SRLX216S00D00GE064H09CH
    SOLIDRUN
    SBC 2GHZ 16 CORE -/64GB RAM
SRLX216S00D00GE064H09CH 数据手册
HoneyComb LX2K Datasheet NXP Layerscape LX2160A based Arm Workstation SolidRun Ltd. Embedded Edge Computing 7 Hamada st., Yokne’am Illit, 2069201, Israel www.solid-run.com Overview Introducing HoneyComb LX2K cutting-edge Arm workstation – designed for native Arm development and demanding computing and networking needs. HoneyComb is based on NXP’s Layscape 16 core LX2160A Arm Cortex A72 processor, and features 2 x SFP+ (10GbE each), dual channel DDR4 SO-DIMM RAM (up to 64GB), 3 x USB 3.0 and 3 x USB 2.0, 4 x SATA, 64GB on-board eMMC, M.2, PCIe x8 open slot (can support x16), and much more. HoneyComb Highlighted Features NXP’s Layerscape LX2160A 16-core Cortex Arm A72 (2GHz) processor Dual-channel DDR4 SO-DIMM (up to 64GB) 4 x SFP+ (10GbE each) Mini ITX form factor supporting easy mounting in a wide range of cases, enclosures and tower configurations 2 | Page Document revision 1.3 10052020 SolidRun Ltd. System Specifications HoneyComb LX2K Processor NXP LX2160A 16-core Cortex Arm A72 (up to 2Ghz) Memory & Storage Cooling Up to 64GB DDR4 SO-DIMM (dual channel) M.2 2240/2280 MicroSD 4 x SATA 3.0 eMMC 4 x SFP+ ports (2x2) 1 x 1GbE (RJ45) 3 x USB 2.0 3 x USB 3.0 1 x PCIe x8 (open slot) MicroUSB for debug (UART over USB) USB to STM32 for remote management Linux kernel 4.14x Mainline Linux CPU air-cooled with heatsink + fan configuration Power ATX Standard Environment Ambient temp. (commercial): 0°C to 70°C CPU die temp. (commercial): 0°C to 105°C Ambient temp. (industrial): -40°C to 85°C CPU die temp. (industrial): -40°C to 105°C Humidity (non-condensing): 10% - 90% Dimensions (WxL) 170mm X 170mm Enclosure Not included Supports mini ITX form factor enclosures Connectivity & Interfaces I/O OS Available SKUs for HoneyComb LX2K SKU Description SRLX216S00D00GE064H04CH HoneyComb LX2K|64GB eMMC|Com. Temp|R04|Inc. Heatsink & Fan (*) Different configurations available for MOQ 3 | Page Document revision 1.3 10052020 SolidRun Ltd. HoneyComb LX2K Layout HoneyComb LX2K Block Diagram 4 | Page Document revision 1.3 10052020 SolidRun Ltd. Safety Notice a. This device is to be used with Certified Power adaptor with output rated 12VDC, 1.5A. Power adapter must meet Limited power source (LPS) requirements. b. Power adapter must meet local safety standards and requirements based on product intended use. c. Power adapter must meet Operating environment conditions as specified above. Disposal Follow local regulations regarding disposal of the product. Dispose of your product in accordance with local regulations. In some areas, the disposal of these items in household or business trash may be prohibited. Help us protect the environment- recycle! IMPORTANT NOTICE – Please Read Carefully No warranty of accuracy is given concerning the contents of the information contained in this document. To the extent permitted by law no liability (including liability to any person by reason of negligence) will be accepted by SolidRun ltd. or its employees for any direct or indirect loss or damage caused by omissions from or inaccuracies in this document. SolidRun ltd. reserves the right to change details in this publication without notice Product and company names herein may be the trademarks of their respective owners. Information in this document supersedes and replaces information previously supplied in any prior versions of this document. Support For technical support please visit: Our developer resources – https://developer.solid-run.com/ For direct support please contact us at: support@solid-run.com Documentation Additional documentation available at: https://developer.solid-run.com/products/honeycomb-lx2k/ 5 | Page Document revision 1.3 10052020 SolidRun Ltd.
SRLX216S00D00GE064H09CH 价格&库存
很抱歉,暂时无法提供与“SRLX216S00D00GE064H09CH”相匹配的价格&库存,您可以联系我们找货
