M12X-08PM0-UL24N05
M12X-08PM0-UL24N05
    SINBON(信邦)
    CBL 8POS MALE TO WIRE 1.64
M12X-08PM0-UL24N05 数据手册
1 3 2 4 5 6 REV. 01 ECN NO. 7 DATE BY Sep/03/2020 Aine Li 8 DESCRIPTION RELEASED A A 500.0 +20.0 -0 21.2(0.835") P8 P6 P5 B CONN 1 P1 P2 B M12 P7 P4 C AWG 24 D E NOTES: 1. TESTING SPEC.: COND. RESISTANCE: 3Ω MAX. INSUL. RESISTANCE: 10MΩ MIN. TESTING VOLTAGE: 200V DC 2. IP67 WHEN MATED. 3. FOLLOW IPC620 CLASS II STANDARD TO ASSEMBLY AND INSPECTION. 4. RoHS COMPLIANCE. 1~ 8 9 10 P3 WIRE RUN LIST CONN 1 COLOR 1 BROWN 2 WHITE 3 BLUE 4 BLACK 5 GRAY 6 GREEN YELLOW 7 8 ORANGE C 10. 9. 8. 7. 6. 5. 4. 3. 2. 1. A/R 1 A/R A/R A/R A/R A/R A/R A/R A/R ITEM QTY HEAT SHRINK TUBE,UL224,1Q,BLACK,ID=1.3,T=0.2(A5340000000SD) M12 CONN., X-CODE, MALE, 8P(A30140219001SD) HOOK-UP WIRE, UL1213 #24, WHITE, OD=0.98, PTFE (A10902921001SD) HOOK-UP WIRE, UL1213 #24, BLACK, OD=0.98, PTFE (A10902920001SD) HOOK-UP WIRE, UL1213 #24, GREEN, OD=0.98, PTFE (A10902916001SD) HOOK-UP WIRE, UL1213 #24, YELLOW, OD=0.98, PTFE (A10902917001SD) HOOK-UP WIRE, UL1213 #24, ORANGE, OD=0.98, PTFE (A10902918001SD) HOOK-UP WIRE, UL1213 #24, BROWN, OD=0.98, PTFE (A10902919001SD) HOOK-UP WIRE, UL1213 #24, GRAY, OD=0.98, PTFE (A10902913001SD) HOOK-UP WIRE, UL1213 #24, BLUE, OD=0.98, PTFE (A10902912001SD) D DESCRIPTION THIS DRAWING CONTAINS CONFIDENTIAL INFORMATION AND IS THE PROPERTY OF SINBON ELECTRONICS CO., LTD. IT MAY NOT BE USED OR ITS CONTENTS COPIED OR DISCLOSED TO A THIRD PARTY WITHOUT PRIOR WRITTEN CONSENT AND IS TO BE RETURNED PROMPTLY UPON REQUEST BY SINBON ELECTRONICS CO., LTD. CUSTOMER : DigiKey CUSTOMER P/N : REV. N/A N/A UNLESS OTHERWISE SPECIFIED DRA. TOLERANCE : 1 ~ 10 11 ~ 30 31 ~ 50 51 ~ 200 201 ~ 400 > 401 ANGLES : : : : : : : ±1 ±2 ±3 ±5 ±7 ± 10 ± 1° Sep/03/2020 Aine Li CHK. Sep/03/2020 Kevin Qiu APR. Sep/03/2020 Kevin Qiu E SINBON Electronics Co., Ltd. DESCRIPTION : 8P male rear, X code IP67, 500mm PART NUMBER : M12X-08PM0-UL24N05 SIZE A3 UNIT SCALE mm NONE REV. 01 SHEET 1 of 1 GDP-D-071 A
M12X-08PM0-UL24N05 价格&库存
很抱歉,暂时无法提供与“M12X-08PM0-UL24N05”相匹配的价格&库存,您可以联系我们找货
