UTL7103G1P14AWG
UTL7103G1P14AWG
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    4(3 + PE) 针位圆形连接器 插座,母插口和公引脚 压接
UTL7103G1P14AWG 数据手册
UTL Series Evaluation kit Complete UTL evaluation kit it: designed to simplify ordering and assembly. Accommodates a variety of cable variations, each kit comes complete with contacts, connector housing and cable boot. Male insert Connector type Plug Inline receptacle Jam nut receptacle Square flange receptacle Boot Female insert Part number Contact part number & quantity Part number Contact part number & quantity 1 UTL6103G1P20AWG SM20ML1S31 x 4 SC20ML1S31 x 2 UTL6103G1S20AWG SM20ML1S31 x 2 SC20ML1S31 x 4 1 UTL6103G1P16AWG SM16ML1S31 x 4 SC16ML1S31 x 2 UTL6103G1S16AWG SM16ML1S31 x 2 SC16ML1S31 x 4 1 UTL6103G1P14AWG SM14ML1S31 x 4 SC14ML1S31 x 2 UTL6103G1S14AWG SM14ML1S31 x 2 SC14ML1S31 x 4 1 UTL1103G1P20AWG SM20ML1S31 x 4 SC20ML1S31 x 2 UTL1103G1S20AWG SM20ML1S31 x 2 SC20ML1S31 x 4 1 UTL1103G1P16AWG SM16ML1S31 x 4 SC16ML1S31 x 2 UTL1103G1S16AWG SM16ML1S31 x 2 SC16ML1S31 x 4 1 UTL1103G1P14AWG SM14ML1S31 x 4 SC14ML1S31 x 2 UTL1103G1S14AWG SM14ML1S31 x 2 SC14ML1S31 x 4 1 UTL7103G1P20AWG SM20ML1S31 x 4 SC20ML1S31 x 2 UTL7103G1S20AWG SM20ML1S31 x 2 SC20ML1S31 x 4 1 UTL7103G1P16AWG SM16ML1S31 x 4 SC16ML1S31 x 2 UTL7103G1S16AWG SM16ML1S31 x 2 SC16ML1S31 x 4 1 UTL7103G1P14AWG SM14ML1S31 x 4 SC14ML1S31 x 2 UTL7103G1S14AWG SM14ML1S31 x 2 SC14ML1S31 x 4 - UTL0103G1P20AWG SM20ML1S31 x 4 SC20ML1S31 x 2 UTL0103G1S20AWG SM20ML1S31 x 2 SC20ML1S31 x 4 - UTL0103G1P16AWG SM16ML1S31 x 4 SC16ML1S31 x 2 UTL0103G1S16AWG SM16ML1S31 x 2 SC16ML1S31 x 4 - UTL0103G1P14AWG SM14ML1S31 x 4 SC14ML1S31 x 2 UTL0103G1S14AWG SM14ML1S31 x 2 SC14ML1S31 x 4 Connection Technologies Evaluation kit Evaluation kit assembly The boot is semi-flexible and heat-shrinkable with a moldable adhesive inner lining. • • • • • • • • • • 123456- Place the heat shrink boot over the cable Strip the cable jacket (see page 33) Strip the individual wires (see page 31) Crimp the contacts Place the contacts in their cavities, checking the retention by slightly pulling the cable Clean the connector surface and the cable jacket with isopropyl alcohol (Note: It is advised to rub the jacket with sand paper and clean the jacket before shrinking the boot) 7 - Position the boot over the rear threads 8 - Heat the boot with a heat gun: minimum shrink temp: 80°C - minimum full recovery temp: 110°C make sure to apply the heat evenly around the boot. Starting by applying the heat from the rear of the connector. Do not apply excessive heat, as it will damage the connector and/or boot. 9 - Let the boot cool down 10 - Check for good retention and the boot glue grip. 4 8 5 9 7 10 For further information, visit our website www.souriau-industrial.com or contact us at contactindustry@souriau.com 2 INDUTLPROTOKITFL01EN © Copyright SOURIAU 2012 - All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. UTL Series
UTL7103G1P14AWG 价格&库存
很抱歉,暂时无法提供与“UTL7103G1P14AWG”相匹配的价格&库存,您可以联系我们找货
