U.FLP-FAKRADP-88150
U.FLP-FAKRADP-88150
    SINBON(信邦)
    ECT TO FAKRA CODE D, 1.37MM, 150
U.FLP-FAKRADP-88150 数据手册
1 2 3 4 5 6 REV. 01 ECN NO. 7 DATE BY Sep/03/2020 Aine Li 8 DESCRIPTION RELEASED A A 150.0±5.0 6.8±0.2 2.0±0.2 17.25±0.20 15.0±2.0 B B 5 1~ 3 DOUBLE SIDE RUBBER 5.3 6 4 C 3.0±0.2 C D E NOTES: 1. ELECTRICAL SPECIFICATION: 1.1 IMPEDANCE: 50 Ω 1.2 FREQUENCY RANGE: 0~4GHZ 1.3 VSWR: 1.5 MAX. 1.4 INSERTION LOSS: 1dB MAX. 1.5 VOLTAGE RATING: 60VAC 1.6 DIELECTRIC WITHSTANDING VOLTAGE: 200V 1.7 INSULATION RESISTANCE: 100M Ω 1.8 CONTACT CENTER RESISTANCE: 100 m Ω 1.9 CONTACT OUTER RESISTANCE: 100 m Ω 2. MECHANICAL SPECIFICATION: 2.1 CENTER CONTACT RETENTION FORCE: 10N Min 2.2 CABLE RETENTION FORCE: 10N Min 2.3 FORCE TO DISENGAGE: 3N Min.(U .FL) 2.4 DURABILITY: 30 CYCLES(U .FL) 100 CYCLES (FAKRA) 3. ENVIRONMENTAL CHARACTERISTICS 3.1 OPERATION TEMPERATURE: -40°C~+85°C 4. RoHS COMPLIANCE. D 6. 5. 4. 3. 2. 1. 1 A/R 1 1 1 1 ITEM QTY FAKRA MALE, TYPE D H.S. TUBE, BLACK CABLE 1.37, BLACK JACK, COPPER, TIN PLATED CONTACT, COPPER ALLOY, AU PLATED OVER NICKEL HSG, HIGHT TEMP, PLASTIC, UL94V-0, BLACK SHELL, COPPER ALLOY, AU PLATED OVER NICKEL DESCRIPTION THIS DRAWING CONTAINS CONFIDENTIAL INFORMATION AND IS THE PROPERTY OF SINBON ELECTRONICS CO., LTD. IT MAY NOT BE USED OR ITS CONTENTS COPIED OR DISCLOSED TO A THIRD PARTY WITHOUT PRIOR WRITTEN CONSENT AND IS TO BE RETURNED PROMPTLY UPON REQUEST BY SINBON ELECTRONICS CO., LTD. CUSTOMER : DigiKey CUSTOMER P/N : REV. N/A N/A UNLESS OTHERWISE SPECIFIED DRA. TOLERANCE : 1 ~ 10 11 ~ 30 31 ~ 50 51 ~ 200 201 ~ 400 > 401 ANGLES : : : : : : : ±1 ±2 ±3 ±5 ±7 ± 10 ± 1° Sep/03/2020 Aine Li CHK. Sep/03/2020 Kevin Qiu APR. Sep/03/2020 Kevin Qiu E SINBON Electronics Co., Ltd. DESCRIPTION : ECT to Fakra Code D, 1.37mm, 150mm PART NUMBER : U.FLP-FakraDP-88150 SIZE A3 UNIT SCALE mm NONE REV. 01 SHEET 1 of 1 GDP-D-071 A
U.FLP-FAKRADP-88150 价格&库存
很抱歉,暂时无法提供与“U.FLP-FAKRADP-88150”相匹配的价格&库存,您可以联系我们找货
