M12X-08CMS00-UL24N30
    SINBON(信邦)
    CBL 8POS MALE TO MALE 9.84
M12X-08CMS00-UL24N30 数据手册
1 3 2 MOLD TYPE CONN1 OVERMOLD 4 5 6 MOLD NO. ITEM REV. CPO0241 3,4 01 ECN NO. 7 DATE BY Sep/03/2020 Aine Li 8 DESCRIPTION RELEASED A A 3000.0 +100.0 -0 50.58(1.991") CONN 1 B P2 P7 P8 CONN 2 M12 P3 P6 P8 P1 P4 M12 P5 50.58(1.991") P1 1 2 3 4 AWG C 24 CONN 1 1 2 3 4 5 6 7 8 P7 P2 P3 P6 P5 P4 2 3 4 B WIRE RUN LIST COLOR CONN 2 1 WHITE/ORANGE 2 ORANGE 3 WHITE/GREEN 4 GREEN WHITE/BROWN 5 6 BROWN 7 WHITE/BLUE 8 BLUE C D E D NOTES: 1. TESTING SPEC.: COND. RESISTANCE: 3Ω MAX. INSUL. RESISTANCE: 10MΩ MIN. TESTING VOLTAGE: 300V DC 2. IP67 WHEN MATED. 3. FOLLOW IPC620 CLASS II STANDARD TO ASSEMBLY AND INSPECTION. 4. RoHS COMPLIANCE. 4. 3. 2. 1. A/R A/R 2 A/R ITEM QTY TPU, SHORE A 78, NATURAL, HF (A51100057001SD) PLASTIC MASTERBATCH,BLACK,FORTPU(A88270010001SD) I/O CONN., MALE, 8P, (A30140235001SD) CABLE, CAT.6, UTP PATCH CABLE, #24*4P, OD=5.6 DESCRIPTION THIS DRAWING CONTAINS CONFIDENTIAL INFORMATION AND IS THE PROPERTY OF SINBON ELECTRONICS CO., LTD. IT MAY NOT BE USED OR ITS CONTENTS COPIED OR DISCLOSED TO A THIRD PARTY WITHOUT PRIOR WRITTEN CONSENT AND IS TO BE RETURNED PROMPTLY UPON REQUEST BY SINBON ELECTRONICS CO., LTD. CUSTOMER : DigiKey CUSTOMER P/N : REV. N/A N/A UNLESS OTHERWISE SPECIFIED DRA. TOLERANCE : 1 ~ 10 11 ~ 30 31 ~ 50 51 ~ 200 201 ~ 400 > 401 ANGLES : : : : : : : ±1 ±2 ±3 ±5 ±7 ± 10 ± 1° Sep/03/2020 Aine Li CHK. Sep/03/2020 Kevin Qiu APR. Sep/03/2020 Kevin Qiu E SINBON Electronics Co., Ltd. DESCRIPTION : 8P M-M, X code anti-vibe IP67, 3M PART NUMBER : REV. 01 M12X-08CMS00-UL24N30 SIZE A3 UNIT SCALE mm NONE SHEET 1 of 1 GDP-D-071 A
M12X-08CMS00-UL24N30 价格&库存
很抱歉,暂时无法提供与“M12X-08CMS00-UL24N30”相匹配的价格&库存,您可以联系我们找货
