UT06104PT
UT06104PT
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN HSG PLUG 4POS INLINE PIN
UT06104PT 数据手册
UT0 - Bantam Metal circular connector (Suitable for EMC requirements) Description “UT0” Bantam industrial circular connectors are a range of multiway connectors available in 8 shell sizes and 8 insert arrangements all intermateable, interchangeable and intermountable with the Trim-Trio “UTG” , “UTGS” and “UTP industrial connector families. “UT0” is equipped with identical shells from military connectors complying to MIL-C-26482 spec. Strong and rugged built to resist every environmental and mechanical requirement for indoor and outdoor applications. In combination with the shielded backshell , “UT0” offers the perfect solution to EMC requirements. Features and benefits Performance characteristics Construction • Suitable for EMC requirements. • Shielded backshell is independent of the cable diameter and its shielding. • Available in 8 shell sizes and 8 insert arrangements. • Available in plug and receptacle version for both male and female contacts. • Shells and accessories are made from tin plated corrosion resistant Aluminium. • Plastic inserts with flammability rating: UL94-V0. • Alu. bayonet ring: - Metal wave spring loaded. - Locks with audible positive “click” - Assures 500 matings and unmatings Operating temperature: Insulation resistance: Test potential: Durability: Vibration resistance: Thermal shock: Corrosion: Shells and accessories: Alumimium alloy Coupling ring: Aluminium alloy Tri-lock pins: Stainless steel Coupling spring: Spring steel Insert: Glass-filled thermoplast UL94-V0 Finish: Bright tin (standard) How to order 5000 MΩ min. 2000 VAC 500 matings and unmatings. Per MIL-STD202 method 204 Per MIL-STD202 method 207 Salt spray per MIL-STD 202 method 101 Shielding effectiveness: 95 dB at 1 Mhz (see shielded connectors section) Degree of protection per DIN 40050: IP65 in mated condition. “H” version used with UTG-PG cable clamp UT0 UT0 Body variation: -55°C to +125°C 0 6 14 14 12 12 P S 0 : Wall mounting receptacle 6 : Cable plug 1 : Free hanging receptacle 7 : Bulk head receptacle for rear panel mounting Shell size: Insert arrangement: Type of contacts: P : Pin contacts S : Socket contacts Insert polarisation: No letter : Standard version Application: No letter : Standard version H : Water protected version (only receptacle) Design variation: No letter : Standard version Others : Special versions Plating: T : Bright tin (Standard version) Packing: No letter: Standard version: Each connector individualy packed in plastic bag B: Bulk packing per qty of 100 pcs 12 Contact accommodation • “UT0” connectors accept Trim-Trio crimptype removable snap-lock contacts (see contacts section) • Contacts to be ordered seperately. – – H –– T B B UT0 - Bantam UTO Cable plug for pin contacts (UT06- - - -PT) Part number Shell size UT06104PT UT06128PT UT061412PT UT061619PT UT061823PT UT062028PT UT062235PT UT062448PT 10 12 14 16 18 20 22 24 ØA ±0.2 21.6 24.8 28.0 31.2 34.3 37.5 40.7 43.9 B max. 31.8 ØC ±0.15 10.2 13.4 16.7 19.7 21.7 24.9 28.1 31.2 ØD ±0.15 12.3 15.1 18.3 21.5 24.0 27.2 30.4 33.5 E ±0.2 19.1 For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT061412PTB Cable plug for socket contacts (UT06- - - -ST) Part number Shell size UT06104ST UT06128ST UT061412ST UT061619ST UT061823ST UT062028ST UT062235ST UT062448ST 10 12 14 16 18 20 22 24 ØA ±0.2 21.6 24.8 28.0 31.2 34.3 37.5 40.7 43.9 B max. 31.8 24.9 26.2 ØC ±0.15 10.2 13.4 16.7 19.7 21.7 24.9 28.1 31.2 ØD ±0.15 12.3 15.1 18.3 21.5 24.0 27.2 30.4 33.5 E ±0.2 19.1 For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT061412STB 13 UT0 - Bantam Wall mounting receptacle for pin contacts (UT00- - - -PT) Part number UT00104PT UT00128PT UT001412PT UT001619PT UT001823PT UT002028PT UT002235PT UT002448PT Shell size 10 12 14 16 18 20 22 24 A max. B C ØD E F ØG ØH ØJ ±0.25 ±0.2 ±0.15 ±0.25 •0.25 ±0.1 ±0.1 ±0.1 15.0 19.0 22.2 25.3 28.5 31.7 34.9 38.0 18.3 20.6 23.0 24.6 26.9 29.4 31.8 34.9 23.8 26.2 28.6 31.0 33.3 36.5 39.7 42.9 3.9 17.3 21.8 25.0 28.1 31.3 34.5 37.7 40.9 15.1 18.2 21.4 24.6 27.8 30.9 34.1 37.3 1.6 31.7 11.3 14.5 33.3 2.4 15.3 3.2 For waterprotected version add “H” behind “P” e.g. UT001412PHT For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT001412PTB Wall mounting receptacle for socket contacts (UT00- - - -ST) Part number Shell size A max. B C ØD E F ØG ØH ØJ ±0.25 ±0.2 ±0.15 ±0.25 •0.25 ±0.1 ±0.1 ±0.1 15.0 19.0 22.2 25.3 28.5 31.7 34.9 38.0 18.3 20.6 23.0 24.6 26.9 29.4 31.8 34.9 23.8 26.2 28.6 31.0 33.3 36.5 39.7 42.9 17.3 21.8 25.0 28.1 31.3 34.5 37.7 40.9 15.1 18.2 21.4 24.6 27.8 30.9 34.1 37.3 UT00104ST 10 UT00128ST 12 1.6 UT001412ST 14 24.3 11.3 UT001619ST 16 UT001823ST 18 UT002028ST 20 14.5 UT002235ST 22 25.9 2.4 UT002448ST 24 15.3 For waterprotected version add “H” behind “P” e.g. UT001412SHT For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT001412STB 14 3.2 3.9 UT0 - Bantam UTO Free hanging receptacle for pin contacts (UT01- - - -PT) - suitable for cable to cable applications Part number Shell size UT01104PT UT01128PT UT011412PT UT011619PT UT011823PT UT012028PT UT012235PT UT012448PT 10 12 14 16 18 20 22 24 A max. B ±0.25 31.7 1.6 33.3 2.4 C ±0.2 11.3 14.5 15.3 ØD ±0.15 14.9 19.0 22.2 25.3 28.5 31.7 34.9 38.0 ØE max. 24.1 26.4 28.8 31.2 33.6 36.8 39.9 43.1 For waterprotected version add “H” behind “P” e.g. UT011412PHT For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT011412PTB Free hanging receptacle for pin contacts (UT01- - - -ST) - suitable for cable to cable applications Part number Shell size UT01104ST UT01128ST UT011412ST UT011619ST UT011823ST UT012028ST UT012235ST UT012448ST 10 12 14 16 18 20 22 24 A max. B ±0.25 24.3 1.6 25.9 2.4 C ±0.2 11.3 14.5 15.3 ØD ±0.15 14.9 19.0 22.2 25.3 28.5 31.7 34.9 38.0 ØE max. 24.1 26.4 28.8 31.2 33.6 36.8 39.9 43.1 For waterprotected version add “H” behind “P” e.g. UT011412SHT For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT011412STB 15 UT0 - Bantam Bulk head receptacle for pin contacts (UT07- - - -PT) - suitable for rear panel mounting Part number UT07104PT UT07128PT UT071412PT UT071619PT UT071823PT UT072028PT UT072235PT UT072448PT Shell size 10 12 14 16 18 20 22 24 A B ±0.15 ±0.2 14.9 19.0 22.2 25.3 28.5 31.7 34.9 38.0 18.0 D max. F max. 31.7 3.2 33.3 6.4 22.7 23.6 G H K L ØM ±0.25 •0.2 ±0.2 ±0.12 ±0.2 27.0 31.8 34.9 38.1 41.3 46.1 49.2 52.4 22.2 27.0 30.2 33.3 36.5 39.7 42.9 46.0 16.6 20.8 23.9 27.1 30.3 33.4 36.6 39.8 17.0 21.2 24.3 27.5 30.6 33.8 37.0 40.1 17.7 22.5 25.7 28.7 32.0 35.2 38.4 41.5 For waterprotected version add “H” behind “P” e.g. UT071412PHT For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT071412PTB Bulk head receptacle for pin contacts (UT07- - - -ST) - suitable for rear panel mounting Part number UT07104ST UT07128ST UT071412ST UT071619ST UT071823ST UT072028ST UT072235ST UT072448ST Shell size 10 12 14 16 18 20 22 24 A B ±0.15 ±0.2 14.9 19.0 22.2 25.3 28.5 31.7 34.9 38.0 18.0 D max. 24.3 3.2 25.9 6.4 22.7 23.6 For waterprotected version add “H” behind “P” e.g. UT071412SHT For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT071412STB 16 F max. G H K L ØM ±0.25 •0.2 ±0.2 ±0.12 ±0.2 27.0 31.8 34.9 38.1 41.3 46.1 49.2 52.4 22.2 27.0 30.2 33.3 36.5 39.7 42.9 46.0 16.6 20.8 23.9 27.1 30.3 33.4 36.6 39.8 17.0 21.2 24.3 27.5 30.6 33.8 37.0 40.1 17.7 22.5 25.7 28.7 32.0 35.2 38.4 41.5
UT06104PT 价格&库存
很抱歉,暂时无法提供与“UT06104PT”相匹配的价格&库存,您可以联系我们找货
