SRLX216S00D00GE064C08CH
    SOLIDRUN
    SBC 2.2GHZ 16 CORE -/64GB RAM
SRLX216S00D00GE064C08CH 数据手册
ClearFog CX LX2K Datasheet NXP Layerscape LX2160A based networking platform SolidRun Ltd. Embedded Edge Computing 7 Hamada st., Yokne’am Illit, 2069201, Israel www.solid-run.com Overview ClearFog CX LX2K is a robust embedded Mini ITX platform designed for the COM Express type 7 form factor – offering a flexible and feature-rich carrier for the outstanding network computing Layerscape LX2160A 16-core Arm processor. This carrier board features an array of 4 x 10GbE SFP+ (2×2) connectors, QSFP28 100GbE cage and 1 x 1GbE RJ45 port. Other features include 3 x USB 3.0 and 3 x USB 2.0 port, PCIe x8 (open port), 4 x SATA, up to 64GB DDR4 memory, eMMC, optional M.2, microSD, and GPIO header. ClearFog CX LX2K Highlighted Features NXP’s Layerscape LX2160A 16-core Cortex Arm A72 (2GHz) processor Dual-channel DDR4 SO-DIMM (up to 64GB) 4 x SFP+ (10GbE each) QSFP28 cage 100Gbps Mini ITX form factor supporting easy mounting in a wide range of cases, enclosures and tower configurations 2 | Page Document revision 1.2 10052020 SolidRun Ltd. System Specifications ClearFog CX LX2K Processor NXP LX2160A 16-core Cortex Arm A72 (up to 2Ghz) Memory & Storage Cooling Up to 64GB DDR4 SO-DIMM (dual channel) M.2 2240/2280 MicroSD 4 x SATA 3.0 eMMC 4 x SFP+ ports (2 x 2 cage) 1 x QSFP28 cage (100Gbps) 1 x 1GbE (RJ45) 3 x USB 2.0 3 x USB 3.0 1 x PCIe x8 (open slot) MicroUSB for debug (UART over USB) USB to STM32 for remote management Linux kernel 4.14x Mainline Linux CPU air-cooled with heatsink + fan configuration Power ATX Standard Environment Ambient temp. (commercial): 0°C to 70°C CPU die temp. (commercial): 0°C to 105°C Ambient temp. (industrial): -40°C to 85°C CPU die temp. (industrial): -40°C to 105°C Humidity (non-condensing): 10% - 90% Dimensions (WxL) 170mm X 170mm Enclosure Not included Supports mini ITX form factor enclosures Connectivity & Interfaces I/O OS Available SKUs for ClearFog CX LX2K SKU Description SRLX216S00D00GE064C04CH ClearFog CX LX2K|64GB eMMC|Com. Temp|R04|Inc. Heatsink & Fan SRLX216S00D00GE064C04IH ClearFog CX LX2K|64GB eMMC|Ind. Temp|R04|Inc. Heatsink & Fan (*) Different configurations available for MOQ 3 | Page Document revision 1.2 10052020 SolidRun Ltd. ClearFog CX LX2K Layout *open slot ClearFog CX LX2K Layout 4 | Page Document revision 1.2 10052020 SolidRun Ltd. Safety Notice a. This device is to be used with Certified Power adaptor with output rated 12VDC, 1.5A. Power adapter must meet Limited power source (LPS) requirements. b. Power adapter must meet local safety standards and requirements based on product intended use. c. Power adapter must meet Operating environment conditions as specified above. Disposal Follow local regulations regarding disposal of the product. Dispose of your product in accordance with local regulations. In some areas, the disposal of these items in household or business trash may be prohibited. Help us protect the environment – recycle! IMPORTANT NOTICE – Please Read Carefully No warranty of accuracy is given concerning the contents of the information contained in this document. To the extent permitted by law no liability (including liability to any person by reason of negligence) will be accepted by SolidRun ltd. or its employees for any direct or indirect loss or damage caused by omissions from or inaccuracies in this document. SolidRun ltd. reserves the right to change details in this publication without notice Product and company names herein may be the trademarks of their respective owners. Information in this document supersedes and replaces information previously supplied in any prior versions of this document. Support For technical support please visit: Our developer resources – https://developer.solid-run.com/ For direct support please contact us at: support@solid-run.com Documentation Additional documentation available at: https://developer.solid-run.com/products/clearfog-cx-lx2k/ 5 | Page Document revision 1.2 10052020 SolidRun Ltd.
SRLX216S00D00GE064C08CH 价格&库存
很抱歉,暂时无法提供与“SRLX216S00D00GE064C08CH”相匹配的价格&库存,您可以联系我们找货
