPEC.: COND. RESISTANCE: 3Ω MAX. INSUL. RESISTANCE: 10MΩ MIN. TESTING VOLTAGE: 300V DC 2. IP67 WHEN MATED. 3. FOLLOW IPC620 CLASS II STANDARD TO ASSEMBLY AND INSPECTION. 4. RoHS COMPLIANCE. 6. 5. 4. 3. 2. 1. A/R A/R A/R 1 1 A/R ITEM QTY PE,TRANS-CLEAR,PE101(A50800001002SD) TPU, SHORE A 78, NATURAL, HF (A51100057001SD) PLASTIC MASTERBATCH,BLACK,FOR TPU(A51700027001SD) I/O CONN., MALE, 5P (A30510637001SD) I/O CONN., FEMALE, 5P (A30510638001SD) CABLE, UL20549, #24*5C+AEB, 0D=5.2 (HT1702266) DESCRIPTION THIS DRAWING CONTAINS CONFIDENTIAL INFORMATION AND IS THE PROPERTY OF SINBON ELECTRONICS CO., LTD. IT MAY NOT BE USED OR ITS CONTENTS COPIED OR DISCLOSED TO A THIRD PARTY WITHOUT PRIOR WRITTEN CONSENT AND IS TO BE RETURNED PROMPTLY UPON REQUEST BY SINBON ELECTRONICS CO., LTD. CUSTOMER : DigiKey CUSTOMER P/N : REV. N/A N/A UNLESS OTHERWISE SPECIFIED DRA. TOLERANCE : 1 ~ 10 11 ~ 30 31 ~ 50 51 ~ 200 201 ~ 400 > 401 ANGLES : : : : : : : ±1 ±2 ±3 ±5 ±7 ± 10 ± 1° Sep/03/2020 Aine Li CHK. Sep/03/2020 Kevin Qiu APR. Sep/03/2020 Kevin Qiu E SINBON Electronics Co., Ltd. DESCRIPTION : 5P female-male anti-vibe IP67, 1M PART NUMBER : REV. 01 M12A-05CFSMS-UL24N10 SIZE A3 UNIT SCALE mm NONE SHEET 1 of 1 GDP-D-071 A
M12A-05CFSFS-UL24N10 价格&库存
很抱歉,暂时无法提供与“M12A-05CFSFS-UL24N10”相匹配的价格&库存,您可以联系我们找货
