BOB-15100
BOB-15100
    SPARKFUNELECTRONICS
    USB-C BREAKOUT
BOB-15100 数据手册
        SparkFun USB-C Breakout BOB-15100 With this USB breakout you will finally be able to incorporate a USB-C connector into your projects without needing to solder each tiny SMD pad. The SparkFun USB-C Breakout supplies up to three times the power as previous USB iterations and also solves the universally frustrating dilemma of plugging a USB cable in correctly because it’s reversible! This board breaks out the USB-C connector’s VBUS, GND, CC1, CC2, D+, and D- pins intro a 0.1" pitch header while providing up to a nominal 1.5A of power and up to 3A depending on the upstream device. FEATURES        Dimensions: 22.1mm x 14mm x 4.9mm (0.87in x 0.55in x 0.19in) Weight: 1.35g        https://www.sparkfun.com/products/15100 12‐3‐18
BOB-15100 价格&库存
很抱歉,暂时无法提供与“BOB-15100”相匹配的价格&库存,您可以联系我们找货
