SRM6828S32D01GE008V20C0
    SOLIDRUN
    MODULE SOM DDR A388
SRM6828S32D01GE008V20C0 数据手册
Marvell ARMADA SOM A388 Dual Core SoM (System-On-Module) Rev 2.0 Simple. Robust. Computing Solutions 1 | Page SolidRun Ltd. 7 Hamada st., Yokne’am Illit, 2495900, Israel www.solid-run.com Document revision 1.0 28082017 SolidRun Ltd. 2017 Overview Embedded system product developers, device makers and OEMs can now drastically shorten their development cycle and complexity with SolidRun’s Micro-System on a Module (SOM™) family. The ARMADA SOM is the perfect building block for a fast and efficient system, and especially optimized for IoT systems. ARMADA A388 Highlighted Features Based on Marvell’s ARMADA A388 SoC Up to 2GB DDR3L (Default size 1GB) Small size 50mm×35mm Variety of temperature grades: - Commercial 0°C...60°C - Industrial -40°C...85°C Long longevity of 10 years Optimal for networking and storage applications Broad SW support 2 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 System Specifications ARMADA A388 System On Chip Marvell ARMADA 388 (88F6828) Processor core Dual core ARM Cortex A9 Processor speed Up to 1.6GHz in commercial grade Up to 1.3GHz in industrial grade Floating Point SIMD  NEON L1 Cache 32KB per core L2 Cache 1MB shared Memory Type 32 bit DDR3L ECC Optional Memory Capacity 1GB (up to 2GB) SPI Flash Optional eMMC Optional (8GB) 10/100/1000 Mbps MAC 3 ports On uSOM GE PHY 1 SDIO  I2S / SPDIF / TDM  USB 2.0 RTC Support (battery on carrier) 3  GPIO pins  Power Managements Signaling Optional JTAG  Total MUXED SERDES ** 6 SATA 4xGen III PCIE 2.0 x1 4xGen II USB 3.0 (Requires USB 2.0 port too) 2 QSGMII 1xQSGMII (3 MACs) OS Support U-boot Linux Kernel 3.x and 4.x OpenWrt Yocto Temperature Range Commercial/Industrial Supply Voltage 3.3V-5V I/O Voltage 3.3V, 1.8V SOM Interface Hirose DF40 connectors 1.5mm, 3mm mating height Dimensions (WxL) 35mmx50mm (*) Refer to the SR-Armada-uSOM-Refence-Manual for complete table. 3 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 Block Diagram 4 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 Ordering Information SKU Format SR M6828 SPI Flash S32 S32 32MB SPI Memory* D01G D01G 1GB DDR3L S32 D01G EXXX V20 @ 0 (*) Different configurations available for MOQ Storage EXXX E000 No eMMC E008 8GB eMMC Revision V20 V20 Revision 2.0 Temperature @ C Commercial (0C…60C) I Industrial (-40C…85C) 5 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 Available SKUs for SOM A388 SKU Description SRM6828S32D01GE000V20C0 A388 |32MB SPI|1GB DDR|No eMMC|Com. Temp|R2.0 SRM6828S32D01GE008V20C0 A388 |32MB SPI|1GB DDR|8GB eMMC|Com. Temp|R2.0 SRM6828S32D01GE000V20I0 A388 |32MB SPI|1GB DDR|No eMMC|Ind. Temp|R2.0 SRM6828S32D01GE008V20I0 A388 |32MB SPI|1GB DDR|8GB eMMC|Ind. Temp|R2.0 Available Accessories and Development Boards SKU Description HS00007 SOM Heatsink SRCFCPE000CV21 ClearFog Pro|Com. Temp|R2.1 SRCFCBE000CV12 ClearFog Base|Com. Temp|R1.2 SRCFCPE000IV21 ClearFog Pro|Ind. Temp|R2.1 SRCFCBE000IV12 ClearFog Base|Ind. Temp|R1.2 Safety Notice a. This device is to be used with Certified Power adaptor with output rated 12VDC, 1.5A. Power adapter must meet Limited power source (LPS) requirements. b. Power adapter must meet local safety standards and requirements based on product intended use. c. Power adapter must meet Operating environment conditions as specified above. Disposal Follow local regulations regarding disposal of the product. Dispose of your product in accordance with local regulations. In some areas, the disposal of these items in household or business trash may be prohibited. Help us protect the environment- recycle! 6 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017 IMPORTANT NOTICE – Please Read Carefully No warranty of accuracy is given concerning the contents of the information contained in this document. To the extent permitted by law no liability (including liability to any person by reason of negligence) will be accepted by SolidRun ltd. Or its employees for any direct or indirect loss or damage caused by omissions from or inaccuracies in this document. SolidRun ltd. Reserves the right to change details in this publication without notice Product and company names herein may be the trademarks of their respective owners. Information in this document supersedes and replaces information previously supplied in any prior versions of this document. Support For technical support please visit: Our Wiki – http://wiki.solid-run.com/ Our Forums - http://forum.solid-run.com/ For direct support please contact us at: support@solid-run.com Documentation Additional documentation available at: http://wiki.solid-run.com/doku.php?id=products:a38x:documents 7 | Page Document revision 1.0 28082017 SolidRun Ltd. 2017
SRM6828S32D01GE008V20C0 价格&库存
很抱歉,暂时无法提供与“SRM6828S32D01GE008V20C0”相匹配的价格&库存,您可以联系我们找货
