MS034MPG58E1
MS034MPG58E1
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    RT ANGLE PIN CONTACT BOA
MS034MPG58E1 数据手册
V.35 - Interface connectors V.35 DTE/DCE Interface connectors Description The Telecommunications Standardization Sector TSS V.35, formerly CCITT V.35 is the international standard termed “Data Transmission at 48 Kbps using 60108 Khz Group-Band Circuits. It makes use of a 34 contact connection system specially designed to be used for DTE/ DCE that interface to high speed digital carriers found in computer, modem and telecommunication industries. Being part of the TRIM TRIO wide range of high reliable rectangular connectors, MSO34 (boardmount connectors) and MS34 (cable connectors) are in complete compliance to this specification. To meet this specification, insulators have been manufactured with 34 contact positions which can be loaded with the international accepted N° 16 TRIM TRIO .0625” (1.6mm) diameter contacts. The boardmount connectors (MSO34) are available in straight and right angle versions equipped with either solid machined or stamped and formed male / female contacts. The cable connectors (MS34) can be offered with a full range of hardware and accessories. Guiding pins and sockets, turnable jackscrew system, different cable hoods with strain relief, pin protection shrouds and discrimination pins make this connector range as complete as possible. Features and benefits • Complete compliance with International Standards of ISO 2593 for TTS V.35 (formerly CCITT V.35) interfacing. • In compliance with NFC 93426 - HE621622 and MIL-C-28748 specifications. • UL recognised. • UL94-V0 rated thermoplastic • Boardmount connectors supplied preassembled with dipsolder contacts in either: - Male or female contacts. - Machined or stamped and formed contacts - Straight or right angle • Stamped and formed contacts have selective tin plating on solder tails, thus eliminating extra flux operations. • Selective loading possible on request. • Right angle version equipped with true position location wafer. • Hold-down feature available Intermateability All the references mentioned are perfectly intermateable, provided that 1 mated pair exists out of a plug half and a receptacle half. Mated pairs can be made for following applications: - Cable to cable - Cable to panel - Cable to straight or right-angled boardmount Technical data on MSO34 PC-Boardmount connectors Technical data on MS34 Cable connectors Performance characteristics Performance characteristics Operating temperature: Current rating: Operating temperature: Insulation resistatance: Test potential: Durability: -55°C to +125°C 5 Amp for stamped contacts 7.5 Amp for machined contacts Contact resistance: ≤ 3mΩ Insulation resistance: 5000 MΩ min. Test potential: 2000 VAC Durability: 500 matings and unmatings. Plating table Plating for solid machined contacts: No digit (std) = Min. 0.4µ Gold all over, over Nickel. T = 3 - 5µ Tin all over Plating for Stamped and formed contacts : K9 (std) = Min. 0.4µ Gold in contact area, 3 - 5µ SnPb on solder tail. T = 3 - 5µ Tin all over Construction Material : Glass-reinforced thermoplastic Flammability rating : UL94-V0 Polarising hardware: Brass nickel plated Contacts: High conductive copper alloy 67 Vibration resistance: Shock: -55°C to +125°C 5000 MΩ min. 2000 VAC 500 matings and unmatings. Per MIL-STD 202 method 204 Per MIL-STD 202 method 207 Contact accommodation • “MS” Cable connectors accept TRIM TRIO size 16 removable snap-lock contacts (see contact section) • Contacts to be ordered separately Construction Connector body: Glass-reinforced Phenolic Flammability rating : UL94-V0 Cable hoods: Aluminium alloy or Polyamide 6.6 Cable clamps: Stainless steel Protection Shrouds: Aluminium alloy V.35 - Interface connectors How to order Connector family MSO Contact arrangement N° 16 contacts Type of housing P: Plug body with male contacts R: Receptacle body with female contacts Contact termination K: straight dipsolder G: Right angle dipsolder H: Reversed version Type of hardware 1: Guide pin and socket 58: Threaded jackscrew pin and socket Design variation E1: Solid machined contacts SE1: Stamped and formed contacts SL1: Metal bracket SEH1: Hold down rivets Plating indication MS034 recommended drilling hole pattern Size 34 68 34 M R G 58 SE1 K9 V.35 - Interface connectors MSO34 Straight boardmount connectors Part number Version with Version with solid machined contacts stamped and formed contacts Description MSO34MPK1E1 MSO34MPK1SE1K9 Guide pin, guide socket and male contacts MSO34MRK1E1 MSO34MRK1SE1K9 Guide pin, guide socket and female contacts MSO34MPK58E1 MSO34MPK58SE1K9 Jackscrew pin, jackscrew socket and male contacts MSO34MRK58E1 MSO34MRK58SE1K9 Jackscrew pin, jackscrew socket and female contacts For other platings: See plating table Other solder tail lengths on request Selective loading on request MSO34 Right-angled boardmount connectors Part number Version with Version with solid machined contacts stamped and formed contacts Description MSO34MPG1E(*)1 MSO34MPG1SE(*)1K9 Guide pin, guide socket and male contacts MSO34MRG1E(*)1 MSO34MRG1SE(*)1K9 Guide pin, guide socket and female contacts MSO34MPG58E(*)1 MSO34MPG58SE(*)1K9 Jackscrew pin, jackscrew socket and male contacts MSO34MRG58E(*)1 MSO34MRG58SE(*)1K9 Jackscrew pin, jackscrew socket and female contacts For other platings: See plating table Other solder tail lengths on request (*) Complete part number with “H” for connector with hold down rivets 69 Selective loading on request V.35 - Interface connectors MSO34 Right-angled boardmount connectors – Standard version with metal brackets Part number Version with stamped and formed contacts Description MSO34MPG1SL1K9 Guide pin, guide socket and male contacts MSO34MRG1SL1K9 Guide pin, guide socket and female contacts MSO34MPG58SL1K9 Jackscrew pin, jackscrew socket and male contacts MSO34MRG58SL1K9 Jackscrew pin, jackscrew socket and female contacts For other platings: See plating table Other solder tail lengths on request Selective loading on request MSO34 Right-angled boardmount connectors – Reversed version with metal brackets Part number Version with stamped and formed contacts Description MSO34MPH1SL1K9 Guide pin, guide socket and male contacts MSO34MRH1SL1K9 Guide pin, guide socket and female contacts MSO34MPH58SL1K9 Jackscrew pin, jackscrew socket and male contacts MSO34MRH58SL1K9 Jackscrew pin, jackscrew socket and female contacts For other platings: See plating table Other solder tail lengths on request 70 Selective loading on request V.35 - Interface connectors MS34 Cable connectors with metal butterfly hood Part number Version with male contacts Version with female contacts Description MS34PM120(*)GE00 MS34RM120(*)GE00 Guide pin, guide socket and butterfly hood. MS34PM140(*)GE00 MS34RM140(*)GE00 Jackscrew pin , jackscrew socket and butterfly hood. MS34PM124(*)GE00 MS34RM124(*)GE00 Turnable jackscrew pin, turnable jackscrew socket and butterfly hood. MS34PM1(*)GE00 MS34RM1(*)GE00 Guide pin and guide socket. No strain relief hood MS34PM58(*)GE00 MS34RM58(*)GE00 Jackscrew pin and jackscrew socket. No strain relief hood. MS34PM007(*)GE00 MS34RM007(*)GE00 Turnable jackscrew pin and turnable jackscrew socket. No strain relief hood. (*) Complete catalogue number with “ S “ for connector with protective shroud. MS34 Cable connectors with cable clamp Part number Version with male contacts MS34PM117(*)GE00 Version with female contacts Description MS34RM117(*)GE00 Guide pin, guide socket and cable clamp MS34PM127(*)GE00 MS34RM127(*)GE00 Jackscrew pin, jackscrew socket and cable clamp MS34PM107(*)GE10 MS34RM107(*)GE10 Turnable jackscrew pin, turnable jackscrew socket and cable clamp. (*) Complete catalogue number with “S” for connector with protective shroud. 71 V.35 - Interface connectors MS34 Cable connectors with metal suitcase hood Part number Version with male contacts Version with female contacts Description MS34PMEHM(*) MS34RMEHM(*) Anodised hood, plastic strain relief and turnable hardware. MS34PMSEHM(*) MS34RMSEHM(*) Shielded version with nickel plated hood, metal strain relief and MS34PMEHMMET1 MS34RMEHMMET1 Version with spring loaded jackscrews turnable hardware. (*) Complete catalogue number with “ S “ for connector with protective shroud. MS34 Cable connectors with plastic suitcase hood Part number Version with male contacts Version with female contacts Description MS34PMEH2(*) MS34RMEH2(*) Guide pin, guide socket and plastic suitcase hood. MS34PMEH3(*) MS34RMEH3(*) Jackscrew pin, jackscrew socket and plastic suitcase hood. MS34PMEH0(*) MS34RMEH0(*) Turnable jackscrew pin, turnable jackscrew socket and plastic suitcase hood. (*) Complete catalogue number with “S” for connector with protective shroud. 72
MS034MPG58E1 价格&库存
很抱歉,暂时无法提供与“MS034MPG58E1”相匹配的价格&库存,您可以联系我们找货
